Marantz pm6003 cuts itself out automatically. connected to 2 Lektor Dali 6ohm
The volume of my model's volume only goes up to 40...is there a way to increase the volume?
Sometimes you can connect a lower ohm speakers. However you must NOT go lower than the amp can take. For example if the amp has 8ohm as the lowest for it you can go to 8ohm speakers, if it has 16ohm speakers connected, but must connect 6ohm speakers. If the amp allows 6ohm than you can connect 6ohm speakers. Changing from higher level speakers to lower level ones will make the volume louder. But you must not connect ones lower than the rating of the amp.
The only other way is if there is something wrong with the amp and that it won't go higher due to a fault.
Oct 27, 2017 | The Audio Players & Recorders
How do I connect a Marantz av8801 to a Marantz sr7009
The 8801 is an 11.2 channel AV preamp/processor. The SR7009 is a 9.2 channel receiver that includes both preamp and amplifiers.
The 8801 handles an amazing 11 channels of audio, but you can only use the SR7009 for 7.1 input channels. (Does anyone really need 11?) Unless you have some extremely demanding audio requirements, you would probably just want to use the SR7009 by itself. You can't fully utilized the 8801 as a front end (pre/pro) so I'm not aware of any benefits to connecting the two of these together.
Feb 22, 2015 | Marantz AV8801 - Flagship AV Preamplifier"
Turns off automatically
probably have a short in the amp section that needs to be repaired.
Nov 20, 2013 | Marantz SR5006
Hi, i have a marantz pm720 amp, when i switch it on, straight away it starts to make loud cracks through the speakers like spikes,then it will cut sound all together for a few seconds then back on, when i...
Hi Paul;
There are one or more transistors failed in the output circuit
I would have tech look at the amp and see what the power supply is doing without spkrs connected
Aug 20, 2010 | Marantz PM7200 2-Channel Amplifier
Can I bridge channels on my JVC RX-D201S it cuts out when I turn the volume above 30 I want to drive 2 x DALI concept 6 front speakers 2 x concept 1 rears and a concept centre. Do you think I can add the...
putting the extra speakers on wont solve the problem the unit has a max output it might give a better alround sound so it will be clearer a little but pushing to far on standard speakers wont help if you need better go for some active speakers there more exspensive but will give better definition and the volume limit might be higher.
Aug 06, 2009 | Audio Players & Recorders
Marantz PM 4000 has cut out
May be the problem solved here :
http://www.audiotoolers.com/ubbt/ubbthreads.php/ubb/showflat/Number/5316/page/1#Post5316
Nov 21, 2008 | Marantz Audio Players & Recorders
Marantz Sr8500
Check the speakers impedance. it should be greater then 6ohm otherwise you overload the system. Also, if the speaker sytem is rated (in Watts) below the amplifier's power it overloads the amp at higher volumes.
Apr 12, 2008 | Marantz SR8500 Receiver
Marantz PM4000 amp keeps cutting out
There is a fairly simple fix to this problem here: http://www.audiotoolers.com/ubbt/ubbthreads.php/topics/5316/Problems_with_Marantz_PM4000_A.html
Apr 22, 2007 | Marantz ZS5300 6-Channel Amplifier
16 people viewed this question
 Grubhead
Grubhead
