Question about Kenwood KAC-7203 Car Amp
Red light is the light meant to be red
The security light on my dash keeps flashing red when I turn off my toyota sienna and lock the doors.
think its,meant too ,flash red its showing the alarms activated .if vehicle is left any length of time always disconnect the battery
Mar 12, 2015 | 2004 Toyota Sienna
I have a Samsung ML-2525 BW laser printer. Recently, the red bar second from the top started flashing and then it went solid. I thought this was because of the ink toner, and the cartridge was running low...
I guess it FixYa didn't accept my (very long, but totally correct) solution that I took the time to type. Because I refused to "sign in".
Here's the short version. Load Paper. The same thing happened to me. I replaced the toner cartridge with a new one (because of a FLASHING red light for several weeks) after the red light went to STEADY red. But it still would not print. The paper was "out". When I'd refilled the paper-tray, it printed fine. I had just ASSUMED that the steady-red light meant toner was finally OUT. WRONG! That steady-red light had nothing-to-do with toner; it meant "you're out-of-paper". Don't get confused like I did. Refill the paper-tray. Then take that expensive NEW toner cartridge OUT, and put the OLD toner cartridge back in. And keep using the "dregs" of the toner out of the old cartridge for several more weeks. And DON'T get confused by the paper-is-out condition making that red light STEADY.
Nov 01, 2010 | Samsung ML 2525 BW laser Printer
What does the red blinking light on battery meant ? It is on The Electric Earthwise Lawnmower.
Red blinking light according to test at Batteries Plus means that the charger is kaput.
Sep 29, 2010 | Electric Earthwise Corded Lawn Mower...
I cant connect to xbox live
The red meant it was ready for configuration. If there is no light it means it is not receiving power. Try plugging it in again, or plugging it in to a front USB slot. If it still doesn't work your adapter has a defect and should be replaced.
Dec 30, 2009 | Microsoft Wireless Network Adapter Xbox...
X box 360 pro showing 4 red lights ????????
Does this console have HDMI? I am not sure about the ones that have HDMI, but on the pre-HDMi units, if you had 4 flashing red lights it meant something with the A/V connection. Usually the A/V connector is not inserted all the way or the A/V cable is bad.
Nov 18, 2009 | Microsoft Xbox 360 Console
Dull red on a Xerox Phaser 8400
That normally is a print head issue and replacing the print head is the only resolution I have had that resolves that problem. Sometimes the red will be almost maroon, other times it will be orange.
But is should normally be a pure red.
Jun 20, 2008 | Xerox Phaser 8200 Laser Printer
Xbox 360-Red to Green
Look on the back of your tv and make sure that the red and blue cables are plugged into the right slot on the back of your tv. This would be the most common cause for something like this that you are describing.
Feb 09, 2008 | Microsoft Xbox 360 Console
Kenwood KAC-7203 Car Amp Logo
18 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
