Question about Mitsubishi WD Televison & Video
How do i change the input on my mitsubishi tv model # wd-52527 with out a remote
I don't have a remote and need to change the input on my tv
SOURCE: WD-52628 Mitsubishi - change inputs
We had the same problem. Luckily, we had a service contract, so it was serviced yesterday. The fix involved the service guy going through a "service menu" and resetting the TV that way. He was not "allowed" to tell me how I can access the service menu, however. I do plan to research this on the internet in case it happens in the future. It is basically a software/computer problem, and unplugging the TV isn't enough to clear it unless the TV is unplugged for "a long time." The technician said the length of time depends on the condition of your capacitors. Anyway, as a temporary fix, he showed me that you can go into the PIP mode. The device toggle for PIP apparently did still work with mine, so I was able to switch the device on the secondary picture and then switch it to primary, then toggle the PIP off. Good luck!
Posted on Mar 26, 2008
SOURCE: Mitsubishi Projection TV Power Supply Board assistance - Model # WD 62525
Mr.Marxxx you need to let one of your friends fix it for a small fee.Just like everyone else does.
Posted on Jul 29, 2008
tvtek
  • 1284 Answers
SOURCE: need to align my mitsubishi wd-73733 dlp tv
We TV technicians don't go into alignment unless absolutley needed. I would stray away from alignments period unless you understand all of the ramifications that come with them.
Posted on Jan 08, 2009
SOURCE: Mitsubishi HDTV model wd-62525 has
It has been renamed.
Posted on Mar 22, 2009
Slinteriors
  • 8617 Answers
SOURCE: tv color not bright enough and just replaced lamp
Clean the small mirror in front that projects the image onto the rear mirror. The Rear mirror always stays good but the front small mirror gets dusty and the colors and bright levels get affected and appear dim.
Posted on Jun 10, 2009
How do I change inputs on my mitsubishi projection tv
You need the original remote. there is 3 up/down buttons, one is volume, one is channel, the other is input. The input up/down will scroll through all the inputs. Some of these TV's don't have it on the front panel
Nov 27, 2013 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-60735 Control issues
This set has aside from the recessed front reset two more done with the Mitsubishi remote.
The soft reset "should" be with set on Menu, 1,2,3, enter
The hard reset requires a 4 digit number code and is based on model number and also done with the Mitsubishi remote--try to see if soft reset works at all on this model.
Mar 31, 2012 | Mitsubishi WD-60735 Projection Television
Changing channel from cable to input
Your control TV switches at the front are bad, need to replace
May 09, 2010 | Mitsubishi WD-62725 62" Rear Projection...
I have a mitsubishi WD-52527 TV with error code 45
You have to pull the light engine to get to the pbs fan it is the one located closest to the lense on the light engine. you should be able to see if the fan is turning without removing the engine.
Sep 06, 2009 | Televison & Video
When accessing the Device Menu, the TV turns off
I would contact Mitsubishi and see if there is s software upgrade for this model. You can contact them at 1-800-332-2119.
Hope this helps,
Skyassoc
Jun 28, 2009 | Mitsubishi WD52527 52" Projection HDTV
No frikin' sound!
Either way the first thing to do if you haven't already is to pull the plug and wait a minute and plug it back in. This will cause the TV to do a hard reset much like re-booting a computer. You can also accomplish this by pressing the reset button on the front panel on some models. If you still have no sound confirm you're getting it from the source. Check for sound with alternate sources like a DVD player or video game.
michtech
Feb 15, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsu-wd-52527 lamp replacement
The lamp in this TV is very easy to change. I recommend to use your owners manual, but the front cover snaps off, using screw driver open lamp door, unscrew lamp, pull out with handle, make sure lamp is cool. Replace, follow onscreen display to reset lamp hours. Use remote to enter information.
Feb 23, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
65 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
