Question about Hampton Bay Ceiling Fan. Hawkins 44 in. White Ceiling Fan YG204-WH
Pull chain hanup on glass light cover
The fan speed chain must be routed through holes in the glass cover and cap. This makes the angle too acute and the chain hangs up on the cover and will not operate.
    Genius:
  • Hampton Bay Master
  • 1,617 Answers
Take the glass off and see if there is a hole in a small plate below the light sockets. The pull chain should go thru this hole first before the glass. I don't know if this has it or not being that it's a low-end store brand fan.
Posted on Jul 28, 2013
  • 18 Answers
SOURCE: ceiling fan will not turn off
There is 2way switch attached to this chain you need to replaced it.
Posted on Jun 04, 2007
Buffalo12980
  • 625 Answers
SOURCE: how to replace or repair center fan speed pull chain
the chain goes into the switch and operates a round contact plate. just get a new three speed switch.
Posted on Aug 22, 2007
Crossedwires
  • 44 Answers
SOURCE: Hampton Bay ceiling fan with pull chains not working
Whether there is a reset switch on this unit or not would depend on the model. If you no longer have the owners manual you should be able to get it from the hampton web site. Many fans have a thermal fuse inline that probably was blown when the bulb broke. The cheaper models do not and then I would guess you burned out the switch.
Posted on Feb 09, 2008
SOURCE: I just had a Hampton Bay fan installed, and the
Replacement switches can be purchased at Orchard supply, Ace Hardware, Lowes, or Home Depot. After checking the wiring at the switch - connections made during fan installation - and no faults are found, switch should do it.
Posted on May 04, 2009
SOURCE: I want to hang the fan on a cathedral ceiling with
The slope is measured off the horizontal plane. A 45 degree slope would rise 12 inches for every 12 inches of horizontal travel in this example. If the slope is too great try checking kits made by Fanimation. The Fanimation SCK52 - 52 Degree Ceiling Slope Ceiling Fan Kit will go up to a 52 degree angle ceiling and will fit most downrods. The hampton bay fans are very popular and should work just fine with this kit.
-Mark
Posted on May 14, 2009
Where can I purchase a Jin you e70469 ceiling fan switch.
ebay 14 bucks
Jin You E70469 Pull Chain Switch for 3 Speed Ceiling Fan 4 Wire 1 2 ...
https://www.ebay.com > ... > Lighting Parts & Accessories
item 2 ze-208s ceiling fan pull chain speed control switch for zing ear 3 speed 4 wire -ze-208s ceiling fan pull chain speed control switch for zing ear 3 speed 4 wire. ... item 3 OEM ZING EAR ZE-208S 3 SPEED CEILING FAN PULL CHAIN CONTROL SWITCH E-89885 DR73 -OEM ZING EAR ZE-208S 3 ...
Exhaust Ceiling Fan Switch 2 Speed Pull Chain Blower Jin You ...
https://www.ebay.com/itm/...Ceiling-Fan-Switch...Jin-You-E70469...-/132376583704 Replaces Jin You E70469, Santa, Gardner Bender GSW-33. The control module provides two speed setting for your fan. 2 Speed Pull Chain Switch. 3" (7mm) Brass Chain. Spark Electric Components LLC. Width 11/16" (18mm). ' eBay!
Jin you e70469 ceiling fan switch Google Search
Dec 12, 2017 | Dryers
Why does fan chain bind at light housing on 10207 eastover
Take the glass off &make sure the chain goes through a hole in the fitter before it goes through the glass.
Sep 04, 2014 | Dryers
Craftmade Ceiling Fan Problems
Make sure your fan is on high with the pull chain switch. Push the remote Hi button then pull the chain until it's on the high speed, Then DO NOT use the pull chain. Same with light , Push light button on remote then pull chain until it's on then leave the chain alone. If that doesn't do the trick then you probably need a new receiver.
Jun 15, 2013 | Craftmade International CXL52 Electric...
My control won't activate the light on my Hunter fan. The light comes on via pull chain fine, and the control works the 3 speeds on the fan, but the light won't respond.
Check the wiring on your receiver to make sure the light wire is connected.You have to have the light on with the pull chain and then use the remote to turn it on/off.
Jan 06, 2013 | Hunter 52" Ceiling Fan With Light And...
I have a Hunter fan with a bowl type light fixture. The chain that controls the fan goes through two holes, one through the metal disc that the bowl sits against, and the other through a hole in the cap...
Sorry to read about your problem, I hope this helps you out.
Either you take a glass drill and make the hole a little larger, or just to put a bevel on the holes, or take a candle/wax and rub on the chain, where it it goes thru the hole. last but not least, you can try to convert to a string,instead of a chain.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Dec 29, 2010 | Hunter Ceiling Fan Control Switch
Hunter 52, fan works but light no longer works with remote or chain pull
mcdevito75 here, Don"t the fan lights work off the wall switch, The chain pull should be for fan speed. Check make sure electricity is going to the fan.
Jul 19, 2010 | Hunter 52" Ceiling Fan With Light And...
How to attach an on/off chain to a ceiling light- the original broke off somewhere inside. The fan switch is intact. This is one unit.
You need the little coupler thing that connects to the ball that makes up the chain. If you dont have the coupler ... you could get one at your local Ace Hardware store ... or you could just purchase a similar switch which would have the coupler on the chain.
Jun 07, 2010 | Leviton 1689-050 Pull Chain Fixture Switch
The chain for fan speed control comes through the glass light globe at such an angle that the fan can not be changed to different speeds is there a fix for this problem
Never heard of that, usually the chains come out of the housing above the light and hang straight down.
Is the chain tangled somehow?
Apr 25, 2009 | Hunter Ceiling Fan Light Switch Control
How to replace or repair center fan speed pull chain
Jan 31, 2007 | Hampton Bay 48670 Flemish Pewter Finish...
Hampton Bay Ceiling Fan. Hawkins 44 in. White Ceiling Fan YG204-WH Logo
114 people viewed this question
Top Hampton Bay Dryers Experts
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
