Question about Measuring Tools & Sensors
Envirastation have model dws-170 outside temp not registering from the remote,no battery site.Have replaced internal batteries. please advise
freetek
  • 5568 Answers
SOURCE: outside temp not measuring correctly
I keep the outside unit of our in/out set under a coffee can shaded under a bench; one could argue the aesthetics but shielding it from wind and sun is mandatory otherwise one can get record temps pretty often.
The outside units generally transmit to the receivers only every few minutes to keep battery consumption down so moving them won't necessary gie you an immediate change.
Posted on Jul 15, 2009
rohdd
  • 293 Answers
SOURCE: Need instruction manual for EnviraStation
Here is a ink for the manual
http://www.simaproducts.com/support/files/FW_101_user_manual.pdf
You will need the free Adobe reader to open the file: http://get.adobe.com/reader/
J
Thanks for using FixYa!! I provide my answer for free as a public service - a 4 THUMBS rating and POSITIVE Comment is really appreciated for the FREE answering of your question.
LtCmdr Spock said: "An ancestor of mine maintained, that if you eliminate the impossible, whatever remains, however improbable, must be the truth."
Posted on Mar 06, 2011
SOURCE: I have a 433MHz cable
You have to push some buttons to tell the MAIN unit to scan, then put battery into the REMOTE, set channel, and hit reset through a little hole. And the MAIN should see it.
Posted on Sep 23, 2011
caroldon
  • 17130 Answers
SOURCE: no display for outside temp. after replacing batteries.
If the unit was workingg prior to the battery replacement, you must remove the battery and check on the terminals to the battery. Make that these are clean, the battery is good - test using a multimeter- and replace with the correct postion.
Now if the earlier battery had leaked it could have damaged the internal board and if so you need to open to check if the board is clogged with the battery leak. If so try and clean the board.
Posted on Nov 08, 2011
  • 42872 Answers
SOURCE: model 00754W4 does not sense outside temperature..new batteries have been placed correctly in both inside and outside units..noW what do I do?
A common requirement for this type of unit is to install new batteries in the outside transmitter first, allow time for it to begin "talking" to the inside receiver, install batteries in the inside receiver and check for results.
Posted on Dec 03, 2014
Envirastation model dws 170
Usually it is due to bad batteries or remote is too far away from home unit. Put units next to each other and press the channel button on front of the home unit. It will start a search to find the remote. If it finds it with a temp reading press the channel button again and you should hear a beep. Channel is locked in. If you still do not get a temp reading try changing batteries in both units and try again. Another try is to unplug the home unit and wait several minutes with no batteries in either house unit or remote. Replace batteries in remote then in house unit and plug back into power. Set all settings and see if you get the reading. If not try step one again. Weak batteries will do the same thing as well as remote to far away from unit.
Oct 06, 2013 | Measuring Tools & Sensors
I cannot find the owners manual to hometics envirastation dws-400 weather station, and need to know how to synchronize the outdoor temperature sensor with the indoor station readout (i.e. pressing what...
You must remove the batteries in the base unit, replace them, and it should work properly. You can press the Tx button on the back of the remote unit to verify the RF reception. To ensure it is working properly, place both units next to each other indoors and make sure they read the same temperature.
The manual can be found here. Refer to page 3 for more information.
May 03, 2011 | Health & Beauty
Need instruction manual for EnviraStation DWS-110. Basically cannot get wireless to transmit to inside unit. Have new batteries in both units. Pls advise.
J
Mar 06, 2011 | First Alert FWS-101 Wireless RF Weather...
Outside temp not measuring correctly
Jul 15, 2009 | La Crosse Radio Controlled Atomic Clock
My clock will not display the outside temp. after battery replace
Try replacing the AA batteries in the main clock/display unit - that worked for me, then you'll probably need to press the reset button next to the AA batteries, and maybe the reset button next to the AAA batteries in the remote unit - press reset on the main unit first. My remote is now registering and the red light is flashing, but I don't know how to reset to the correct time and date - it's been scanning for a while and found nothing...
Nov 21, 2008 | Audio Players & Recorders
Measuring Tools & Sensors Logo
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
