Question about Whirlpool WMH32517AT 1.7 cu. ft. Over-the-Range Microwave Oven with 300 CFM Venting
How to change position of the venting fans - Whirlpool WMH32517AT 1.7 cu. ft. Over-the-Range Microwave Oven with 300 CFM Venting
    Top Expert:
  • Whirlpool Master
  • 12,223 Answers
See the diagram attached. God bless you
how to change position of the venting fans - 182768ad-8a8a-4829-b532-55ae5f91887b.gif
Posted on Jul 28, 2013
How do I change my MMV4205BAS to vent (recirculate) out of the front vent instead of the top vent.
Paul, if you look on top of the microwave before you install it you will see where the fan is located at the back edge. There should be 2-4 screws that hold it in place. Remove the screws and pull the fan up and out of the microwave and rotate the unit 90 degrees towards the front of the microwave and put it back in and replace the screws. That should be all that you have to do to get it to vent out the front.
Jul 29, 2014 | Maytag MMV4205 Microwave Oven
Vent fan filter??cleaning,etc does not seem to pull air out as it runs
If this is a new installation, or if this ove is new to you, the following may apply: on some ovens the vent fan can be flipped to either exhaust air out of the house, or re-circulate it. Could it be in the wrong position? You would have to take the oven down to determine this.
May 25, 2014 | GE JVM1653 Microwave Oven
Mmv5165bas vent fan will not stop running
Check to see if there's a relay providing power to the fan. If there is, the contacts might be sticking in the closed position. Assuming that this is an over-the-range unit, disconnecting the vent fan completely might not be a good idea as heat/steam from foods cooking on the range would more likely damage the microwave.
Apr 29, 2014 | Microwave Ovens
I've purchased the Whirlpool Model #: WMH73L20AS microwave and the venting fan not working (well). The intake under the microwave into the filter can be barely felt, but on the top part of the microwave...
I just returned mine.... I had 7 (SEVEN) service calls coming out for it.. and they tried everything to stop it from overheating...and shutting off... and finally after 4wks we called it quitts. its a venting design problem... inside the unit...
Aug 17, 2013 | Whirlpool Microwave Ovens
How to change the inside bulb in a ge spacemaker microwave that has a top vent fan
My Spacesaver bulb replaces from the top. You have to remove 2 screws that hold the upper vent cover. W/ cover off you will find a phillips head screw about the center that holds the bulb cover. Remove the cover screw & lift up & remove the cover, then replace the bulb, the cover & screw then put the vent cover & it's 2 screws back. There may be some variance but they are all similar.
Mar 16, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
Exhaust fan direction
You can usually recongure the outlet on the vent to just vent into the room,but if you aren't going to use it,not an issue.
Dec 18, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
JVM1790 Microwave GE-Draws air from bottom and top vents
1. You have to have exhaust pipe to connect m/w vent and this pipe has to be free from obstruction.
2. If it already connected and good, but air come from vent bar over door, then blow motor on top of the m/w was installed in wrong position ( motor has 2 -3 position depends which way air coming out up, back or front).
3. In this case you have to remove m/w from installation and change motor position.
Dec 10, 2008 | GE JVM1490 Convection/Microwave Oven
Fan vents
Most microwave oven fan systems can be rotated for either back or top venting.. This can be done by removing a few screws and rotating the blower housing to the position you need and screwing it back in place.. Hope this helps..
Aug 30, 2008 | GE Microwave Ovens
Concerning Microwave oven Model MH2175XS I am following the installtion instruction phamplet to change the vent fan from inside circulation to outside by removing the two blower screws on the back and...
Looking at the pamphlet, it sounds like you're doing everything right.
It sounds like something is a little bent or out of alignment making it stick.
Maybe you can take the tip of the screwdriver, and push against the motor assembly a bit to loosen it?
Aug 11, 2008 | Whirlpool Microwave Ovens
Whirlpool WMH32517AT 1.7 cu. ft. Over-the-Range Microwave Oven with 300 CFM Venting Logo
23 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
