Question about Pentair IntelliFlo VS-3050 & VS+SVRS Variable Speed Pump -
Display shpws motor is running but motor doesnt run
I just bought the intelliflo VS in February 2013. I went on vacation for a week to find that the pump had not been running. The display shows that it is when I run in manual or auto but the motor is not turning on.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Pentair Master
  • 1,448 Answers
Go to utube they have videos how to program you need to set clock and set a run time
Posted on Sep 07, 2014
thepool
  • 78 Answers
SOURCE: pentair intelliflo variable speed pumps
Extensive information available is available from Pentair. Owners manual http://www.pentairpool.com/pdfs/IntelliFlo4x160and4x100OM.pdf Quick start guide http://www.pentairpool.com/pdfs/intelliflovsQSG.pdf
Posted on Apr 21, 2010
adamh294
  • 310 Answers
SOURCE: We lost our password for
On the normal vs-3050, you need to reset the whole unit. You do this by holding all 4 speed buttons for 30 seconds. After thi, shut off the power at the breaker. let sit for 2 minutes. Restore power and all setting are reset. I cant find any information about the SVRS model, but it should work the same way.
Posted on Oct 28, 2010
adamh294
  • 310 Answers
SOURCE: I have intelliflo VS+SVRS pool
There is either something blocking the suction side of this pump (blocked valve, strainer, strainer basket, leaves on main drain.) or the pump is not getting primed in the aloted amount of time. You can increase the priming time on the pump, or manually prime it, or just turn off the svrs feature temporarily until you get a good prime again. If you need the manual to figure out how to do these things, here is the link.
http://www.pentairpool.com/pdfs/IntelliProVS+SVRSOM.pdf
Posted on Jan 19, 2011
jharwell668
  • 640 Answers
SOURCE: I came back from vacation to find the pool not
It sounds like your pool pump might have lost its prime. Make sure the lid is on and is secured tightly. Check your water level to make sure that it is above the skimmers. Make sure the suction lines, pump strainer, and pump pot are full of water. After you check these things, re-prime. If this still doesn't solve the problem, also check for clogged baskets and worn out gasket/valve. Make sure that you don't have an visible air leaking in the pool (look for bubbles).
Posted on Apr 26, 2011
aquaman987
  • 927 Answers
SOURCE: I just installed a intelliflo
Try slowing the pump down if it is variable.
Gary
Posted on May 05, 2011
The pump went off.display shows power stopped,.I can't restart pump.How can i do?
most likely the pump has tripped the motor overload - there should be a button on the motor that once pressed should reset the overload - should it trip a 2nd time call in a spakey
Nov 11, 2013 | Pentair IntelliFlo VS-3050 & VS+SVRS...
Pentair IntelliFlo VS-3050 & VS+SVRS Variable Speed Pump -leaks from housing
Which part of the housing?
The back against the motor or against the strainer basket housing?
Parts break down for the Pentair IntelliFlo VS-3050 here.
If leak is on the back of the housing - shaft seal. Or if the leak is on the front the replace O-Rings #10 or #23 in diagram.
Sep 13, 2012 | Pentair IntelliFlo VS-3050 & VS+SVRS...
Motor will not come on everyday. comes on some days and then others, you have to start it manually. Replaced control panel 6 weeks ago and worked fine, now same problem again. Motor runs at lowest speed...
FIRST: When you shut the breaker off and then back on was it because the breaker was "tripped" ?
SECOND: Does the motor run "hot"? Feel the outside of the motor casing when its running to check. ****becareful - it may be really hot****
As soon as you get back to me with the information I can tell you what is going on and what direction to go in. Thank's
Dec 08, 2010 | Pentair IntelliFlo VS-3050 & VS+SVRS...
Went away on vacation, came back basket clogged of leaves, pump has no power and wont start
contact pentair customer support......after first checking breaker for pump,,,,....make sure power is on and at oump with voltgage light up pencil checker.....checks sockets or any device for line voltage just by placing it on power line....get it at lowes.....I believe pump has a rest but check with customer support or your product troubleshooting guide
Nov 27, 2010 | Pentair IntelliFlo VS-3050 & VS+SVRS...
Pentair IntelliFlo VS-3050 & VS+SVRS Variable Speed Pump -  Logo
112 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
