Question about Garden
Northstar Pressure washer starts and runs but dies when throttle is opened up
Its a Northstar pressure washer. It starts and runs at half throttle but when I open the throttle up all the way, the engine dies.
    Sergeant:
  • 429 Answers
Is this a v-twin engine or has the unit been stored for quite some time with fuel in carburetor.inspect fuel jet and tube for restriction.
Posted on Aug 05, 2013
picatudo
  • 239 Answers
SOURCE: NO PRESSURE FOR BLACK AND DECKER PW1400
the pump went bad
Posted on Dec 28, 2008
jj505
  • 195 Answers
SOURCE: pressure washer won`t pressure up
Have you tried adding 30 wheight pump oil,under 1 qrt usually
Posted on Mar 19, 2009
  • 10 Answers
SOURCE: pressure washer stalls out when wand nozzle is released
common for not starting unless trigger engaged as you are turning the pump as well as engine creating pressure,as for stalling pump has unloader valve which is probably in need of grease(use good silicone grease)this allows water to ciculate when trigger released.
Posted on Apr 20, 2009
  • 3 Answers
SOURCE: Karcher pressure washer with Honda GC160 engine only runs on chok
You need to remove the carb bowl, then with a small flat screwdriver remove the jet. ( on the side, at the bottom of stem.) take a small wire or toothpick and clean the gunk out of the jet, reassemble and open fuel valve, start, and pat yourself on your back.
Posted on Aug 04, 2009
  • 151 Answers
SOURCE: Pressure washer with Honda GX160 5.5 HP OHV-Starts easily but...
what about the linkage between the governer and the carb. Is that working and not binding?
Posted on Dec 24, 2009
Can i run plus gas in my washer
I'm not sure what you mean.
I think you are asking if your power washer needs oil mixed with the gas.
Does your machine have a oil reservoir below the engine?
If there is a place to put engine oil, then your engine runs on ordinary gasoline.
The pump oil is SAE20 or SAE30 non-detergent motor oil > oil comes up half way inside box.
The engine oil is 10W30 motor oil > oil comes up bit more than half way on dipstick
Oct 21, 2010 | Northstar Pressure Washer 3000 PSI
White smoke. when it won't start, raw gas comes out of the exhaust GS190 honda Karcher 3000 PSI
Sounds like it's flooded. Close the throttle and open the choke if equipped. Pull it through a few times and then open the throttle a bit.
May 24, 2010 | Northstar Pressure Washer 3000 PSI
My pressure washer starts fine but after you run
HAVE GX390 RUNS ON LOW IDEL THAN DIES ON HIGH NEW GAS
Feb 20, 2010 | Honda Pressure Washer PSI 3000
Water leak
bypass valve is shot or stuck in the "open" position
Jun 15, 2009 | Northstar Pressure Washer Turbo Nozzle
Honda GCV160 5.5 on a pressure washer runs only intermittently
The problem is the plastic float in the carburetor, it's not adjustable and after sitting up with gas in it it distorts. Save yourself the trouble and buy a new one, you can get them online for $15-$20.
Mar 17, 2009 | Campbell Hausfeld Garden
Garden Logo
81 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
