Question about Troy-Bilt 4-Cycle Curve Shaft Gas String Trimmer #41ADT41C966
Can not remove line reel, the knob just spins.
I have not changed the line read, when I try to remove the retaining knob it just spins. How can I remove the reel and head.
  • Troy Master
  • 1,807 Answers
I'll send you a link to the operators manual. To change the cable, simply unscrew the bump feed knob anti-clockwise.
Posted on Jul 28, 2013
Setting the drag on a model Crossfire 2500 daiwa spinning reel
Hi
To set the drag on the spinning reel you adjust the knob that holds the reel in place. The same knob you use to take the reel off to clean and oil. It will hold the reel in place and as you thighten it down it will increase the drag.
May 10, 2017 | Fishing
How do you set the drag on a model Crossfire 2500
Hi
Where do get users manual for Quantum BSP100PTSE spinning reel and set the drag
The drag is set using the knob in front of the spool... just tighten it until you can barely pull line out..(the bigger the line.. the harder you pull..and vice versa...)
Apr 22, 2016 | Fishing
Howtoseyupaspincastingreel
use 10# test line or heavier. use 3\8 oz lure or heavier. set magnetic control to "5". tighten small silver knob under the reel handle down until the spool will not turn when you push the thumb bar. loosen the same silver knob while you have the thumb bar pushed and adjust the knob tension so that the spool stops turning when the bait hits the ground. this is basic tuning for any baitcasting reel.
Jul 08, 2012 | Abu Garcia Pro Max Baitcast Reel
The line constantly comes out of the reel. I just bought it. Have not had an open face reel in years.
Your line is not taking the memory of your reel, therefore coming off trying to come to its original state. You could try braid fishing line, which has no memory, or go down on the pound test of mono filament line your using. First, before buying anything else you should try to tie your string to one of the eyelets and reel in until the line is pretty tight(tight as you can get it), and leave for a couple of days, it will start to take the memory of your reel spool. Hope this helped.
Apr 28, 2011 | Shakespeare Agility Spinning Reel 6825
How to I fix a spin casting reel?
You should be able to remove the spool by removing the knob on the front of the reel which also is the drag adjustment. With the knob off the spool should pull right off. Hope this helps you
Oct 18, 2009 | Shakespeare Agility Spinning Reel 6825
The Drag on my 750ss does not work what could be the problem?
This happens after you screw the drag too tight so that the plastic washer under the spool is pressed out. The fix is simple: cut excess of that washer and tighten properly.
May 30, 2009 | Penn Spinfisher 7500SS Saltwater Spinning...
Penn Spin Reel will not lock after casting
On the front of the spool there is a device to turn to set the drag. Torn it tighter and tighten it until slightly below the breaking point of your fishing line. It isn't a critical adjustment, it just keeps your line from breaking while trying to land a fish.
Nov 29, 2008 | Penn Gt Series Levelwind Reels 330GTi
Ryobi Trimmer
To install string in the Ryobi you do not have to disassemble anything: Line up the two arrows on the inner and outer reel, remove any excess string, cut two pieces of string about 10 feet, feed line in the side holes, secure line in hole where it comes out the bottom (it only takes about 1/4in. to do so), pull strings tight, then turn the inner reel counter clockwise to wind it. If it sticks a little just pull line a little.
To remove the inner spool in order to remove line that has broken inside, to clean the mechanism, or to perform other maintenance, grasp the outer reel and unscrew the bump knob counter-clockwise. Mine is often very tight and requires pliers to get enough leverage. While you are in there, clean the inner reel and the inside of the outer reel to improve feed performance. The shaft rarely needs cleaning. Do not lubricate. After re-installing the reel, add string (0.080") as described above.
Sep 09, 2007 | Ryobi 15" Electric Factory Reconditioned...
Troy-Bilt 4-Cycle Curve Shaft Gas String Trimmer #41ADT41C966 Logo
128 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
