Question about MGA Entertainment Toys
Instruction manual for Bratz Secret Safe
It is a Bratz Secret Safe with voice activation.
Cannot open my secret safe by justice
Reference: Paisley Electronic Push Code Safe
Item # 5661462
Purchased at Justice. May be one of the following design/colors: 1. Pink and black 2. neon green 3. tye-dye (all in zebra pattern, I believe)
To gain access to safe without code proceed with the following simple instructions:
Use a screw driver to access batteries on the bottom of the safe. Remove all three AA batteries.
WAIT AT LEAST TEN SECONDS before reinserting betteries to functional position. Replace screw. Key in default passcode "0000#" Safe will now be unlocked and upon opening you can reset passcode. Hold down the "*" and when voice prompted to "key in passcode" enter new 4 digit code followed by the # sign... HOLD "*" until completed code with "#" You will hear the voice command, "enter passcode" after each digit entered. [Press & hold "*" (1234) press "#" release "*"] Close safe and new passcode should be set and work properly. If not, enter default "0000#" and try to reset once again.
Feb 03, 2014 | Toys
Phillips 696 recorder manual
Turn on the Voice activation switch and the volume control adjusts the sensitivity.
Nov 16, 2011 | Audio Players & Recorders
I nedd instructions for the Bratz ATM bank
Unfortunately, the Bratz Kidz ATM has been discontinued by it's manufacturer, MGA Entertainment. As such, the instruction manual is no longer available for download from their Product Instructions page. This toy has not been produced or supported by MGAE for at least 2-3 years now.
Mar 02, 2011 | MGA Entertainment Be-Bratz Webcam
Lost code sheet for bratz computer for games ect
if you go on your products website and type in make and model the option to read or download instruction manual is available on site
Sep 12, 2009 | MGA Entertainment Bratz P4F Laptop
Nutool sf20 safe
I need an instruction Manual for a Nutool sf20 safe
Jul 15, 2009 | Computers & Internet
I cannot open my sons Science Museum Lock N safe Money Box
here is the default code, start by pressing mode so you go into code mode, tehn turn the dial left to 0, then right to 1, then left left 0,then right to 3 then turn dial right and your safe will open!!!!!
Jan 15, 2009 | Toys
Bratz talking alarm clock
I purchased a Bratz talk back alarm clock for my daughter, however, she threw away the instructions.
Can you tell me how to work the clock to hear it talk back or to activate the talk back voices.
May 07, 2008 | MGA Entertainment Bratz Plugged In Talk...
Toys Logo
235 people viewed this question
Top MGA Entertainment Toys Experts
Andrew Taylor
Andrew Taylor
Are you a MGA Entertainment Toy Expert? Answer questions, earn points and help others
