Question about Sewing Machines
Necchi 270 breaks thread
5 Suggested Answers
  • 1116 Answers
SOURCE: Hi I have broken the lid on my necchi 270
You will have to contact a Necchi dealer to see if this is available.
To locate your nearest Necchi Dealer us at 1-800-525-9987 ext. 4
Posted on Mar 01, 2010
bargainbox
  • 1388 Answers
SOURCE: Threading a necchi 537l
There are several Necchi models (and loads more) threading guides shown here, it may well be you can find one very similar to help.
Threading Guides
Posted on Mar 17, 2010
RichSew
  • 184 Answers
SOURCE: why does the thread keep breaking ?
The most common reason is the needle not inserted correctly (backwards), other causes can be burrs on the needle plate opening or burrs on the parts in the bobbin area.
Posted on Jun 03, 2010
SOURCE: My Necchi 4595 has never really worked
I also own 2 necchi sewing machines, my mechanical is a 4595,,
lower thread tension
to test the bobbin tension, remove the bobbin case & bobbin & hold it by suspending it byb the thread, **** it once or twice, if the tension is correct, the thread will unwind by about an inch or two.
if the tension is too tight, it does not unwind at all, if the tension is too loose, it will drop too much.
to adjust the tension,, left is loosen & to the right tighten
thread breaks
rethread the machine making sure to get all thread guides
top thread tension usually 3 or 4
replace needle- make sure the needle is inserted correctly
some needles don't work with some thread, here's a tip
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
Posted on Nov 17, 2010
I need a diagram of how to thread it or a problem solver the thread eeps breaking at the needle
Search the internet for:
Manufacturer + Model + the word "Manual"
or search YouTube videos for "sewing machine threading." You may not find your exact machine, but many machines have similar threading patterns. Be sure to raise the presser foot before threading the upper thread so it will seat properly in the tension disk.
If the thread is breaking at the needle, it could be several problems:
Threaded incorrectly--#1 cause
Upper tension too tight
Install a brand new needle compatible with the fabric & thread
Make sure the thread is not too large for the needle eye
Avoid old, fuzzy, bargain bin thread
All About Needles
Dec 24, 2015 | Necchi Sewing Machines
How to thread a NECCHI royal series machine 3204FB
How to thread a Necchi model 535 FA sewing machine [now ...
? 8:52
https://www.youtube.com/watch?v=CEGuA6kZG4A
Jan 8, 2012 - Uploaded by Wren Paasch
How to thread a Necchi model 535 fa sewing machine. I'll make a separate video to show how to wind a ...
Necchi 3215 Sewing Machine Demonstration - YouTube
? 0:40
https://www.youtube.com/watch?v=ulo4kvnj3PU
Aug 9, 2011 - Uploaded by GoldCoastSewVac
... explains what the Necchi Heavy Duty Sewing Machine can sew and ... How to thread a Necchi model 535 FA sewing machine [now with ...
How to Thread a Necchi Sewing Machine (with Pictures ...
Dec 14, 2015 | Necchi Sewing Machines
How do I adjust tension on a Necchi Lydia 510 sewing machine?
loops under fabric means top tension needs to be tightened
try cleaning the top tension dial with some unwaxed dental floss and see if that helps. if it doesn't then the tension dial may need to be replaced
also check to make sure the spool of thread is not getting caught on the spool holder
also try a new needle--one that is correct for the fabric being sewed
Feb 10, 2015 | Necchi Sewing Machines
Necchi sewing machine
There are a number of things that could cause this.
Needle installed with flat in the wrong direction.
Excessive thread tension,top or bottom.
Lack of lubrication. If the machine can do anything more than a straight stitch the mechanism can gum up and not move the needle correctly.
Here is a link to threading directions.
Necchi 3537 Sewing Machine Threading Diagram
Aug 03, 2014 | Necchi 3537 Mechanical Sewing Machine
My Necchi 4595 has never really worked properly,.,.,the lower thread (bobbin) is very loose and then the thread breaks,,,I've tried to adjust the tension, but maybe I'm doing that wrong.
thread breaks
Nov 16, 2010 | Necchi 4595 Mechanical Sewing Machine
Why does the thread keep breaking ?
Jun 02, 2010 | Necchi 6011
Mar 01, 2010 | Necchi Sewing Machines
The top thread keeps braeking. This is a recent problem. I use singer needles. I live in South Africa. I dont get necchi needles.
Usual causes are:
Weak or inconsistent thread..
Threaded wrong.
Needle installed backwards or not seated.
Incorrect tension or contamination in the tension control.
The key to finding the problem is to manually turn the machine through cycles and watch at what point the thread breaks or is strained excessively.
Dec 14, 2009 | Necchi Sewing Machines
I have a Necchi supernova Julia 534
sounds to me like a tension issue, also are you using rayon or polyester thread, this is just a recommendation for those types of threads,,,,,,but please check your tension, is it only doing it during automatic
Jan 21, 2008 | Necchi 3101 Mechanical Sewing Machine
Sewing Machines Logo
14 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
