Question about Dell Computers & Internet
Orange light on and processer fan not work
Orange light on and processor fan not work
    Top Expert:
  • Dell Master
  • 12,223 Answers
Restart the PC, HOLD the keys f2 or esc +CTRL and enter to the BIOS setup, go to TAB for restore the factory default, and try it.
However you must use the software diagnostic coming the computer or download from www. dell.com
God bless you
Posted on Jul 28, 2013
Indication lights
make sure that the cpu fan is plugin the right place or the fan is broke replace it then
Jul 28, 2013 | Dell Computers & Internet
Have a Dell Optiplex 740 desktop. Power button is lit solid orange. No diagnostic lights on. Fans still blowing. Replaced power supply unit still nothing. HELP!!!!!
before replacing main board,try replacing individual hardwares like ram,processor and if still not working,try resetting the bios by alternating the jumper on the labelled CLR CMOS
good luck
Mar 28, 2013 | Dell OptiPlex 740 PC Desktop
My desktop has an orange light no beep sounds when starting it won't boot up the back where ethernet plug goes is orange too the fan makes a burning smell also
Orange light usually means the harddrive or computer is processing and loading, But it can also mean that there is a problem with the hard drive. Start your computer and wait. If you see orange light it means its working to boot up, it might take a while, you might see your screen black for a while but eventually will work.
To fix this problem you need to upgrade more hard drive space, RAM memory and processor speed
Nowadays a computer should have a minimum of 2GB of RAM memory, at least 120GB of Space, and about 2.0Ghz of processing speed.
You can also buy great refurbished computers which are cheaper. Most of them come with 4GB of RAM memory, 250GB HD Space and 2.5Ghz processing speed.
May 24, 2011 | Dell Computers & Internet
We need To Install Another Processor But The 2nd Slot Doesn't Work To new one That Work In the other slot
hi,
Welcome to Fixya
By the way have you purchased the VRM module . If you are about to upgrade the server with second processor you should have VRM also . Without VRM , the second process wouldn't work and it will light out amber LED(Orange) . Now If you have VRM then just swap the processor and check. That is check whether the second processor works while insert it in first processor slot. If it works then it relates to motherboard issue .
Thanks
Jan 27, 2011 | IBM x3400 Server
When i switch my ps3 on it switches off and lashes green and orange light
There is no orange light built into the PS3 system, you may be mistaken orange for red. If it's bright it can be hard to tell the exact color.
Does the lights blink? If so, you have the infamous YLOD, aka. Yellow Light of Death. This is the number 1 cause of pS3's dying. It is an overheating issue linked to your CPU and GPU (the processor chips) You will need to find a local PS3 repair shop who can repair this. Do not try to attempt repairs seen on the internet yourself. You could make things much worse and render the unit totally unresponsive. The repair process takes about 3 hours.
It can be fixed.
IS THERE A DISC STUCK INSIDE?
If you have a unit that is not backwards compatible, any non 60g or 80g then you
can retrieve your disc.
Power off the unit using the toggle switch on the back. Hold down the 'eject'
button and turn the toggle switch back from off to on. This will run a fan test
and eject your disc. Remember, this will only work on the 20, 40g models. Not the
backwards compatible units with the 4 usb port holes and the memory card slots.
Jan 20, 2011 | Sony Playstation 3 (PS3) Console
Hello. My desktop seemed to have completely froze (power was running and sounded normal, but did not respond to mouse or keyboard commands), so I shut it down by holding the face button. Now when I power...
Please Clean Processor Fan By removing dust from the cooling went ( make sure the air should be transfer through the cooling went from the fan) Then Apply the Good heat sink Paste on the processor then try
In this process please don't touch the processor fan while the sys is powered on or running
Dec 26, 2010 | Compaq Presario SR1000T (568657) PC...
Computer wont turn on orange flashing light on the power button
Here is a web site that may help solve your problem.
http://www.randomfix.com/2007/04/19/dell-dimension-%E2%80%93-flashing-orange-power-light/
Oct 23, 2009 | Dell Dimension E510 PC Desktop
Hi I opened a work computer Dell GX260 to clean it out as a favour for my boss. I've removed the processor fan in the process. I then decided that I don't have the right equipment to properly clean it....
You confirm all the connectors are properly connected. Check the power supply connector and the power button connector. Remove the cpu fan connector and refix it properly. Ther is no other chance for failure.
May 05, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
Computers & Internet Logo
13 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
