Question about HP Computers & Internet
My computer sounds like a power generator
My computer is making a lot of noise as it runs!what can i do to stop this?
  • 221 Answers
Is this a laptop or a desktop PC? The two common parts of a computer that make noise are the cooling fan(s) and the hard drive(s). Is the noise caused by air moving, like a hair dryer? or does it sound mechanical like a grinding noise?
Posted on Jul 28, 2013
Pump makes a humming sound but will not run
Don't run it hot or it will stop working.
Sounds like start capacitor has gone bad.
Copy following link for motor troubleshoot resources:
http://waterheatertimer.org/Color-codewire.html#motor
Add a comment
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
May 27, 2013 | AO Smith Centurion 1081 2 Hp Standard...
Screeching sound-Honda eu2000i
Sounds like a bearing has failed or something has gotten inside the generator or engine area where it spins and is now rubbing against it. There is a bearing at the far end of the generator from the motor and it is most likely to be where the noise is coming from. Best to repair it before it seizes and wears out parts you don't want to have to try to find!
Oct 30, 2012 | Honda Eu2000i 2000w Generator
My 1998 grand cherokee makes a very loud noise from the muffler, it sounds like a gun shot, shakes and then stops
Didn't you go for a road test with the mechanic along
Why didn't the repair shop resolve?
Sep 19, 2012 | 1998 Jeep Grand Cherokee
Im using a behringer ucg102 guitar/usb interface, im getting a very bad hum/hiss.. i've tried 3 different guitars and multiple jacks. im not running any guitar effects yet, i've removed the...
Try this using a differeent computer. Some computers generate a lot of digital noise. Also use a lot of gain from the guitar to improve the signal to noise ratio.
Jul 23, 2011 | Behringer energyXT2.5 Plus Portable...
Portable generator head stopped making power
portable generator head stoped making power engine runs fine sircut brakers are fine
Mar 16, 2010 | Pramac Electrical Supplies
My fan makes so much noise especially when i play video.Can someone help
The problem with fans is there really isn't much you can do with them. Normally they begin to make noise as the bearing assembly begins to wear, or it might just need to be cleaned. In either case you need to crack open the case on your laptop, then you can inspect the fan. You can try cleaning it at that point, but usually its easier just to replace it. The reason why it makes more noise when you play videos is because video media requires more system resources to run, which also generates more heat. So, while you have your laptop open you may want to check your video card (which should also have a fan) and make sure that its clean. A dirty video card will **** out a lot earlier than it should.
Jul 25, 2009 | Acer Aspire One AOA110-1588 Notebook
Generator started, ran briefly, then stopped sending juice
crclarkphd has a problem that sounds like a brush failure. The clunking noise was likely the remainder of the failed brush getting knocked around inside the back end of the generator so you need to take it apart and inspect things closely. Here is a link to a general solution I posted some time ago that may be of help.
Guest jj has a fried breaker in one leg of the 220 outlet. Even though it doesn't look tripped it's failed, check it with an ohm meter.
Regards,
Carl
Feb 18, 2009 | Coleman Powermate Powermate 5000W...
Hp compaq dc5000sff cpu fan sounds like a jet taking off
Not sure how long you have had the Desktop. However it will be one of two things. If it used to run quitely and now is making lots of noise then immediately take it to be replaced. Fans on power supplies cannot be fixed. If it should stop completely then the heat that builds up in your desktop could damage your components. Second, if it is fairly new and has always sounded that way then you are ok. Yes, there are some fans that are very loud, again you can have it replaced. They sell "quite fans" now that make no noise at all. But first and foremost if you start having problems like unusual reboots, lock ups, etc then your computer is getting overheated and the power supply which houses the fan needs to be replaced. Hope this helps.
Dec 24, 2008 | Computers & Internet
Computers & Internet Logo
63 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
