Question about Craftsman 27cc 2 Cycle Crank Straight Shaft Weedwacker Gas Trimmer ()
Removing trimer head - Craftsman 27cc 2 Cycle Crank Straight Shaft Weedwacker Gas Trimmer ()
  • Plink-plonk
    Plink-plonk Jul 28, 2013
    Here is the link to the operators manual, you can save it to your computer as a PDF file.http://www.gobookee.net/get_book.php?u=a...
  • Craftsman Master
  • 1,807 Answers
Ive found a link to the operators manual, Its all explained on page 7. I'll send you the link :)
Posted on Jul 28, 2013
How can i remove the head from my trimer
There should be somewhere to stick a tool in to lock the shaft, then generally it removes in the opposite way it spins. Actually, note how it spins when you hold it, then flip it over and turn it in the same direction only it'll be upside down so if it spins clockwise when running, flip it over and turn it clockwise to remove it. It'll be pretty stuck on there most likely so be prepared for it to suddenly give and release.
Sep 28, 2014 | Garden
Hoe does the automatic line feed work on a line trimer
Richard the auto line feed works by bumping the head when the strimmer is running. If it's wound right the line comes out when you tap the head on the ground when on full running.
Jan 12, 2014 | Garden
I'm writing about cleaning the String trimer head of my 19.2 volt string trimmer. Is water from the garden hose nozzle O.K.?
i use WD40 to clean also spray head before use this keeps the head clean at least it does with my strimmer
Jul 02, 2013 | managemylife.com
Gas trimer runs however the cutter does not work
there is a rod on the inside of the tube that goes down to the cutter head check to see if it broke. Ryobi??
Jun 05, 2012 | Homelite Mighty Lite Lawn Trimmer
Trere are lines running up and down half way across the screne they are colorful.
Try to adjust the vertical hold trimer.In adjusting the trimer you look the screen while adjusting the trimer until the screen or picture back to normal.
Jul 04, 2011 | Hyundai HPT-4250 Television
Is it possible to fit a brush cutter head to a ryobi rbc30cet line trimmer
Is it a straight shaft? If so measure the inside of the blade and fit the arbor to your trimer.
Aug 17, 2010 | Ryobi Garden
Have a troy built TB575SS trimer. Pull cord has lost tension and cord is just fully hanging out. How do I I take unit apart to re-adjust cord tension?
The starter recoil spring may have possibly broke or the rope is hung up somewhere on or in the pulley. A lot of these units are assembled using Torx (Star) head screws and disassembly requires a couple different sizes to accomplish. Take your time...you will see the screw heads, but reloading a starter spring for a trimmer is a little tricky and you may need help doing so, but you can fix this yourself.
May 29, 2010 | Troy Garden
The motor works but the head does not spin
Either lawn material is binding the head to the base or the reduction gear is broken, stripped, or melted. The motor's steel gear or belt drives the plastic gear which drive the spool. If claning doesn't help, then there is no user repair. The parts are generally not consumer available.
Apr 03, 2010 | Black & Decker 14" Grass Hog Xp...
HOW TO GET BRUSH CUTTER OFF FS 55
Look at the top of the head (where the brush cutter is) find the small hole about 3/16 diameter. Insert an allen wrench or a large nail, or anything else that will fit in the hole almost the same size as the hole. While putting a little downward pressure on this "tool" turn you blade slowly by hand until you feel the tool slide into the locking slot, this will hold the blade from turning. Keeping it in this position, take a socket and ratchet on the nut that is holding the blade and loosen and remove it. THE NUT HAS LEFT HAND THREADS SO TURN IT OPPOSITE OF WHAT YOU NORMALLY WOULD TO REMOVE IT!!!!
Sep 07, 2009 | Garden
How do I change the Battery in My Norelco T3000 Beard Trimer
Remove Phillips head screw at bottom of trimmer. Separate body in two being careful to notice how on/off switch is assembled. Unsolder the ni-cad battery from circuit board. Install new ni-cad battery of the same physical size that has solder tabs on it and solder it to the circuit board. I used a ni-hi (nickle metel hydride) instead of ni-cad which had different charging requirements so I limit charge time to no more than 16 hours for a discharged battery. It had been working fine for over a year. Don't forget to apply a few drops of light oil to the cutting blades to extend cutting life. Replacement blades are about $30.00
Jul 06, 2009 | Norelco T770 Beard Trimmer
Craftsman 27cc 2 Cycle Crank Straight Shaft Weedwacker Gas Trimmer () Logo
66 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
