Question about Dell Latitude D630 Intel Core 2 Duo T7250 2M L2 Cache, 800MHz Dual Core 80GB/512... PC Notebook
Dell code 2000-0148
When I turn it on it boots up into windows (XP) and shuts down 3-4 minutes later. It is saying HD issues but can it be a motherboard ? Please can you help me with this problem.
  • 221 Answers
Hi, when your laptop shuts off after running for 3-4 minutes, does the computer reboot and attempt to reload or go back into Windows? or does it just shut off and stay off?
Posted on Jul 28, 2013
  • Dell Master
  • 3,799 Answers
It could be the motherboard, but it is more likely to be a hard drive. Back up anything you need as soon as possible and replace the drive and re-install the operating system(Windows)
vincebeach
  • 37 Answers
SOURCE: Dell XPS M140 laptop shuts off after powering on
Most laptops that I have worked on that power off that quickly turned out to be an overheating problem. Is the cooling fan running for the brief period that you can hear the hard drive before it powers off ? If the fan is running another potential resolution might be to remove the processor and apply new thermal paste.
Posted on Nov 11, 2008
Char1ieJ
  • 100 Answers
SOURCE: not going in window xp
The error code indicates that your hard drive is failing. If the laptop is still under warranty, contact Dell for support. If not, I would suggest trying to get it booted one more time and copying everything you want to keep off of it. Then, look for a new 2.5" hard drive on Geeks.com or TigerDirect.com (some place like that). Either way, the hard disk is probably on its last leg. I hope this helps!
Posted on Nov 17, 2008
  • 53 Answers
SOURCE: dual boot vista/XP on dell studio 1737, drivers needed ?
For the video drivers you might try the intel generic drivers for xp these should work here is the process.
For the audio use the latest vista driver and then follow the steps here.
The latest driver in combination with f you are using Microsoft Windows XP*, you may need to first install KB888111.exe, the Microsoft* UAA High Definition Audio Package version 1.0a. should work.
Posted on Jan 30, 2009
efs_perpends
  • 1996 Answers
SOURCE: I have the same problem D830
Seems to me if it ran normally until powered down that the motherboard would have to be functioning, no? It's a boot or startup problem, but there are all kinds of hardware and software issues that could cause that. Have you tried booting into safe mode or last known good configuration by pressing F8 as it boots up?
Try going to Dell support and enter your service tag # and see if there are any service bulletins or advisories for your laptop, then maybe search the Dell forums for reports of the same. If the motherboard was an issue on your model, you'll find some forum posts about it.
See also Dell support for your boot problem here.
If you get it booted up again, you might like to take a look at the event viewer and device manager and see if there are errors or warnings posted that indicate software or hardware problems on your system. Also consider running the Dell diagnostics utility (see here) to check the system health. And run chkdsk to scan the hard drive for corruption. (instructions here and here)
Malware removal protocols I'd recommend as a check here.
Good general troubleshooting for windows here and startup here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jul 10, 2009
  • 30 Answers
SOURCE: Dell Inspiron Mini 10 Not Shutting Down Properly
There could be a corrupted file. I would try to give dell tech support a call
Posted on Sep 21, 2009
Dell Dimension tries to boot, blinking cursor
first check the BIOS settings whether the first boot device set to be hard disk and no CD in the CDROM and also ur system is virus free
Apr 19, 2010 | Dell Dimension 3100 PC Desktop
Dell Latitude D410 - OS won't boot only after a few minutes
Seeing that both OS's (Windows XP and Ubuntu) are having a problem booting up, I also think the problem is with your HDD. I think you have a pretty good idea about computers from your use of terms :) There may be some corruption with the HDD. I would check that out first.
Good luck with your problem and thanks for using FixYa.com!!
Apr 18, 2010 | Dell Latitude D410 Notebook
Dell 4700 bios a06 2.8 ghz 64 bit bus=800mhz pentium 4 2.8 ghz microsoft xp pak 2 moterboard light= green abcd lights=green reset bios to factory settings computer keep shutting down.. windows dialog box...
You have a rootkit virus, the only answer is reformat the drive and start fresh, sorry.
After a fresh install is done immediately install service(can be downloaded free from microsoft.com) pack 3, because sp2 is vulnerable to a host of trouble.
Apr 17, 2010 | Dell Dimension 4700 PC Desktop
Windows shut down to prevent damage
You need to boot your system into Safe Mode by pressing F8 just before the Windows startup screen loads, once in Safe Mode do a system restore to a previous date to when your system was working.
This should sort out your problem.
Sep 09, 2009 | Dell Inspiron 1525 Laptop
Dear I installed Xp windows on my hard disk on Pc with Dell Board or you can say dell Pc but later I changed my that hard disk to other PC with Compaq board 686T3 version 2.1 but then hard disk did not...
In most cases you cannot swap hard drives from one Pc to another and expect it to boot. After the initial bios boot it does not recognize the machine or have the correct settings for it so it wont boot. All you can do in that case is to reinstall windows on the Pc that you have installed the Hd in.
Apr 25, 2009 | Computers & Internet
Blank Black Screen After Windows XP Loading Page
the easiest solution would be to re-install windows and hope it is not a hardware problem
Jan 12, 2009 | Dell Dimension 2400 PC Desktop
Blue screen and windows shut down
For the issue of BSOD of Unmountable Boot volume, the only solution so far is to reinstall the system. If you are unaware of how to do it, it would be easier to contact Dell technical support and allow them to guide you thru it. (if your warranty is active, it's free)
Dec 21, 2008 | Dell Inspiron 6000 Notebook
Windows XP shutdown
The computer is just doing it's internal diagnostics before it shuts down. This uses fairly little amount of physical memory. Every computer handles it differently depending on your configuration. If the computer does shut down on it's own....there is no real problem present.
Feb 22, 2008 | Microsoft Windows XP Professional With...
I cant install windows in my computer
Have you tried another installation CD?
Have you performed a HD format with a Windows 98 boot disk?
Nov 28, 2007 | Compaq Armada E500 Notebook
Dell Latitude D630 Intel Core 2 Duo T7250 2M L2 Cache, 800MHz Dual Core 80GB/512... PC Notebook Logo
67 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
