Question about Electronics - Others
Roberts radio displays "Information not available"
My Roberts RD1 DAB radio refuses to play, just displaying this message, "Information not available" and the date 06 March 2002. None of the buttons seem to work except the on/off button, which just produces this message. This has happened with no warning, i.e. all worked fine until today. Any ideas?
SOURCE: Front Display Panel Not Responding
the cable is torn that connects the lcd to the headunit.
Posted on Jul 04, 2007
SOURCE: main computer display panel Audio estate A6 5 years old
There is a button on the bottom of your windshield wiper control arm. Push it once to turn on or off the computer display. Hold it to clear the current information. At the end of the arm is a "up/down" button for changing which info you would like to see (miles to empty, current mpg, etc.)
Happy driving!
Posted on Sep 17, 2008
SOURCE: CD player that doesn't play
I had the same problem.
I cut the orange wire which went into the black connecter block
and WOW I had sound...
brilliant
thanks a lot
Andy - North Yorkshire, England
Posted on Feb 24, 2009
  • 20 Answers
SOURCE: I purchased a new Matsui DAB Portable Radio
matsui was specialy made for curry's if you ring your local branch and ask for the phone number of there service dept and ring them i have found them helpfull in the past as only they have service manuals .sorry but i can't find the number
Posted on Jun 13, 2009
rteemon
  • 578 Answers
SOURCE: Grundig dab radio guadabr08 nearley new why does
what are you trying to accomplish
Posted on Jul 01, 2009
Where can I get a replacement off-on switch for my ROBERTS ECOLOGIC 4 DAB/FM PORTABLE RADIO? The mains light is on, but the radio doesn't work and I see that this is a noted fault of this model. Is it
If you cannot get parts from the manufacturer you may end up directly connection the wires to have the radio on continuously or installing an aftermarket switch.
Feb 04, 2015 | Roberts Audio Players & Recorders
"No disc" message while CD is in
either a dirty or bad optical pickup in the unit that reads the disc so it can play.
Jun 15, 2012 | Cambridge Audio Sonata DV30 Player
Hi - we have a Roberts MP53 DAB radio. When finished playing the cd we press eject with either the remote or on the unit and although it says eject on the screen it doesn't. After about 10 secs the visual...
Mine did the same at first. I turned mine upside down and pressed eject and that worked to get the CD out then let it warm up to room temp and all is well.
Jan 16, 2010 | Electronics - Others
I have a proline DAB 100 alarm clock radio, I went
I am finding difficulty to set the clock on Proline dab 100 fm
Jan 03, 2010 | Audio Players & Recorders
I recently moved my Legato Pure radio, now I have trouble tuning in the DAB radio and the display struggles to set the clock often flashing with a message saying it is wating for time to set. When it does...
Clearly, the DAB signal strength is poorer in the new radio position. Try moving it, even a foot or two can make a difference. Better still, use a roof aerial.
The display can be changed, even in standby mode - press the Display button to see the 3 options.
Dec 19, 2009 | Audio Players & Recorders
SONY XDR-S55DAB Stack at display : DAB WAIT
Solution seems to be do not buy small Sony DABs, or any small ones. I have the XDR-S56DBP and have same problem. Was also cursed with 'no ensemble' error. Even worse than the Pure one I had before which lost all of the DAB facility and now only functions as an FM radio. I had a good medium sized Roberts one, but power cable split and I can't find a suitable replacement.
Apr 28, 2009 | Sony Audio Players & Recorders
Changed battery on roberts r871 radio .time date needs to be set
hold down mode button until display flashes, change time with up/down buttons. Press mode button once to change to date use up/down to move through dates, the time display will show year you are in the further you press the up button the further in the future you will scroll. This radio holds date & day information depending on the year displayed. Leave flashing to time out after adjusting.
Apr 27, 2009 | Emerson Audio Players & Recorders
Tuning DAB radio
Just bought the same unit but the instruction manual was double dutch. After messing around for a while I managed to do it like this. Whe the unit is set to DAB, Press the Sel+/TU+ or the Sel-/TU- button on the unit (not the remote) until the DAB station displays and then press the Select CH+ button again on the unit. Wait a few seconds while the word "tuning" is displayed and that station should now play. To save the station as a preset do this. When the station is playing use the remote and press the PRG/MEM button once. Then press the number for which preset you want that station to be. The station will be saved. EG to save Radio 1 as Preset station 1, play Radio 1, Press PRG/MEM, then press number 1. After that whenever you press number 1 on the remote Radio 1 will play. Do the same with any other station you wish to save. To save station 10 press the 0/10 button on the remote. To save station 11 press 10+ then 1, 12 is 10+ the 2 etc. Good luck Dopeyemma
Dec 27, 2007 | Audio Players & Recorders
Electronics - Others Logo
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
