Question about Kodak Office Equipment & Supplies
How to unjam ink cartridge 7250 printer
Ink cartridge is stuck code 3527
geemarie
  • 876 Answers
SOURCE: hp photosmart printer 7350
Turen the machine off
Unplug it from the wall
open the paper jam door and gently push the paper roller upward until it clicks.
close the door.
Plug it back in
Wait a few minutes
then turn the printer on and see if the carriage moves.
This is a simple general reset of theprinter and sometimes it will help with this sort of problem. Let me know if it helps or not.
Posted on Aug 13, 2008
  • 7 Answers
SOURCE: Magenta Ink cartridge is stuck in Xerox Phaser 8550/8560
09,03x
35 = Cyan
36 = Magenta
37 = Yellow
38 = Black
The error indicates an ink stick was jammed. You have to clear the ISC (ink stick count) error.
Turn off the printer.
Turn on the printer.
As soon as you see XEROX start moving across the display hold down the back and help buttons until you see "beginning service mode" on the display.
Release the buttons, it will now come up in the service mode.
Scroll down to the function menu, hit ok, scoll to clear isc fault, hit ok.
Hit the back button to get back to the first menu then exit diagnostics, hit ok when it asks if you want to restart in customer mode.
Posted on Jun 10, 2009
pineworks
  • 4041 Answers
SOURCE: Printer cartridge cradle is stuck.
Hi ok sorry to heer but try I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 08, 2010
  • 739 Answers
SOURCE: how do I remove the
Is it still switched on?
Posted on Feb 09, 2011
SOURCE: Kodak ESP 3250. Error 3527. I put new ink
Contact Kodak. I think it's the batch of printers that were made around this time. I just contacted them (mine is the same age and I'm getting the same error), and they are sending me a new printer.
Posted on Mar 09, 2011
Print head parked at left, error code 3527
This problem has plagued me for a very long time. The issue is that the printer head is "glued" in the resting position under the guard of the printer, so you can't remove the ink cartridges to clean it. Solution is to (I know this sounds stupid, but it works) turn the printer on the side where the printer cartridges are (if they are stuck on the left side, turn the printer on its side so the cartridges are on the bottom). Turn the printer on, and the cartridges magically start moving! I guess there are some sensors that get tricked out when you tip the printer on its side. If the cartridges are still stuck, click the "ok" button, and before it gets a chance to see if you actually fixed the problem, turn the printer off using the power button. It takes a long time, but you should see the ink trap lower (release the ink cartridges) and the ink cartridges start moving to prepare for shutdown! Grab the cartridges when they move out of their hiding place and don't let them go back until you clean the print head so it doesn't get stuck again. Remove the ink cartridges, then push the grey tab to release the print head. Wipe the bottom of the print head clean with rubbing alcohol (it will have a lot of gooey - sticky ink stuck on the bottom). I used nail polish remover since I didn't have rubbing alcohol available. You can also wipe down the ink pad which is where the ink cartridges were previously jammed to clean up more of the mess and prevent this sort of thing happening again too soon. Good luck!
Dec 27, 2013 | Kodak ESP 7250 All-in-One InkJet Printer
I have kodak ESP 7250 ... Error light says printhead cartridge jam ... How do you fix ... I tried everything ...
When all else fails contact Kodak support and they can help you through this issue. The customer service number can be found in the instruction manual or online using "Kodak printer repair".
Nov 14, 2013 | Kodak ESP 7250 All-in-One Printer
Kodak 7250 print head jam
Jan 20, 2012 | Kodak ESP 7250 All-in-One InkJet Printer
Printhead cartridge jam code 3527
Contated Kodak about the error code 3527 and was advised I needed to purchase another printer and they would give me a 30% discount. Why would I do that when my Kodak printer is only 14 months old! My Dell is 9 years old and works fine! Dell ink cartrides are expensive and can only be ordered online. That is why I switched to Kodak. Do not buy Kodak!
May 01, 2011 | Kodak ESP 7250 All-in-One InkJet Printer
ERROR CODE 3550 TOP TRAY JAMMED HAPPENS EVERY TIME
to unjamm your printer unplug the printer or just shut it down and re-start it, it will atomatically unjam itself. it that dont work then there lift the scanner bed and look where the inks is and see if there is paper lodge inside, most of the time its the small paper or an envelope that will cause this problem. hope this helps
cw, fl
Mar 19, 2011 | Kodak ESP 7250 All-in-One InkJet Printer
Printer wont print
Issues with the cartridge are other causes for trouble in your printer. If you have not used your printer for a pretty long time, there's chance for the ink in the cartridge to get solidified, ending up in its damage. The issue could also be caused due to the lack of ink in the cartridges. In order to resolve the issue, you might ensure that you are not keeping your printer idle for very long periods. You could also check its ink level.
Feb 21, 2011 | Kodak ESP 7250 All-in-One InkJet Printer
Kodak ESP 3250. Error 3527. I put new ink cartridges in.It started to pull the paper thru then stopped. I had to remove the paper buy pulling it back out. It says Printhead cartridge jam. Open printer...
Feb 02, 2011 | Kodak Esp 3250 Allinone Multifunction ( ...
My kodak copier model esp3250 shows an error code of 3527...what do i do?
Print cartridge jam error 3527
I cleared this error by manually moving the head cleaning pad into its stand by position It must of stuck while changing the ink cartridges.
Mar 13, 2010 | Kodak Office Equipment & Supplies
18 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
