Hisense lcd3203eu Tv starts autosearch automatically and scart2 option (digital tv) has to be manually changed back. Sometimes it happens every five minutes, sometimes the problem doesn't come up for days.
SOURCE: HISENSE TL2020
is it in demo mode
Posted on Dec 29, 2007
SOURCE: Sharp aquos lcd screen goes blank
i was having these same problems with the screen going black, and i found that when i hit the back of my tv it would work sometimes. so, i improvised on some of the advice on this page and so far no problems. here is what i did (its very easy):
1. lay the tv on the floor and take off the back panel. (i think 12 screws)
2. on the right side of the tv (as you are looking at the back) you will notice a large metal covering that is held in place by 6 screws. unscrew these and remove the metal cover.
3. you will notice that the three screw holes on the left side of the board have some sort of metal or solder around them, in sort of a star pattern. when i looked closely i noticed that most of the metal (solder) was tarnished, or kind of blackened. (this must mean that the ground screws werent getting a good connection and this would explain why it would work sometimes when i hit it because it would vibrate the screws enough to get a good connection! )
so, take a pencil eraser and erase all the black or tarnish off the metal surrounding the screw holes. thats it! (to be safe i took some sandpaper and cleaned up the screw holes on the back of the metal covering, but i dont know if that was necessary)
at this point i followed another gentleman's advice to do a hard reset. this involved unplugging the 8 connections although i dont know if this was really necessary because i believe my problem was a ground issue. i did it just to be safe. his advice is on this site if you want to do this step.
4. i put everything back together and it worked! i performed a soft reset at this point which puts your tv back to factory settings. just go to menu>setup>reset>return to factory settings? yes
this will turn your tv off and back on. that's it. so far so good for me.
Posted on Dec 18, 2008
SOURCE: 55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Posted on Sep 28, 2009
  • 148 Answers
SOURCE: tv turns on but no picture for about five minutes
The caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once insidet here will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Have fun becoming an overnight tv mechanic lol! If this helped (or not)please rate, thank you!dcefcd6.jpg
Posted on Feb 04, 2010
SOURCE: My Samsung SK01 42" TV
Power board assy' is defective. Check those bulging caps right into secondary circuit.
Posted on Jun 08, 2011
Hisense lcd3203eu keeps changing channels by itself Iv no remote so it's not that.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Sep 20, 2016 | Hisense Televison & Video
Am trying to change fromt tv to dvd using universal remote the brand is hisense tv what do i do
You have to set it with its setup code. If you wish to get more details, check this site. Pull up older posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter."
Mar 29, 2013 | Televison & Video
I need a remote control code for a hisense tv
Hello
Four digit universal remote codes for Hisense TV are:
0073 0182 0216
Five digit universal remote code for Hisense tV with RCA RCR312W remote control is:
10748
Sep 14, 2012 | Hisense LHDN32V66AUS 32 in. LCD TV
Need a universal remote control code for Hisense tv
Hello
0073 0182 0216
10748
Dec 12, 2011 | Hisense LHDN32V66AUS 32 in. LCD TV
Unable to play DVD's
Hi, It is entirely possible that a couple of conditions could exist.
1) the DVD may support progressive output and the TV may not
2) the TV input could be defective or the DVD output could be defective.
Possible tests are -
You could test the TV input by substituting the dvd with another appliance known to be working (say a VCR. etc). the Y input (Green) on the TV only needs to be supplied with a composite output (yellow plug). If you see some sort of response from the picture then you can confirm the tv input is at least working.
Alternatively, try a different input/ output combination between your DVD/TV (Composite signal)
Mar 19, 2010 | Hisense LHD3204US 32 in. LCD HDTV
How to connect sound system to Hisense LCD tv
I phoned the help line at Hisense, they stepped through the set-up - its all good now
Dec 30, 2009 | Hisense TL3000 30 in. HD-Ready LCD...
Universal remote wont work on hisense tv TC 1828E
You may have to try a different universal remote control. All universal remote controls do not contain all possible codes.
Nov 26, 2017 | Televison & Video
INPUT GOING CRAZY
It could well be the accumulation of dirt/dust behind the buttons causing them to stick. If you are able to carefully remove the board that the buttons are located on and use a cleaner that will de-grease at the same time. Be sure that everything is dry as can be before re-assembling and then check if the problem persists. If you are not capable of doing this trust a competant technician. Hope this helps.
Aug 04, 2008 | Hisense TL-3220 Television
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
