Question about Dometic Rooftop RV Air Conditioner
Compressor won turn off - Dometic Rooftop RV Air Conditioner
    Genius:
  • Dometic Master
  • 1,363 Answers
Relay module
Posted on Aug 18, 2015
Why my A/C condenser fan won t stop running, dodge ram 2008
To clarify, the compressor and fan will run in defrost mode. The compressor and fan runs to dry out the air blowing onto the windshield.
Now if the condenser fan runs in "heat" you may have a problem with the fan relay or the main controller.
Sep 25, 2014 | 2008 Dodge Ram Pickup 1500
Compressor won't turn on or off with the switch no idea why help please
The key is the last part of the video, the part that wont move is unloader valve. The pressure switch under the lever is sticking and not allowing the switch to close.
Mar 11, 2013 | Air Tools & Compressors
My 5hp 13 gallon compressor won,t run when you turn it on there is no wind nothing at all how do i bypass the switch and hook it direct
you don't connect it up direct unless you want to destroy the compressor and burn the motor out
check for a reset or thermal overload button if it just shut down when over pressured
replace the pressure control switch is the best fix after checking out the motor condition
Jul 04, 2017 | Campbell Hausfeld 26 - Gallon Air...
A/C and heating core
The leaking heater core won't keep the compressor from working.
You say the ac system is charged, but the compressor won't come on ??
The compressor has to run to charge the system, otherwise you will only get half a can of freon to go in. The system holds 3 or 4 cans when empty.
The low pressure switch has to be jumped to make the compressor run to take the first two cans of freon.
Jul 03, 2012 | Chevrolet Cars & Trucks
A/c compressor won't work -fuses and relays good
the compressor will turn on when freon is added a low pressure switch shuts it off to prevent damage to the compressor
Jun 23, 2012 | 1999 Pontiac Grand Am GT
My kobalt air compressor model#215914 won't stop running is it suppose's do that?
All compressors run up to their rated high pressure level, usually listed on the data plate on the compressor or in the manual, then the pressure regulator turns them off. If your compressor is not shutting off it is either not getting to the pressure it takes to get the pressure regulator to turn it off or the pressure regulator is broke and won't turn the motor off. To check which, turn the compressor on and watch the guage that shows tank pressure. If the pressure rises then stops at a level below the rated pressure for your compressor and the motor continues to run, you have a leak somewhere. It could be the tank drain valve, the lines from the pump to the tank, the valve plate or in the piston cylinder area. If the pressure rises more than ten psi above the rating for your tank, your pressure regulator is broke or possibly set too high. If you know how, you can try lowering the shutoff point to see if that fixes it but you're usually better off replacing the regulator.
May 09, 2012 | Air Tools & Compressors
The air conditioning in my 1994 toyota pickup all of a sudden stopped working the compressor won't kick on but the pulley turns, does that mean i need a new compressor?
The air conditioning system has a pressure switch that won't let the compressor engage if the refrigerant is too low. You seem to have some sort of leak ... if something slow then one of the
refill and lube/seal kits from the auto parts store should get you going. Get one with a gauge so you don't over charge. Obviously if a major leak then repairs are in order.
Jul 08, 2011 | 1994 Toyota Pickup
Air condition compressor won;t kick in
Most likely a loss of refrigerant ( freon ) in the system. The A/C compressor uses a low pressure switch as a SAFETY to insure it wont turn on without freon in the system. Hope this helps.
May 18, 2009 | 1999 Chevrolet Lumina
Dometic Rooftop RV Air Conditioner Logo
48 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
