Question about Craftsman Garden
Timing set points
I hit something with my mower and knocked it out of time how do I reset the timing
3 Suggested Answers
  • 11 Answers
SOURCE: Timing belt off my 5.5 push mower
it has a crescent shaped pin under the flywheel and is sheared causing the timimg to be off and pull your arm out of the socket
Posted on Apr 03, 2009
  • 420 Answers
SOURCE: blade hit something and now the motor will not
You must replace the flywheel key and it will start right up.
Posted on Jun 04, 2010
Exmark disengages and backfires after runing for 1/2 hour or so
The backfire indicates a timing problem. Did you hit something at some point in the past? If so you may have damaged not sheared your timing key, this would still allow you to start your machine. If your mower runs for a short period, it warms up enough to put timing out. What I mean is when hot expansion, when cold contraction. Check your shear key for the problem. GOOD LUCK FRIEND.
Sep 05, 2014 | Garden
How to set timing on a honda gvc160 6.5 hp engine
the timing is set by the magneto sitting on the Shaft that is fixed by a Keyway. If the timing is off it is because you broke the key. Did you hit something that made the mower stop?
Jul 11, 2013 | Garden
5 HP DID RUN THEN DIDNT
Try new spark plug, fresh fuel, and new air filter.If you have hit something with the blade it may well have sheared the flywheel key knocking the ignition timing out.
Feb 17, 2012 | Briggs & Stratton Garden
My son hit the edge of a paving stone with the mower. He says that it killed the mower and then he could not restart it and that it was making a noise like the blade was hitting something when he tried. ...
Do not run it like it is. At a minimum you have partially sheared the flywheel key. That upsets the ignition timing. Remove the flywheel and inspect the key, replace if any damage whatsoever. The key is a little piece of soft metal that is designed to give way when you hit something hard. After repairing that, remove plug and turn the engine over by hand to see if anything is hitting in the engine. Probably could do that first to let you know how bad it is. If no unusual noises from the engine or knocking of parts, try turning over with pull cord checking again. Then you can put the plug in and attempt to start it after flywheel key replacement.
I hope this helps.
Aug 06, 2011 | Poulan Garden
Does the blade need to be on for my 6.5hp self propelled toro mower to start? It keeps backfiring and the blade key is striped.
I am not familiar with this model. However, just about all lawn mower engines rely on the blade to act as a flywheel, a very important factor in engine operation.
I hope this helps you ...
Thanks for your interest in FixYa.com
Jul 13, 2011 | Toro Garden
Blade hit something and now the motor will not
Jun 03, 2010 | Toro Lawn Mower With Toro Power Tools
How to reset timing on a Kawasaki 4-stroke lawnmower engine. I replaced the flywheel key after an employee had hit something. It is still very hard to pull start.
The flywheel key is the only way to set the timing. If it has a blade clutch that may have been damaged when it hit something. If it does not have a blade clutch, it has a brake on the flywheel that is not operating correctly. Did you check to see if the blade and/or shaft got bent in the mishap?
Sep 15, 2009 | Garden
My zero turn mower's deck was knocked off. I put
if it got knocked off, i'd guess it hit something pretty darn hard. i'd check first for bent blade[s], then bent or broken mandrels
Aug 23, 2009 | Garden
Apr 02, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
13 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
