Question about Dryers
Frigidaire GLGR331AS4 gas dryer
Humming noise
dididsaythat
  • 291 Answers
SOURCE: Our Frigidaire GLGR341AS1 Does Not Start
see if you can turn the drum my hand... Makeing sure nothing is stuck in blower fan... if you can... sounds like motor my be bad
Posted on Oct 14, 2007
ginko
  • 19396 Answers
SOURCE: Frigidaire Dryer
If Dryer does not tumble , check the following:
" It won't tumble If your dryer doesn't tumble, check these:
Belt
Motor
Door switch
Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
Click here for a belt installation diagram.
Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it."Source Repaiclinic
Posted on Sep 08, 2008
TheMobilian
  • 8220 Answers
SOURCE: GE gas dryer hums, won't start.
broken belt? repair pix
Posted on Aug 15, 2009
richardsimpl
  • 230 Answers
SOURCE: my frigidaire dryer glgr331as4 is not spinning
Hi there
i read your report. OK try this tip. Open your dryer and spin it with your hand and its spins freely with no resistance then it's your belt is bad. Try this and let me know how it goes. Ty for writing to fix ya.
Best Regards Richard
Posted on Dec 03, 2009
heatman101
  • 43501 Answers
SOURCE: I have a Frigidaire Affinity dryer that shows
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 04, 2010
What part opens the gas valve in a gas dryer? I'm thinking the electric mechanism that triggers the gas valve to open. Is it the gas valve solenoid?
Not real clear on the "beep" sound but the hum is most likely the electric coil on the gas valve. If the unit is functioning properly and there is not smell of gas, the only way to resolve the noise is to replace the gas valve assembly.
Oct 01, 2017 | Frigidaire Dryers
Why gas Frigidaire dryer makes humming noise? will not start
Hello rodney flowers, thanks for your post!
From the information you have provided your Frigidaire dryer is making a humming noise and will not start. It could be a possible problem with your burner, igniter, or control panel. I would suggest performing a reset on your dryer and you can do that by either unplugging your dryer or flipping the household circuit breaker for roughly ten minutes. If that does not help correct your issue I would recommend having a professional technician out to perform a diagnosis on your washer. This will help avoid purchasing any unnecessary parts. Hope this information is helpful. -Matt
Jan 20, 2015 | Frigidaire Dryers
Why Frigidaire gas dryer will not start? makes humming noise
Rodney, if the humming noise sounds like your motor is running but the drum does not turn you probably have a broken belt.
Jan 20, 2015 | Frigidaire FGQ332ES Gas Dryer
Frigidaire model# GLER341AS2 humming noise
Hello friend, thanks for your inquiry!
I understand that your Frigidaire dryer, GLER341AS2, is making a humming noise. It could be a possible issue within your belt, motor, or the blower assembly. The manufacture provides to a dryer preventative maintenance kit part number 5304457724 and it costs $45.12 plus tax and shipping. I would also recommend contacting a professional to help avoid any unnecessary purchases. I hope this helps. -Matt
Aug 15, 2014 | Frigidaire Dryers
Gas Dryer making loud humming noise and vibrating. It just started doing it.. it was not a slow progression.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Nov 04, 2010 | Frigidaire Dryers
Turn the On switch for the dryer it just makes a humming noise
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 14, 2010 | Frigidaire GLGR331A Gas Dryer
My frigidaire dryer glgr331as4 is not spinning
Hi there
Dec 03, 2009 | Frigidaire GLGR331A Gas Dryer
Oct 13, 2007 | Frigidaire GLGR341AS Gas Dryer
Dryers Logo
Top Dryers Experts
