Question about Northstar Garden
Northstar pressure washer starts and then dies when I give it gas
Its a Northstar pressure washer model # 1573701. It starts fine when throttle is half open. When I open it all the way, the engine dies. What's causing this?
    Sergeant:
  • 406 Answers
You may have a restricted carburetor??
Posted on Aug 05, 2013
4 Suggested Answers
  • 174 Answers
SOURCE: northstar pressure washer randomly gives pressure
Hi:
You need to find the bypass (unloader) valve and grease it with a good waterproof grease. Sorry, I cannot find a pic for you
Posted on Sep 03, 2009
  • 3600 Answers
SOURCE: Northstar pressure washer needs new hose
Need to know what country you are located in and if you want a 15 foot hose or 25 foot or 50 foot hose. The reason is We have to know where you are going to buy it and if you have a dealer that that is local or not. it's a 2500 PSI hose so the hose has to be a minimum of 3200 PSI You can also have hoses fixed at local hydraulic shops in the U.S. in the local phone book, they can make up the hose you need if you take it to them let me know.
Posted on Mar 25, 2010
  • 4349 Answers
SOURCE: I have a Northstar Pressure
This sounds like a mixture problem, try adjusting the main jet. You can also test by applying choke, briefly when you start to spray.
Posted on Mar 05, 2011
My northstar pressure washer has no pressure
PDF]Owner's Manual - Northern Tool + Equipment
https://www.northerntool.com/.../1577544.p...
Northern Tool + EquipmentCall NorthStar Product Support 1-800-270-0810 .... -During transportation take precautions to make sure pressure washer will not tip ..... A- Low oil shutdown.
Sep 21, 2015 | Northstar Garden
Northstar Pressure washer starts and runs but dies when throttle is opened up
is this a v-twin engine or has the unit been stored for quite some time with fuel in carburetor.inspect fuel jet and tube for restriction.
Jul 28, 2013 | Garden
Looking for an electric starter for Northstar Model 157892A
Is this the engine model number or the machine model number? Is the motor already set-up with an electric start or is it something you are looking to add?
Oct 30, 2010 | Northstar Pressure Washer 3000 PSI
I have a northstar pressure washer 2000pw serial #03005610 item #157754b someone has took carb off and u was wonderin if u could give me a blowup of how the linkages and springs go ?
You will find your information by looking for model number and code of engine. Look on the fan cover, valve cover engine block or tag directly on the engine itself. Example would be Honda model gx340 from starter of engine. Then check google or mfg. web site for manual showing governor linkage. Norhstar uses several brands of engines. Good luck
Sep 08, 2010 | Northstar Pressure Washer Trigger Spray...
White smoke. when it won't start, raw gas comes out of the exhaust GS190 honda Karcher 3000 PSI
Sounds like it's flooded. Close the throttle and open the choke if equipped. Pull it through a few times and then open the throttle a bit.
May 24, 2010 | Northstar Pressure Washer 3000 PSI
Northstar pressure washer randomly gives pressure
Hi:
Sep 03, 2009 | Northstar Pressure Washer 3000 PSI
My Northstar Pressure Washer Pump does not boost water pressure
Pump will power up, but when I attempt to use the wand the motor sounds like it is running on one leg & blows circuit breaker----Ser# 1575551-1101 5160 Model #1575551E
May 11, 2009 | Northstar Pressure Washer 3000 PSI
Unable to start gas engine on a NorthStar pressure washer
Disassemble and clean the carb. If it ran briefly with the starer fluid then gasoline is not coming through the carb.
Dec 30, 2008 | Northstar Garden
Garden Logo
87 people viewed this question
Top Northstar Garden Experts
John Trevino
JOHN LAPIER
Are you a Northstar Garden Expert? Answer questions, earn points and help others
