Question about Electrolux 15 Turquoise Sky Pedestal EPWD15TS
Order oars for washer drawer - Electrolux 15 Turquoise Sky Pedestal EPWD15TS
    New Friend:
Program board is most likely gone
Posted on Aug 03, 2013
Electrolux frontloader washer detergent drawer won't stay shut
Hello royal37 - Hi - The dispenser drawer could either be cracked or have a broken latch due to interference between the drawer front and top panel. Contact a professional to move forward accurately and might possibly need to order a service kit (PN: 137146000/part number may be different depending on your model number).
Feb 13, 2013 | Electrolux EWFLW65H 4.7 Cu. Ft. Washer
Soap dispensewr will not close
Hi - If dispenser drawer will not stay pushed in it could either be cracked or have a broken latch due to interference between the drawer front and top panel. Contact a professional to move forward accurately and might possibly need to order a service kit (PN: 137146000) if it is an Electrlolux washer.
Oct 19, 2012 | Electrolux EW1000i Front Load Washer
The dispenser drawer is jammed after i put it back to gether,
It is possible that the dispenser assembly is warped and may need to be replaced. The part number is 4925ER1015B. You can also order the replacement drawer assembly if that's been damaged. The part number is 3721ER1073D.
Jul 20, 2011 | LG WM-2277HW Front Load Washer
Washer leaks from the front - not a major leak but noticeable none the less. Have checked hoses but no problem there. Can you help?
1. Remove the lid of the washing machine by removing 2 screws from behind.(Power and water off etc.) You will probably see rust on the steel above the drawer unit.
2. Remove the drawer.
3. Label all hoses leading to the drawer unit (for re-assembly) and remove the hoses.
4. Remove the drawer unit - a bit fiddly. (2 screws at front of washer at either side of drawer unit need to be removed.)
5. Remove the lid from the drawer unit. Thoroughly wash out the drawer unit. Also wash out the drawer. (I forgot whether the lid can be removed before removing the whole unit from the machine.)
6. There is a thin hose leading from the drawer unit to the drain in the back of the washer - make sure this hose is not blocked. Remove hose and run water through it.
7. Re-assemble everything into the washer.
8. This is the controversial bit: (The drawer unit should be fully installed but the drawer is still removed)
- Silicone seal the gap between the drawer unit and the plastic at the front of the washer, (Seal all round, but especially at the top. It should be possible to do this neatly, Try to get silicone fully into the gap, not just between the two pieces of plastic. (I flexed down the plastic at the top of the drawer unit to get silicone into the gap.
9. Replace the drawer and wait a day before using the machine.
Jun 28, 2011 | Washing Machines
LG Front Loading washer detergent drawer is jammed and will not open
you're in a bad spot. you will need to remove top metal panel of washer; and carefully separate the drawer housing a little and wiggle the drawer out. one of the compartments in the drawer popped up and jammed the drawer.
Feb 15, 2010 | LG WM-2277HW Front Load Washer
Can one purchase or order the detergent drawer assembly?
You can order this part directly from Sears. Sears has a very good parts dept. and you can order online.
Oct 09, 2009 | Kenmore 44102 Front Load Washer
How are the oars supposed to be positioned in the
You should push the collar all the way out to the locks. When you are pulling through the water, the cup of the oar should face the same way you face. As you return up your slide, the cup should be facing straight up.
In order to keep the oar inside the oar locks, simply close the latch on the top side of the oar lock. This is usually something you snap down, and screw on.
Aug 28, 2009 | Boating
Conditioner remains in drawer after wash cycle on my Bosch Classixx 1400 Express
i have done this recently. you need to remove the top of the washer and the disconnect all the items attached to the drawer at the top right of the washer. then remove the drawer assembly and flip down the upper section of it by releasing all the clips. then prize of with a screwdriver. it will then become obvious why it leaves the conditioner behind. it will have a black sort of mould blocking the waterways. clean this and replace all the items in order. be careful when you re-connect the large rubber drain tube undeneath make sure it is engaged fully. i got my son to hold it in position while i clamped it back in. hope this helps....adam howell swindon
Oct 13, 2008 | Washing Machines
Electrolux 15 Turquoise Sky Pedestal EPWD15TS Logo
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
