Question about Blast Zone Pirate Bay Inflatable Water Park
Water inside the walls
After a party for my 6 year old son, we tried to fold it up and discovered there is water inside the walls of the park. Any suggestions on how to get it out so we can fold it up and put it away?
Scion xa water gets into spare tire well during rain. a lot of it. gaskets look ok.
Best advice from i ever got from an old mariner was if the water gets in drill a hole and let it out ,then worry about it later .When i lived in the uk many years ago and the older cars then had rubber window screen seals it was common to get water leaks in the front footwells which caused rust and eventually the car to fail the inspection for corrosion in the floor so i used to drill a 3/8th hole either side of the respective floorpan by the seal so if the car was parked in the road pointing in one direction the water would tun out and when car moved and parked on the other side of the road it could run out that side ,Yes i know iam ancient and none of these things i done are relevant now and are frowned upon as you have to fit new parts but in my time i repaired things and welding up cars was everyday and stopping them from rotting afterwards was part of that.Including opening the rubber bung in the boot to let the water out and if no rubber bung drilling a hole .But then iam only a dinasaur now so ignore me
Mar 19, 2012 | 2006 Scion xA Hatchback
Hot water temp seems ok but flow has got slower. Does not appear to be a problem with the diverter valve, as it is not bypassing. (this valve was changed last year) Mains cold pressure is fine. Boiler...
The last sentence in the description of the problem, says it all.
I too, have had the problem, Tony. But, in addition, to the hard water,I discovered something that I didn't know. In our home's water system (our home is 30 years old) , someone prior to our ownership had installed a 6' section of galvanized pipe (possibly a repair). If you're not familiar with galvanized pipe and what hard water (High iron content) will do, it rust from the inside out. This 6" piece was almost totally clogged with rust and corrosion. This is also the effect it can have on a water heater. Especially, the sacrificial anode rod inside the heater (if it's an electric water heater) That's why it's so important to drain and flush your water heater, at least once a year.
I mention all of the above, because you very well, may be experiencing the same issue. The way to resolve it requires a little detective work on your part. Check you piping to see if any is galvanized pipe, rather than copper or PVC. Keep in mind, that the sink fixtures, may very well may be galvanized, if your home is 30 or more years old. If you find any, I highly recommend replacing it, before something goes wrong in the middle of the night or while you and your family are away from home. If you hard water is a result of using a well, place a whole house water filter on the main incoming water line. It does not have to be a charcoal filter. And to make your water more palatable, install an automatic water softener. For me, it was all money well spent.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 16, 2011 | Heating & Cooling
The boot keeps getting moldy..yes, I ALWAYS leave the door open..even dry the folds with a towel. Its only a couple of years old! I have looked at other people's front loading washers..and noticed their...
In order for you to get rid of the mold, you have to get rid of it. Wash your boot seal with vinigar followed by bleach and antibiotic soap. Make sure to rinse well before loading any clothes afterwards. It would not hurt to run vinigar through your wash cycle followed by bleach either. You have to kill the mold or it will keep coming back and soap skum is a breeding ground for mold.
Feb 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer tub slowly (over several days) gets water inside
yes this is more than likely a leaking inlet valve, to confirm turn of water at wall valves
Sep 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
1 year old Kenmore Elite Trio Refridgerator not cooling
There are a lot of things that could be the source of the problem... is there no cooling at all going on in the freezer? Is the back wall of the freezer cold? It could be anything from a fan, to the compressor, to the control board... you need a technician.
I would get on the phone with Sears, and explain the continuing problems you have been having, and they may agree to cover service.
Jul 26, 2009 | Kenmore 73503 Stainless Steel Bottom...
Sub zero 550 (14 years old) has a small but steady leak onto floor from freezer compartment. Small amount of frost buildup on inside of door. Food is frozen and the door "appears" to seal we
Right hand side wall in the freezer - take a look- any frozen water or moisture? Need check a drain line, usually defrost heater inside the freezer wall getting bad and draining water just freezing inside of it.
May 10, 2009 | Sub-Zero Bottom Freezer Refrigerator
Samsung ac model aw25ecb7
hi! bill,
water drip it should be outsidethe house,beside there is a spout on the basin of your ac unit and hose to drip off outside the house,all you gonna do insert a piece of wood or metal on front side of basin, in between basin and the wall,just small piece object to elevate the basin to outside wall,the water will not stored in the basin.or make a spout, drill a hole 1/4" size at the corner at the backside of basin out side your house,be carefull not to drill condenser tube or the fan blade,insert a plastic hose 3/16" and weld it by glue gun.and end of hose put it an empty bottle so that the water drip will not scattered outside your house.regards and don't forget to rate me,thank's a lot
Apr 29, 2009 | Samsung AW0503B Air Conditioner
Whirlpool "Duet" Frontloader washer
The freshwater leak is a simple fix. After plugging off the wall, check the inlet water valve electric connection to see the harness has come loose. If there is no problem there you only have the change the inlet valve which you can do yourself. Check model number and try the sites below for spares.
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Aug 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Printing black text
you can try this to really clean the print head: Canon will hate me for this.
1. Remove ink cartridges.
2. Remove print head.
3. Go to sink or tub (stainless steel, not plastic type), pick up a roll of paper towel on the way.
4. Fold several layers of paper towel and place on flat surface.
5. Run hot water until HOT!
6. Turn hot water back to a dribble.
7. Run the dribbling hot water through print head being careful not to wet the gold contacts.
8.When water running through print head is clear, place print head on paper towel.
9. Repeat number 7 and 8 until no colour shows on paper towel.
10. Gently DAB print head (DO NOT WIPE) inside and out with dry paper towel until dry.
11. I normally replace print head after drying, but you may wish to let it air-dry overnight.
12. Replace print head in printer and install cartridges
13. Start printing.
I do this to all 4 of my Canon printers every 6 months or so.
If any colour fails to print after this process it means your print head probably needs replacing.
Feb 16, 2008 | Canon BJC S450 InkJet Printer
Kenmore Clothes Washer leakes when filling,it's a top loader.
When you say it is leaking when it is filling, where is it leaking ? Inside or outside the machine ?
I'lll try to help once I know the answer to the above
Jan 01, 2008 | Kenmore 24032\24036 Top Load Washer
Blast Zone Pirate Bay Inflatable Water Park Logo
653 people viewed this question
Top Blast Zone Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Blast Zone Pool and Spa Expert? Answer questions, earn points and help others
