Question about Garden
Echo SRM 210 6EHXS-0214EF LEAKS GAS - Garden
  • 666 Answers
SOURCE: fuel mix and manual for Echo SRM 4000
Go to www.echo-usa.com/pdf/documentation/SRM40005000edi_110107.pdf
Posted on Mar 28, 2009
moretons
  • 155 Answers
SOURCE: Lost eyelets Echo SRM-220ES strimmer
Hi these machines are made by allpower most parts you can obtain from your local echo dealer.
Posted on Sep 08, 2009
SOURCE: I have an echo weedeater srm 261t it will start and idle but dies when I give it gas.
nichodemus, you can thank the epa for this. All of the 2-stroke handhelds now come from the factory set up very lean. Almost every new 2-stroke that I have bought in the past few years has needed a carb adjustment, both on the low speed needle and the high speed needle. There are tamper resistant plugs over the adjustment screws on most carbs now. Unless you know what you are doing, the dealer will have to do this.
Posted on Apr 17, 2010
rycgl
  • 1545 Answers
SOURCE: My echo srm 2100 weedeater will start, but when I
There are an array of things that could be wrong, but most likely this is a carburetion problem.
For starters, make sure the fuel lines are soft and there are no cracks or pinholes in them. They tend to break down after time. I don't know the age of this machine, but a gasket and diaghragm kit may bring it back to normal operation. The parts in this little kit are easy to install and not very expensive. Another issue of note is there is a very fine mesh screen inside the fuel pump chamber of the carburetor that traps dirt and foreign particles. It is easy to access and clean, once you have the pump cover off. The internal parts of the carburetor need to be soft and pliable like the fuel lines to operate correctly. They dry out after time and need replacing. All these little carbs have this issue at some point in their usage. If you remove the carb, gaskets and diaghragms, try spraying all the holes with carb cleaner aerosol spray after cleaning the fine mesh screen. If a good cleaning doesn't help, then you probably need the gasket and diaghragm kit for that carburetor.
Posted on Oct 10, 2010
rycgl
  • 1545 Answers
SOURCE: echo weedeater srm 230 oi l for houseing what
See section 24 of your manual here. It has the information you want for lubing the flexible drive shaft and the gear-drive housing (if your unit is so equipped). This is a manual for the SRM230S model.
http://dl.owneriq.net/0/026b46f7-c706-4d99-8444-50bb35343992.pdf
Posted on Jul 24, 2011
I have an echo srm 265t and it leaks gas through the air filter. Also, it will run for a little bit and bog down without starting again. Any suggestions on how I can fix this?
first I would suggest adjusting the carb. this will show if it's either a bad carb or another issue like plugged exhaust...
Aug 23, 2014 | Garden
Have a ECHO gas trimmer SRM 2100 wont start. coulld it be the fly wheel
no not fly wheel maybe coil if not sparking check switch fist is on for sure or bad plug coil expessive try squrying some starting fluid in the carb check compression has to be above 90lb to start check and see if carbon has block exhaust port do all this first
Jan 20, 2013 | Echo 2-Cycle 28.1 cc Straight Shaft Gas...
If it doesn't turn over when you pull the rope it could be in the starter assembly or the flywheel where the starter pawls engage it. If it turns over then you need to check for fuel, spark, air and compression.
On my echo srm-2100 what length should the 3 lines be?
Check out the manuals on their website. They are all posted there. Or maybe check their FAQ section: http://www.echo-usa.com/faqs/
Jun 06, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Sep 08, 2009 | Garden
Fuel mix and manual for Echo SRM 4000
Mar 28, 2009 | Echo Garden
Garden Logo
85 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
