Question about Watches
Weide wh 1009
How do you reset the day/date led
How do i set the day ? Mine is stuck on sun.
I would try removing the battery for 10 minutes reinstall the battery if it doesn't help there's a problem with the circuitry.
Hope it helps thank you.
Jun 10, 2015 | Novelty 30M Waterproof Analog & Digital...
Intercrew LED watch, model ic3905. How do I set time and date?
Setting intercrew led time and date - Fixya
www.fixya.com/support/t14276175-setting_intercrew_led_time_date
Sep 8, 2012 - setting intercrew led time and date no instructions to set time and date on LED Watch by INTERCREW - Watches question.
Intercrew LED - YouTube
? 1:57
https://www.youtube.com/watch?v=bR9oGWDTwxs
Jan 25, 2012 - Uploaded by CoolWatchDanmark
Review af et af vores meget popul?re LED-ure. Intercrew LED. ... ????????
Dec 24, 2013 | Watches
I am looking for instruction manual for Weide sports watch WH902
Does exist a function to beep hour a hour in model Weide WH2309?
free-shipping-watch-fashion-weide-sports-watches-wh-2309-with-quartz-led-watch-for-watches-men-aq2i4dbsyqjd0wgvev1j31bb-4-0.jpg
Nov 10, 2011 | Watches
How do i reset date after battery change? or where can i cet a pdf file a9no calliber number on case or movement but its a timex perpetual with indigo light approx 30 yers old
to reset the date manually, pull the stem out to the second position to reset TIME; manually continue setting time until the date is on the correct day/date.
I had to do this to get back to the proper date when my timex was off by a week. Nothing else worked. 14 times around (twice per 24 hour day) and each time I passed "midnight" the date advanced.
blessings!
Mar 12, 2011 | Timex Watches
I got a president day date rolex, sometime the date jump twice in 1 day
Reset the time, day and date manually from scratch. Check for another 24 hours. If the problem persists that means there is interference between day and date wheels and in this case you will need watchmakers help, as to correct such a fault the watch needs to be disassembled almost completely.
Feb 24, 2011 | Rolex Oyster Perpetual DayDate 18kt Yellow...
Watch instructions for Armitron m721 (49/1009 GP) need to set time and date
Hi mandardani,
You can change the time and day of your Armitron watch by following the steps below.
1. Press the MODE button once. This will put you in the timer.
2. Press and hold down the MODE button. This will put you in the alarm set display.
3. Press the MODE button once more and it will put you in the time set display.
4. Use the ST/SP button to change the blinking portion of the time. Then use RESET button to move you thru the different parts of the time/date.
Hope it helps.
Thank you for using FixYa.
Jan 05, 2011 | Armitron 40/8125BLK Digital Sport Watch
Dkny 1350 how to change day
Hello. Contact DKNY customer service and request an instruction manual http://www.dkny.com/contact/index.php
May 25, 2010 | DKNY 1009 Wrist Watch
How to reset date on skagen watch, model 180LSLW
the stem pulls out three different heights, one is month, one is day, the other is time
May 15, 2009 | Skagen Men's - PERFORMANCE MULTIFUNCTION...
Setting my day date on watch
mcdevito75 here, The stem has 2 positions, first, set the day to 1 day before the day you need, now, slip a finger nail just under the stem and gently, gently lift the crown to it;s first position, set the DATe to 1 date before the date you need. Push crown back in, now pull crown out to set the date and time of day. Your watch is set and should change around mid nite
May 03, 2008 | Seiko SLL003 Wrist Watch
Watches Logo
65 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
