Related Tags:
This problem should be removed because:
Problem with Samsung T220 22" Widescreen 2ms Gloss Black LCD Monitor 22 inch
SyncMaster T220 Switches back and fourth to analog/digital
My Syncmaster T220 was purchased about a half year ago and used even less than that, what happened is about a month ago the monitor would switch back and fourth between analog/digital and just keep doing that over and over.
I've used the Syncmaster software, checked all wires and made sure my divers are up to date. Nothing is working, had a friend try it and it does the same thing.
I don't know where my receipt is so no chance in taking it back. Is there anything i can do?
Suggested Solution (3)
First of all plug another monitor to the VC on your PC and do the same for the SamSung"I over heat"SyncMaster2 053BW. Reply!
I had a similar problem, the monitor was going blank once in a while (since I don't have a VGA input), so I switched the Auto Source feature to
"Manual" and so far it's working fine for the past 2 days, if I run
into the problem again I'll update this message.
On the side
panel of your monitor, press the top button to access the menu, scroll
down to the setup menu (by pressing the 3rd button down on the panel),
press the 4th button down to enter the setup menu, scroll down to "Auto
Source", use the 4th button to select, "Auto" & "Manual" are your
choices.. press the 2nd button down to select "Manual" then the top
button to exit the menu(s).
This monitor is set up to be able to
do multi display with the software included. Utilizing both Digital and
Analog signals. I'm not using this feature so I'm not sure how
switching the Auto Source off will affect the performance of this
feature.
You screen "LCD" is broken , need new lcd panel. Very expensive
Source: Dark vertical stripe on monitor
monitor switchs between digital and analog
my SyncMaster T220 monitor just started 4 days ago randomly beginning to switch constantly between Digital and Analog.. the only way it stop...
Dark (but you can see through it) vertical stripe about 1.5 inches wide and full lenth down the SyncMaster T220 monitor. Showed up about 2...
My samsung 19
My samsung 19" lcd tv comes on for a few seconds then the screen goes black.I can still hear the sound.Any ideas thanks Mine does the...
Black on the montior is bugging the monitor out
I have a T220 and a 8800 GTS 512 vid card. When i have too much black on the page the monitor craps out and goes black. Then it starts going...
I have s samsung monitor T220 and will not come to
I have s samsung monitor T220 and will not come to show that my computer is connected, I have a message on the screen that says check signal...
Tips for Helping myfamouspolk With Their Issue
- Give detailed step-by-step instructions
- A picture or video is helpful
- Use plain language not industry jargon
- Check spelling & punctuation
Add Your Solution
samsung t220 lcd monitor black screen.
Was playing a game on my computer and then the monitor just turned off and completely died. No power at all. It used to...
power button (touch-sensitive button) don't...
Turn on is not possible, power button don't run
touch-sensitive button : power button to start...
touch-sensitive button : power button to start don't run
My samsung T220 monitor has
My samsung T220 monitor has suddenly started to go off and on repeatedly . i dont understand what's the...
See all Samsung T220 22" Widescreen 2ms Gloss Black LCD Problems
Related Topics
Fix-O-Meter
266
266 people viewed this problem
- 0 people are following this problem. Be the first!
Top Samsung Monitor Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
This is how it went for me..I have a Samsung SYNCMASTER 2053BW. I leave my monitor on and let it hybernate when I shut down PC. I'm 3 months outside of my warranty. Two weeks ago something started happening. I boot PC and video doesn't come up for 10 minutes, and when it came up it worked perfect. VC/Monitor/MB?? It became 20 minutes and ...now..I have the analog/digital box in top left screen, power light on monitor flashing, no menu available on monitor and none of the other buttons work for anything. I test the monitor on Laptop..nothing(same as above)..I break out the old(working) monitor from deep within the closet. Plug it in and I'm up and running. So...
HOW TO OPEN A SYNCMASTER 2053BW
NO SCREWS!!! Assuming that the stand mount has been pulled out..The seam around the screen frame is where you start. The frame has the prongs, the back cover has what the prongs slip over.The frame is coming off first! I got the side to open by finger, then used a small standard screwdriver to pry ever so gently(lifting frame from rearcover). Leave the power button assembly on the frame, pull wire only a little to relax any tension..you get about 3/4" in extra taped to panel. The hard part is done.;) Still holding the frame...Now lift the panel (where the power button assembly wiring goes under panel) with the power housing that is under it as a whole and you will see where the powerbuttonassemble detaches.Remove frame. Now..holding edges of panel into back cover, lift and flip the whole thing over and place panel face down on a perfectly flat surface..a towel on my desk works. Lift and remove back cover.Your now looking at the back of the board housing. The ribon is simple, on the panel end of the ribon, squeez the outer clips together and slide it away against the panel..The secondary tin plate is removable, two clips super close to where the sets of wires come around the housing and into the panel.Unhook the 4 plugs(pink inside/blue outside)...Now lift the power housing off of the panel. The big board has the power. One screw to remove a ground plate first. Two screws to remove power board. Pics from phone.
Reassemble but DO NOT re-snap the frame into place....yet... Test it! There is a reason the caps got hot in the first place, therfore it has a good chance of happening again. This is not fullproof...but.....mine has been on now for close to 6 hours with no glitches whatsoever. So I have resnapped mine back together. I hope you can too.
I must also add that this is one of the best producing monitors I have ever seen...in 60hz. The clarity is top notch. If you purchase one get the extended warranty. FYI...I paid $4.00 for those caps.
