Use zanussi zwq270
How to replaced the damaged washing dum bearing
  • 183 Answers
SOURCE: replace drum bearing
To complete this repair correctly and to prevent problem re occuring within months you must change the inner drum spider at the same time as the bearing kit, otherwise you are wasting your time, to complete the repair if you have not done one before will take you aprox 1 to 3 hours depending on space available and practicle ability, here goes, remove lid and outer case from machine to do this remove bolts on lower back and two side bolts (under small white covers) remove bolts along top edges both sides on top of macnine, remove cabinet, remove motor, remove hoses, remove heater and thermostat wires, noting location for refitting, remove suspension leg pins and lift outer drum assembly complete fron lower frame, split two halves of outer drum by removing bolts around centre seem, split drum in two, remove drum pully, refit pully bolt and drift inner drum out having put nut back on drum spider thread to avoid flaring shaft, using hammer knock shaft through bearings, then using a chisel or similer object knock out bearings and seal, reverse process refitting new bearins and spider, make sure to replace centre outer drum seal, as these are prone tro leaking I suggest you also seal with a layer of clear silicon, and problems contact me again, not really a job for a novice. Good Luck you will need it. Regards Advisor
Posted on Aug 30, 2007
  • 54 Answers
SOURCE: Zanussi FJS 1197W washing machine main bearing
sorry you will need to remove drum
Posted on Feb 14, 2008
cbaroni78
  • 44 Answers
SOURCE: replace washing machine bearings
It is a very involved process with the tank having to be extracted form chassis. There is really no step by step instructions for this, but most reports say it is not economical to do this yourself. There may even be restrictions in your zip code. You should hire a technition to do this and the job takes about 2 hours.
I hope I was able to fixya problem and I wish you the best with this.
Posted on Oct 19, 2008
  • 16 Answers
SOURCE: Zanussi IZ12 bearings gone & plastic fragments in drum
Probably all parts inside drum is ok.Heating element is the only damageable item and a sensor.Changing bearings you must separate the drum, all screws in middle of drum must out and then bearing and zimmerring can be changed.Jan
Posted on Feb 15, 2009
  • 636 Answers
SOURCE: I have a Zanussi FJS1397W Washing machine and need
try this site it is called manuals online
Posted on Jul 25, 2009
Replacing drum bearing on a ZANUSSI FJS 874 front loader ?
This is not a simple job, it can be fine but requires the complete disassembly of the machine to change the bearings, there are 2 bearings and a seal that require replacement, I can assist in guiding if you wish to do so, it takes around 3 hours total to strip and rebuild.
Jun 16, 2016 | Zanussi Washing Machines
Can I replace drum bearings only or do I have to replace the entire drum?
if you can remove bearing with out damaging drum shaft, bearing only needs replaced
Jan 23, 2016 | Zanussi Washing Machines
Lg tromm wm1812cw dum makes load noise when spinning
LOUD NOISES IN MACHINE;
LOT OF THINGS TO CHECK, THE BELT LOOSE OR WORN, THE CLUTCH, THE TRANNY, THE BEARINGS BOTH TUB SEAL AND BEARING, THE REAR DRUM BEARING,
THE DRIVE PULLEY- If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
THE TRANSMISSION, THE MOTOR COUPLER, THE MOTOR DRIVE BEARINGS,
THE DRIVE MOTOR- If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
Jun 15, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Zanussi aquacycle 1200
Sounds like the bearings have collapsed. If you are intent upon doing this yourself check out How to replace washing machine bearings on youtube.
Sep 13, 2013 | Washing Machines
My machine has been making a noise while spinning and now seems the dum wont go ound?
Sounds like the main drum bearings have siezed up.
If it was noisy before stopping and the noise has been getting worse, then It wikk be the main bearings.
This is a major repair to undertake, and if the washer is more than 5 years old, I would seriously consider replacing it.
Dec 19, 2010 | Zanussi IZ161S Front Load Washer
Noisy drum, grinding sounds when the drum is spinning
Hi
The grinding sound is because of damaged or broken bearings.
You will have to see if the motor rotor bearing is damaged or the drum bearing before you change anything.
Regards
Berry
Feb 07, 2010 | Zanussi FS1155W Front Load Washer
Feb 15, 2009 | Zanussi IZ12 Front Load Washer
Washing machine noisey on final spin
this isn't a problem usually every washing machine is very noisy on a final dry its normal
Oct 15, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi aquacycle 1000 washing machine spin problem
this is possible due to a bearing collapse or bearing spider broken. this causes drum pulley to be out of line and the belt comes off
May 29, 2008 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
