Question about Dometic 3313470.002 Refrigerator Cooling Unit 605 RM4601 RM2652 RM3662
Dometic ref. shuts off from time to time and check light comes on.
    Top Expert:
  • Dometic Master
  • 8,688 Answers
Check gas pressure if LP use
Posted on May 30, 2016
2 Suggested Answers
SOURCE: DOMETIC REF
Check your 5 amp fuse on the control board on the outside of the trailer where the condensate drain comes out of the side of the r.v. -- while you're at it, check the 3 amp fuse also.
Posted on May 27, 2009
Dometic Fridge 2652 will not stay lit or relight in gas mode
check house batteries needs 12 volts to control board
Jul 13, 2012 | Dometic RM2652 Refrigerator
I HAVE A 1997 FLEETWOOD RV WITH ORIGINAL DOMETIC RM2852 REF IN IT. ALL POWER SEAMS TO WORK (LIGHTS ARE ON PLUGED IN OR OFF OF GAS BUT THE WHOLE PROBLEM IS THE REF OR FREEZER WILL NOT GET COLD
Largest problem is with the cooling unit going bad on these unit at about your units age.
But first
check your 12 volt fuses and make sure both the fuses in the back of the refer and the fuse in the power distribution panel are good
Must have 12 volt for the gas to work
Sep 23, 2009 | Dometic RM2852 Refrigerator
Light stays on check when on ac on Dometic Fridge
Here's some info regarding the check issue you're experiencing:
Problem. Unit controls go to "check"
There is a common problem with, Dometic RM2807 or RM2811 and most later model Dometics with upper controls. The refrigerator's "check light" comes on or the refrigerator just shuts down seemingly for no reason. Another common problem occurs while on 120v. The refrigerator might switch to gas or just shut down even while you have a good 120v supply.
Answer. Dometic RV refrigerators with the push button upper control boards have a problem with the main power boards. The power board components are encased in yellow epoxy, reducing heat transfer. This tends to cause them to run too hot which in turn can often cause the power board to fail completely or cause problems such as listed above. We have found the only effective repair is to replace the power board. We do not use the Dometic replacement as they too can fail. The Dometic replacement also requires you to rewire the board and gas valve. The only board we recommend is the P-711. The P-711 not only will fix these problems but does not require the rewiring. It uses all the standard wiring. See Power Boards
Hope you find this helpful and best regards!
Jun 27, 2009 | Dometic RM2652 Refrigerator
RV refrigerator works fine on AC power. Burns for 30 seconds on gas power then shuts off.
tap on the gas valve with a wrench,not too hard but not too light about 10 times,the valve is probably sticky from not being used,re-light and see what happens.
May 10, 2009 | Dometic RM2652 Refrigerator
DOMETIC REF
Apr 19, 2009 | Dometic RM2652 Refrigerator
My check light keeps coming on my dometic ref in my 5th wheel
I have had this problem also. My experience has been that the propane line to the frig has air in it, especially after not being used for a while. Here's what I do:
1) Make sure the propane tank valve is open.
2) Light one of the burners on the stove. This may take a while but keep the gas on and a lighter at the burner. This is safe becuase as the air purges from the line it just blows the flame (from the ligher) around. Then when the air is purged the gas lights. Let the burner run for a couple of minutes. This sounds a bit odd, but what you are doing is bringing the "gas" close to the frig. The frig does not have to purge all that air as you have already done most of the purging by getting the burner to light. The facory setting for the frig is to stop trying to light after 45 seconds, and the "Check" light comes on.
3) Now try the frig. It may a couple times, but it should light and work fine.
I have found that this technique also helps with lighting the hot water.
Apr 05, 2009 | Refrigerators
Rm 2611 will not run on gas when going down the road
Your voltage supply is being interrupted. The DC voltage needs to be at least 10.5 to work properly. If you are switching from shore to gen this can cause the interuption also. I presume the gas supply is staying on when you are traveling.
Jul 28, 2008 | Dometic RM2652 Refrigerator
Dometic 3313470.002 Refrigerator Cooling Unit 605 RM4601 RM2652 RM3662 Logo
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
