Question about Western Digital Computers & Internet
Wd3200meb 00 Can I switch this portable hard drive back and forth between my PC that uses XP and my 2 year old MacBook Pro (plus a soon to be purchased new PC).
    Brigadier General:
  • Western Digital Master
  • 3,400 Answers
IF THEY HAVE THE SAME FILE-SYSTEM.
Posted on Jul 29, 2013
seekpcrepair
  • 39 Answers
SOURCE: One Touch 4 Maxstor 750 external hard drive installing on a macbook pro
If you have a hard-drive that is formatted as NTFS which stands for (New Technology File Ssytem), Mac OS X can only read the partition. It cannot write to it.
The trick is to use your drive manfacturer's disk-formatting software which will allow you to format your drive as one large partition. Formatting your drive as one large FAT 32 partition is the easiest way to make a drive so it can be used with both PC's and Mac's.
Another option is to use a third part utility so that you can read a MAC formated harddrive's from your PC. Here is one option: http://www.macdrive.com/.
Good luck.
SeekPCRepair
Posted on Feb 09, 2008
  • 10406 Answers
SOURCE: USB hard drive not recognized by Mac and by PC
Does the external drive work when connected to some _other_ computer? (Friend? Office? Home?)
It could be a failure either in the "hardware" inside the external-case (the USB adapter & interface)
or in the disk-drive "inside" the external-case.
So, a qualified technician can open the external drive, remove the disk-drive, and connect it directly to a computer, to see if the files can be "directly" read from the disk-drive.
If not, then you should search online for a "data recovery" service -- they are expensive, but they physically repair a damaged disk-drive, just long-enough to copy your data to another disk-drive.
Posted on May 31, 2009
Crankstart
  • 696 Answers
SOURCE: WD Passport plugged into mac then PC, but no drive letter
Hi
You can either format the drive using the PC or install MacDisk on your PC witch will allow you to view any Mac formatted drive on the PC.
http://siteadvisor.de/sites/macdisk.com/downloads/17329989/
Click the link to download macdisk7.5.7.5 or reformat the drive to NTFS which the mac and PC will be able to share if the need arises in the future.
Chris
Posted on Jul 09, 2009
  • 10406 Answers
SOURCE: i need a manual how use my passport essential hard
Download Quick Install Guide or download the manual:
http://support.wdc.com/product/install.asp?groupid=209&level1=2&modelno=&lang=en
Posted on Sep 14, 2009
SOURCE: Cannot add anything to my external hard drive
re-hobrax
also make sure you are in administrator account to make changes
Posted on Feb 19, 2010
Replace macbook hard drive
There are a few guides out there, this one is my favourite. MacBook Pro 15 Core Duo Model A1150 Hard Drive Replacement
You didn't say what year MBP you have, if it's a newer one with Retina display you can't replace the HD.
Mar 27, 2016 | Apple MacBook Pro Laptop Computer with...
Drive does not appear on macbook pro
You need either need a driver to detect the hard disk or you will have to format hd.
Jul 25, 2014 | Western Digital WD Elements Portable...
Is it possible to boot from an Iomega eGo Blackbelt Mac Edition Portable HD and also use it to clone an existing drive? I want to upgrade an existing 160GB Internal HDD in a Macbook Pro 17" to a...
It's possible to clone to this drive, but over the USB interface, it will be very slow. Firewire would be faster. It's also possible to boot from it, but again, it will be slower than an internal. What you've described, however, IS possible.
Feb 28, 2011 | Iomega eGo BlackBelt Portable Mac Edition...
Seagate Portable 250 GB External Hard detected for only 2 secs
u can try some hit and trial...
1 - keep ur USB HD off and switch on the PC then switch on the power on USB HD
2 - try another USB port
3 - try another USB cable connector
4 - check ur Device manager/usb root hub settings/power setting, uncheck the box that says" alow computer to switch off power....in Power Mgt tab
Feb 18, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My MacBook Pro goes to the grey screen with the
Most likely, you are looking at a corrupt installation of the OS, or a failing hard drive... most likely the latter, unfortunately. Laptop hard drives only seem to last a couple years now, 3-4 if you're really lucky. I would suggest popping in the System Restore Disc (that came with the computer originally) or the OS install disc (in case it has a new version installed than it came with originally) and go to Tools->Disk Utility, and tell it to "repair permissions" and "repair disk", and see if that resolves it. If it happens to, I suggest backing up your data ASAP just in case. More info can be found here on using Disk Utility.
Nov 11, 2009 | Apple MacBook Pro Laptop Computer with...
My back up 160GB Rugged drive quit working,felt hotter than normal and gives off a 'burnt' cct. smell. MacBook Pro using XP pro SP3 with Firewire link. Backup size about 70GB with five years of photos....
One of the circuits in the back up drive failed. Your options are to send to to the manufacturer for possible repair or you can try removing the drive unit, that is actually what is inside that, and putting it in a portable case, available from Best Buy for about 39.99, and continue to use the device. or take it as a lose of data and get a new back up drive.
Sep 08, 2009 | Computers & Internet
Hi
Chris
Jul 09, 2009 | Western Digital Passport WDXML800UE...
MacBook Pro
It is possible, nonetheless you would have to do something before taking your mac, or any product, to a store.
1- Go to bestbuy.com and all the way to the bottom of the site.
2- Under product support you will find a link named Trade In center.
3- Click on it (because that's what links are for).
4- Answer the questions and voila.
5- Print the certificate.
MB
May 18, 2008 | Apple MacBook Pro Laptop Computer with...
Apple macbook pro
http://forums.macrumors.com/forumdisplay.php?f=129 Look here first as I'd need more info prior to Guestimating the cause.. (Were Swamped).. Any way post back.. Sounds like drive failure to me or similar/OS Issue but could be more. Is the flashing/Change Timed or an Intermittent thing..
Mar 10, 2008 | Apple MacBook Pro PC Notebook
Computers & Internet Logo
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
