Question about Dryers
Kleenmaid gas dryer
Just turned it on and no heat, just blowing cold air, checked all the connections all good
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,069 Answers
Possibly a bad gas solenoid
Posted on Jul 28, 2013
SOURCE: DRYER BLOWING COLD AIR-NOT HEATING UP
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
I hope this helps....
Posted on Jan 21, 2009
jsrock516
  • 5911 Answers
SOURCE: kenmore model 76712 does not blow heat just cold air
The following link explains how to troubleshoot and dryer "no heat" problem and the common causes:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Read through the link thoroughly, paying particular attention to the section that discusses proper ventilation. Most dryer heat related problems are caused by insufficient air flow which, in turn, causes the dryer to overheat to failure. More commonly, the Thermal Cut-Off (TCO) fails. You will need to check all the components mentioned in order to be sure. If you haven't had your dryer ventilation cleaned or inspected in a while, now would be a good time to do so. Failure to correct any potential existing problems, can cause premature failure of any parts you replace.
If you have questions, or require additional assistance, please let me know, so I can provide you with a viable solution. i hope this helps you.
Posted on Jan 22, 2009
  • 98 Answers
SOURCE: the tumble dryer is work but is only blowing cold air
sounds like a heating element. not to hard. remove the back and its is right there.
Posted on Jun 07, 2009
  • 15 Answers
SOURCE: my kenmore dryer is blowing out cold air
Make sure that both poles of your circuit are live - An electric dryer uses 220 volts to the heating element, but taps into only one pole (110 volt) for the motor that spins the drum. Check your circuit breaker to make sure that neither pole has tripped.
Posted on Jul 20, 2009
SOURCE: the dryer only blow out cold air.
When I turn the dryer on, only cold air blows out. There's no heat. I cleaned out the vents? What do you think is my problem> Thank you very much. K
Posted on Sep 13, 2009
Kenmore 400 series model # 110.77422600 will not heat when dryer is turned on only blows cold air
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Oct 06, 2011 | Dryers
Drier has no error codes will not heat spins and blows cold air has good 220 volts
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 23, 2010 | Samsung DV337 Electric Dryer
Estate by Whirlpool. TGDS680EQ3. Dryer turns on but air blows cold. Any insights?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 04, 2010 | Estate TGDS680EQ Dryer
Whirlpool gas dryer blows cold air. took back panel off cleaned lint out. Took front cover off, turned dryer on gas igniter does not heat up, or glow model # lgr4634jq0
heatman101
Oct 09, 2010 | Dryers
Cold air
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 14, 2010 | Dryers
No heat in gas dryer, gas good, elec good??
if the heat is on when the dryer is cold then shuts down after 15 to 30 minutes and doesn't lite for a long while you have bad gas coils,the gas should come on until it hits temp. then it shuts down,when the dryer calls for heat it will turn back on,if it stays on for short periods of time you might need to clean out the dryer,this will shut the gas down to soon,you need to clean out the duct that the lint filter slides into,blow out the vent line,make sure the air is blowing outside with nothing blocking it and vac out the inside of dryer where the motor is
Mar 12, 2010 | Maytag Dryers
Gas dryer wont heat up, blows only cold air.what would cause this
Could be a bad hi limit thermostat. Could be a bad glowbar ignitor. Check the glowbar ignitor at the gas valve, is it glowing bright orange/red? If not. Replace the ignitor.
Jul 22, 2009 | Whirlpool Dryers
Kenmore model 76712 does not blow heat just cold air
Jan 22, 2009 | Kenmore 75962 Gas Dryer
The dryer only blow out cold air.
Oct 18, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
60 people viewed this question
Top Dryers Experts
