Question about Hoover U5753-900 WindTunnel Bagless Upright Vacuum
Hoover Wind Tunnel 2
Purchased new in December 2006. The Lifetime Hepa Filter is getting clogged, it does not appear to be rotating
  • likeitclean Jun 01, 2008
    My cylindrical filter also gets clogged each and every time I use the vacuum. More debris ends up wrapped around the filter than it does in the dirt cup side. I just replaced this filter to see if that would help, but it is exactly the same. I cannot find clogs anywhere, and the screen has been cleaned. My vacuum never used to do this. Not sure what else to try!
  • mamabd Nov 25, 2008
    I think this twin container bagless system is VERY messy to clean. I have to do it before I start to vacuum, so I can clean up all the "spills" it leaves behind.
    I use a plastic grocery bag and insert the dust container, turn it upside down,but the cat hair and dirt don't just fall out - so in trying to remove them manually, everything just gets all over.
    It does a great job picking up the dirt and hair, but getting rid of it is a pain.
  • 126 Answers
The filter for the U5753 does not rotate on it's own. There is a knob on the lid of the dirt canister to rotate before you empty the container, but it does not rotate automatically. If the filter is getting dirty quickly, it could be a result of very fine dirt going through the pre-filter screen and blocking the filter. You should also check the filter UNDER the dirt container for blockage and also the exhaust filter on the side. These are both washable and must be bone dry before re-installing
The main filter cartridge is a long cylindrical style and is coated with a teflon material so that all you should have to do is tap the filter lightly to dislodge any dirt. You can wash the filter by running warm water over it and using a SOFT brush to clean the surface. This filter must be BONE DRY..... before re-installing.
By the way, the lifetime filter is not lifetime. It should be replaced every two years, under normal use.
Posted on Jan 20, 2008
SOURCE:
How do I clean and with what,a Hoover elite lifetime hepa filter?
Hello! Please follow the instructions below to clean the lifetime Hepa filter on your Elite Rewind.
1. Press on the tab located on the side of the filter cover to remove.
2. Remove the HEPA filter and brush with the combination tool to clean or tap side of filter against a trash receptacle. Return the HEPA filter into the filter cavity.
3. Align tab on filter cover with slot. Press cover closed until you hear a snap.
Hope this was helpful!
Jun 09, 2014 | Hoover U5507900 Elite Rewind Bagless...
Hoover wind tunnel hepa filter wont stay in
The filter may be clogged. Try replacing it if it's over a few months old..
Jan 28, 2014 | Vacuums
Hepa filter does not turn on hoover wind tunnel vacuum model U6630900. It was working (turning) and I cleaned the filter and canister and now it no longer spins when the vacuum is running.
The part you refer to is not the HEPA filter. It's a very common misconception that that part spins - it looks like it when there's dust whirling around it. In fact, it does not spin - there are no visible moving parts.
Jan 07, 2010 | Hoover U6630-900 WindTunnel Bagless...
I have a Hoover TurboPOWER 7300 Windtunnel V2-belt change
1. Remove the 4 screws holding the bottom plate.
2. remove roller and old belt
3. install new belt on motor spindle first and then on roller.
4. pull roller, stretching belt, set into roller cavity.
5. turn roller by hand to center belt.
6. reinstall bottom plate.& screws
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Feb 26, 2009 | Hoover U5444-900 5100 Wind Tunnel 15 Inch...
Filter in Hoover Wind Tunnel Vacuum
Definitely not. Do not use water or any liquids to clean it. Te normal use life is 2-3 years keeping it maintained. You can clean it dry with the dust brush from your vac attachments. place in a plastic bag and tap it some folks even us an air compressor to blow out the impacted dirt. you will only want to use the Hoover brand, other generic brands dont fit as well.
Jan 17, 2009 | Hoover U6630-900 WindTunnel Bagless...
My hoover wind tunnel vaccum has a hepa filter that is supposed to be self cleaning but continues to plug up. it is not easy to get to and takes forever to clean it out so the suction is strong again.
do you have the SELF-CLEANING, rotating HEPA filter?
I just fixed my HEPA filter not rotating!!
It involves taking apart the vacuum HEPA area. All screws are the same size. There are a LOT of 'em. Really straightforward putting it back together too.
ok, once you take the HEPA canister area off the vacuum, careful with the wires! Unplug them from the controller board. You open up the HEPA chamber by removing more screws until you see where the motor that turns the filter is mounted on the side. Remove motor from the green chamber. Note where the washer goes. Once the motor is off, you'll see that the center hub that drives the HEPA filter is rounded out. What I did was jam little bits of aluminum from a pop can into the space between the circle and the square to force the walls back to square. I started by folding a little piece of aluminum over and over so it was about three layers thick. Jammed that in. That wasn't quite enough thickness so I shoved another piece with it. If you can find something that is about 4 times the thickness of a pop can aluminum, that'd probably work too. Slight wedge shape on the tip would help. Any sort of tiny shim.
To test your work, just put a couple of holder screws into the HEPA cannister housing, plug in the cover/switch, plug in the HEPA moter. Turn it on for a few seconds to make sure the filter turns. Then you can add more thickness to the hub or put things back together.
Apr 29, 2008 | Hoover U5444-900 5100 Wind Tunnel 15 Inch...
Hoover Z-400 - Hepa Filter
These filters should be changed at least once a year, they get clogged up and won't clean out. So I would try a new filter and go from there, make sure there are no clogs in the hose and down below where the dirt inlet is.
Feb 20, 2008 | Vacuums
Hoover wind tunnel vacuum cleaner shuts off during use
Check the inlet down by the brush roll to make sure it isn't clogged. If not and the hose isn't clogged, then probably the thermo protector (part #28382093) maybe bad. It is mounted near the motor. Could be motor Part #43576188. But I would suspect a clog in the inlet or hose, or the thermo protector has gone bad.
Dec 25, 2007 | Hoover U5444-900 5100 Wind Tunnel 15 Inch...
Hoover Wind Tunnel Problem
motor burnout. replace the motor or get a new vacuum
Dec 15, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover U5753-900 WindTunnel Bagless Upright Vacuum Logo
369 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Kirk Thompson
Level 1 Expert
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
