Question about Garden
Satoh tractor Hsve a 1980 Satoh S630 bull, When running fuel pour out from between trany and engine. There is no leakage from tank or fuel lines, only leaks when running. Engine runs fine. Is it the fuel pump, or could in come from the injectors
  • 24 Answers
SOURCE: 1991 S-10 Blazer replaced leaking fuel tank
Maybe the system needs to be bled, an air pocket somewhere?? Tey bleeding the fuel system.
Posted on Jun 10, 2009
nova2nv
  • 197 Answers
SOURCE: Engine runs but keeps going up and down in RPM model JD 445
Have had to replace fuel line in tank MANY times do to it being split just above pump.Try doing a fuel pressure test on the return hose from throttle body,should be close to at least 40psi.
Posted on Nov 14, 2009
mickey813
  • 472 Answers
SOURCE: Poulan Pro 20hp Tractor with B&S fuel flow problem
sound like to m e that your gas cap is bad if its not venting it will do that
Posted on Apr 16, 2010
SOURCE: John Deere 115 lawn tractor - won't start.
I have a 115 john deere tractor that runs but the engine will not run smooth I've put a new fuel cap on it a new pump and clean out the carb.
Posted on Aug 18, 2010
  • 13 Answers
SOURCE: I have a John Deere GX345 with a Kawasaki liquid
Sounds like you may have a problem with Choke adjustment, or perhaps a broken choke cable. Do you have a workshop manual?
Posted on Oct 25, 2010
My Craftsman lawn tractor will run for a while and then stop then sometimes after sitting for a while will run again. What should I check? I added fuel additive to gas just incase the fuel was bad.
Drain the fuel tank. Dispose of the gasoline responsibly.
Replace the fuel line between the tank and the carburetor.
Put fresh gas in the tank. See how long it runs.
While you're at it, change the oil and remove any debris from
the cooling fins on the engine. It may be overheating.
If it still doesn't run, you probably failed to replace the fuel line.
Trust me, this is part of good maintenance for these machines.
Sep 24, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Where can I find an owner manual?
no problem Neil.
This topic is about how to operate a A Mitsubishi MT 300 Tractor
Here's a site where you can BUY parts manual and the service manual, but I guess these are not what you want http://www.ssbtractor.com/tractor_manual_search.cgi?tractor_manual_make=Mitsubishi&tractor_manual_model=MT300
and
http://www.tractor-manuals.com/acatalog/Homepage__Mitsubishi_9.html
Here's another useful looking site (data only) http://www.tractordata.com/farm-tractors/003/1/9/3190-mitsubishi-mt300.html
but on this page http://www.best-used-tractors.com/manuals/Mitsubishi_Manuals.htm you'll find an 'operators manual' $44.95 about 3/4 of the way down. Note that this covers a small range of similar models (its described as generic)
Finally, you might try contacting Mitsubishi directly (by email or any other method) and asking them for help in finding an operator's guide I should try one of the many addresses given on this site http://www.mam.co.jp/english/products/ mam= Mitsubishi Agricultural Machine, a company or division of the Mitsubishi organization. The 'contact' details under the contact tab were not available when I tried.
There are are sure to be Mitsubishi owners clubs around which might help you with all sorts of things, one is http://mitsubishi-satoh-tractor.info/
Sorry, but that's the best I can do I assume you are in the USA
16.August.2014
Aug 16, 2014 | Cars & Trucks
Poulanprop fuel line routing diagram
in 1980 it is pretty much forward from fuel tank to fuel pump from fuel pump to carburetor ....the return line from pump to tank
hope it helps
Apr 06, 2014 | GMC C1500 Cars & Trucks
Looking for torque specs on a mistubishi diesel engine valve cover K3B-16094
Valve covers and pans are really light, you use inch pounds and the spec is 5 to 12 inch pounds.
Aug 11, 2012 | Cars & Trucks
Engine stopped. fuel cutoff. I thought I traced it to the underseat cutoff switch. replaced switch. still not starting. Will start and run on primed gas poured in carb. checked fuel filter(in line) good...
Pull plug andcheck and seeif it is Floded, see if plug is wet, and you can alson check and see if it is firing by grounding the the plug to the frame, with a ground wire and crak it over to see if you see it spark.
Sep 12, 2011 | John Deere 420,1020,2010,2020,2510,2520...
The engine is backfiring in idle, more so when driving, even worse when blade engaged. Could there be water in the gas?
Yes you could have water in the fuel. Drain it and save it. Unless it is over a year old. You can pour the good gass off the top of the water after it settles. The biggest job after removing the fuel line from the carburetor and draining. Then removing and replaceing the fuel filter, is removing the carburetor floar bowl and removing the water inside, then cleaning the bowl. After removal, be carefull not to damage the hanging float. Dont use carburetor cleaner on the carburetor after you remove the float bowl, due to the rubber o-ring. It can't handle the chemical, it will swell to the point of it being to large to fit back in, and you will have to replace. Next, leave the fuel line off at the carburetor and fill the tank to wash out any trash in the lines. Once fuel starts to run ( catch it in a oil drain pan or empty oil can), then install new fuel filter, then reinstall fuel line on the carburetor. Problem should be solved. I as a preventitive and cleaner/stabilizer pour in some sea foam additive. :)
Aug 11, 2011 | Craftsman 42 in. Precision Cut Plus 24hp...
Craftsman riduing tractor turns over but won't
If you have spark and compression, the only thing left is fuel.
Check that fuel is being deluvered to the carb (remove fuel line to carb and make provision to catch ejected fuel. Crank engine. Fuel should be pumped from the tank and out the open line at a good rate.
If this checks out (or there is no pump fitted, but there is fuel issuing from the pipe), check the electrical connector on the bottom of the carb. There should be battery voltage on this conection for the engine to run - if not - that's the problem.
If that checks out, the cut-off solenoid (fed by the connection you just checked) is suspect.
May 09, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Fuel problem?
Mukini does make inline fuel pumps. If there is a wire going to it then it is more than likely a fuel pump. I would replace the fuel filter, and air filter. I would also purchase a can of Seafoam cleaner at most auto parts stores. Pour in the correct amount in the fuel tank, as listed in the directions on the can. I have seen this work wonders on small engines with fuel problems.
Sep 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Mt180d hrdraulic problem
Since you are not saying which hydraulic oil you want to change I will give you a site where you can log in and they can help you with the oil and any problems you have had since you didn't say what the problem was. You will have to become a member but costs nothing except your e-mail address’s go to http://www.tractorbynet.com/forums/mitsubishi-satoh/101519-welcome-hydraulics-forum.html and you can find what you need.
Jun 19, 2009 | Mitsubishi MT160, MT160D, MT180, MT180D,...
Garden Logo
41 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
