Question about VDO 2003 Oldsmobile Alero Blower Motor
My blower is barely moving on 2003 oldsmobile alero
I can hear the motor turning if i listen closely but it doesnt matter if its on low or high it still barely turns
  • 3,799 Answers
This is a classic sign of a failed coil. You will need to replace the blower motor.
Posted on Jul 28, 2013
Testimonial: "i want to thank michael green for the info on my blower motor problem.thanks michael"
I have a 1979 oldsmobile delta88 for several years.My blower motor stays on and blows at a constant low speed and doesnt blow much on high.I already replaced sll components except for thewhole a/c switch...
REPLACE BLOWER MOTOR RESISTOR. IF YOU GET ONLY ONE CONTROL SPEED.IF YOU HAVE ALREADY REPLACE BLOWER MOTOR RESISTOR.BLOWER MOTOR CONTROL SWITCH BAD. REASON BLOWER STAY ON ALL THE TIME.FAN BLOWER MOTOR RELAY BAD.
Aug 25, 2011 | Oldsmobile Delta 88 Cars & Trucks
2003 Alero, heater blower only works on the two highest position?
The blower motor is located on the passenger side of the vehicle next to the blower motor. Run the fan on high and listen for the blower motor location if in question. The resistor will be mounted into the heater case and held in by two screws.
Good Luck
Mar 12, 2010 | 2003 Oldsmobile Alero
Heater control only works on high and fan doesnt blow heat thru the vents sounds like its a fan being blown in the wind.
100%: Heater Control on High Only?
This is the Blower Motor Resistor that needs to be replaced. It is located adjacent to the Blower Motor.
Jan 28, 2010 | 2000 Oldsmobile Alero
I have a 2000 olds alero and first the back
It sounds like an electrical nightmare. The rear defrost and the blower motor are probably not related. The fact that the blower motor only runs on high is because the blower motor resistor is bad. I'm guessing the blower motor is just worn out that's why that quit. As far as the turn signal problem, not a clue there, maybe a bad ground somewhere or you're getting feedback from another circuit. Electrical problems are tough enough when they're right in front you, let trying do solve them via email. You need an electrical wiz for a mechanic.
Jan 04, 2010 | 2000 Oldsmobile Alero
Ac trouble
TSB #01262004 -- THIS IS A PRODUCT SERVICE MESSAGE REGARDING THE NEW PART NUMBER FOR THE HEATER BLOWER RESISTOR FOR CUSTOMER CONCERN OF THE HEATER MOTOR NOT BLOWING ON ONE UP TO ALL SPEEDS. *TT (NHTSA ID #10012980, JANUARY 26 2004)
I hope this will help you, Was thinking of the blower resistor that control the different speeds and most of the time they were recalls. Just go back to the dealer and see if your covered.
If not i'ld take a close look at the switch and then the Resistor and if you need to know where it is, just ask the guy's at the dealer. Most of the time it's not to far from the blower motor.
Good luck and hope you can save time and money.
Apr 13, 2009 | 2003 Oldsmobile Alero
2002 olds ALERO fan switch
u will need to change the blower motor speed control resistor, it is located near the blower motor in the housing.
Mar 17, 2009 | 2002 Oldsmobile Alero
Blower fan not working correctly
It is the blower motor resistor and is located under the glovebox behind the blower motor.
Nov 19, 2008 | 2003 Oldsmobile Alero
VDO 2003 Oldsmobile Alero Blower Motor Logo
49 people viewed this question
Top VDO Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a VDO Heating and Cooling Expert? Answer questions, earn points and help others
