Question about Canon iP2700 Inkjet Photo Printer
Stripes in printing pictures in canon ip2700
The colored pictures has yellow horizontal stripes while printing pictures. pls help solve this problem
    New Friend:
  • 3 Answers
Your ink has most likely mixed together, I had to get new ink cartridges for mine, & clean ink heads carefully or you may get mixed ink again.
Posted on Mar 19, 2015
    Top Expert:
  • Canon Master
  • 12,223 Answers
Run the utility maintenance printer coming with the printer , for to clean the head from your printer.
God bless you
Posted on Jul 28, 2013
  • 97 Answers
SOURCE: pictures printing with stripes of color in some programs but not all programs.
Try new injet cartidges. If your printer has separate head and ink combo, replace the jets. The high quality mode operates the piezo jets at full power and lower setting can cause jets not to open as far. On some preinters, your particalar problem can be the result of too thin paper and the economy setting being used. Use 18lb or 20lb paper and see if it still does it on normal print mode.
Posted on Apr 29, 2007
SOURCE: my canon i860 is printing funny stripes on all colored docs
I am having the same problem. Does anyone know the solution to this one?
Posted on Oct 27, 2007
SOURCE: Printer will not use the magenta color
I had the same problem. It is most likely that your print head nozzles are clogged. Your choices are to attempt to manually clean them, or order a new print head from Canon.
Attempt the manual cleaning at your own risk, this doesn't always work. When it does not work, it means your print head is damaged.
To maually clean the print head. Printer cover up (so you can get to the cartridges and print head). Turn the Printer Off. Remove all the cartridges (I put each cartridge in a separate zip lock bag). Then flip up the lever and remove the print head.
Now heat (don't boil) distilled water (Iused a good sized cook pan and a plastic measuring cup to pour the water). Find a container you can soak the print head in (I used a deep alluminum baking pan). Pour the hot (not boiling) distilled water over the print head molding where the cartridges seat down (hold the printhead over your diposable alluminum pan). Then dunk the molded print head part into the pan numerous times. When the water gets dark change it (be carefuill not to stain the sink). Then slowly pour the hot distilled over the print head (opposite side from where the cartidges seat in). Eventually no ink will be in the water. Set the print head on a dry paper towel, and let it dry for 24 hours or longer. Reinstall the print head, then the catridges. If it worked, your true colors will return. It make take up to 15-20 photos to get all the ink catridges flowing-be patient. You can also just wait 24 hours after re-installing the cartridges, and hopefully it will take less photos to see the correct color match.
Never keep printing when a cartridge is low or out.
Print a few prints every week. Not printing for weeks causes the printheead and the ink flow to clog!
Good luck. I just recovered my S820 and my i900D using the above cleaning method. Like everything else, your mileage may vary! It cost me $1.29 for distilled water and about an hours worth of time!
Posted on Oct 20, 2008
  • 615 Answers
SOURCE: Canon Pixma yellow color problem
Either the ink you are using is not going to give the color you want, or you have print heads that are blocked.
Posted on Mar 28, 2010
  • 89 Answers
SOURCE: my canon ip2700 got problem
it is a service error. you have to reset your printer along with eeprom.
Posted on Jan 12, 2011
No red color appear when i print pictures
The Magenta print head nozzle maybe blocked.
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Apr 08, 2013 | Canon Pixma iP2700 InkJet Photo Printer
My canon ip2700 colour wont print
how to overcome my ip 2700 canon 006 error?
May 10, 2012 | Canon Pixma iP2700 InkJet Photo Printer
Canon ip2700 after refill of Black cartridge ink status still shows 'low' and print is very poor - breaks, incomplete - as ink running out. How to reset ink level, or to disable warning, and to get print...
For your ip2700, even if you reset your refilled cartridge, they are not going to be usable.
After 4~5 times of color refill, you will see e5 error that cartridge is not readable anymore.
So you need to replace your cartridge with new one somehow.
If you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
Apr 20, 2011 | Canon iP2700 Inkjet Photo Printer
The color of my PIXMA MP780 printer has problems
clean the head of the ink. then do the calibration for canon.
Jul 02, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Prints B&W in Horizontal Stripes
I received an answer elsewhere. Thank you.
Jan 26, 2010 | Canon Office Equipment & Supplies
Printer prints stripes through images
your printer needs to be cleaned. Use the cleaning mode in windows printer HPOFFICEJET
Sep 18, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Stripes printed on every picture
go through your printers software in your start menu and clean the heads.
Aug 21, 2009 | Canon PIXMA MX850 multifunction InkJet...
Pictures printing with stripes of color in some programs but not all programs.
Apr 27, 2007 | Canon MultiPASS MP730 All-In-One InkJet...
Canon iP2700 Inkjet Photo Printer Logo
139 people viewed this question
old marine
old marine
