Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Sm8525079 Clean softner dispinser
My LG washer machine will not rinse thru the softer section in the cup, what can I do?
then the solenoid is not actuating to allow water into drawer. take top off, very easy, two screws in back, pull back, lift off. follow hose from softer cup to little round device/solenoid. check wiring. check hose, tho you would know there was a problem with hose, because you would see a water leak. replace solenoid. hope this is the issue. good luck.
Mar 02, 2015 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Water is coming up in fabric softner cup during rinse time front loader
this is normal
water should go thru the softner and into the drum when the machine rinses to introduce the softner to the drum
Dec 05, 2014 | Kenmore Elite 45986 Front Load Washer
My fabric softner will not dispense into the washer
Clean out dispenser it maybe clogged due to softner,rember clean dispencer and machine once a month.
Jul 05, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Maytag MTW5620T2 the fabric softner despenser doesn't despense. There is mositure inside and it slings fabric softner everywhere. It leaks from the side hole of the agitator. Gets fabric softner on my...
Liquid Softener was clogged up over time.
1-Put hot water in the place of the Softener slowly and let it over flow to dissolve the solidified liquid.
2-Keep doing this until you see water at the bottom of the tub.
3-Run a small load to clean out the gum.
Jul 02, 2009 | Maytag Washing Machines
Jetstream 1200 wont take away fabric softner
strip and clean out the soap tray then remove the tray and clean the fill water holes above it with a stiff washing up brush.
Mar 16, 2009 | Zanussi ZWF1430W Front Load Washer
"fabric softner staining the clothes"
make sure you delute it with water. yes fabric softner will start to stain your clothes if you use too much of it. I would recomend stop useing it for a while. so you can clean the washer out. There is a product called Washer magic or Affresh that cleans out residues built up in your washer. or you can just run several loads of HOT water and bleach to clean it out. The hot water will melt the left over fabric softner in your washer. Fabric softner is kind of like hardend bacon fat thats what it looks like in your washer after time and if you do not clean your washer it builds up and builds up.
Also i do recomend alternating liquid detergent and powdered detergent. The reason why is powder leaves a residue that liquid takes away and vise versa. try this and let me know how it goes
Feb 12, 2009 | Maytag PAV2300 Top Load Washer
Water collecting in the fabric softner dispencer
you need to take out dispenser draw and clean out under tap
the softner dispenser syphons out and if channels are gluged up the dispenser will not empty
Mar 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Zanussi jetsytem fjs1225w
clean the draw out remove the top where the softner goes and clean under there.
Jan 22, 2008 | Zanussi FJS1225W Front Load Washer
Softner remaining
Try diluting the softener, some softener are too thick. But first clean out the softenre tray, by pulling it out, or with a tooth brush. Do look into your user manual. Does water enter the soft tray, check this too.
Sep 08, 2007 | Zanussi FJS1225W Front Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
