Question about Bissell 1697-7 Powersteamer Pro Deluxe Vacuum
Bissell 2x steam cleaner
I am experiencing the same problem (will not pick up water)and its very frustrating. When the machine works, it clean really well. I almost threw my steamer in the trash. Any suggestion to correct the issue, will be greatly appreciated.
  • Anonymous Nov 19, 2008
    I have the same problem. works great when working but will not **** up any water.
    President:
  • 1,673 Answers
Usually when it won't pick up water is because the bucket isn't seating all of the way down. Or there is a window gasket or seal, it goes bertween the clear window and the bucket, if it is missing, yiu get no suction thru that clear window. The other is on the one side of the lid for the bucket is a filter, is it clean? And the seal that that filter sits on, is it sealing? If the moror is running, it is sucking, but any leak will cause it to loose that suction.
Posted on Jan 06, 2008
SOURCE:
Cleaned machine filled with water pushed botton but water will not come out
Hey Parker! I know how frustrating no spray can be.
Here is a quick link to troubleshooting steps to assist you:
http://www.bissell.com/FAQDetail.aspx?id=1122&cid=ccsocial
Mar 30, 2013 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell ProHeat 2X model 9500 will not dispense water
Not having spray when you need the machine to work can be frustrating.
Here's a quick link to troubleshooting steps to assist you.
Jan 04, 2013 | Bissell 9500 ProHeat 2X CleanShot Upright...
My Bissell Pro Heat Select 2X does not pull up the dirt from the carpet into the water. The water just slowly disappears. The first time I used it the water got really dirty. The very next time I used it...
Inside the plastic suction lid is a little red plastic filter that has to be cleaned out every time you use it because it sounds like your vaccum is not picking up all the hair and debri before you clean the carpet causing the water to be injected into the carpet and disappearing and not filling the tank with dirty water. Steve
Jun 06, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
We have a Bissell Proheat 2x steam cleaner; we can spray the water out, but it will not pick it up.
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101 ,,.
May 11, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
My Bissell Pro Heat 2X steam cleaner is not releasing the water
Have you tried cleaning out the small filterfrom the reserve tank? Also, check the tank/resevoir valve is operating properly, when you take it out to fill try to make water release from tank.
Apr 29, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
My bissell 2x steam cleaner is not picking up the water from the carpet. What do I need to do?
heatman101
vxbv
Jul 11, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Does not pick up the water after cleaning
heatman101
789iut
Nov 20, 2008 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell Proheat 2x TurboDoes not pick up the water after cleaning
heatman101
m,nb
Bissell 1697-7 Powersteamer Pro Deluxe Vacuum Logo
128 people viewed this question
Top Bissell Vacuums Experts
CJ C
CJ C
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
