Question about HP Computers & Internet
Overcharge when i charge it in a hour. the screen not com up..
    Master:
  • 663 Answers
Remove the battery and use the ac adapter only and turn on your computer. If it turns on just fine then put the battery back and try turning it on with the battery and charger plugged in. if it doesn't work, then replace the battery.
If after removing the battery and the computer still doesn't turn on with ac adapter only. then the charger or the motherboard is defective.
David
Posted on Jul 28, 2013
How to charge
• IMPORTANT: This unit is delivered partially charged.
Plug into an extension cord FOR 40
hours before using.
You cannot overcharge the unit using the AC charging method.
• To recharge this unit, use only the supplied AC charging adapter.
• All ON/OFF switches should be in the OFF position when the unit is charging or not in use. Make sure all switches are in the OFF position before charging. Here is the instruction book:
http://ecx.images-amazon.com/images/I/81US%2Bom6xKS.pdf
here is the booklet.
Jul 21, 2014 | Stanley Tools 500W Portable Power Station"
Will 18 volt black & decker charger over charge battery
Hello Howard, There are two different kind of cordless drill chargers. One is a smart charger that will not overcharge your battery. It usually has a stand alone base that the battery plugs into and sometimes may have a red and/or a green light to let you know it is charged. This charger will stop charging when the battery is fully charged after an hour or less. The other one is a dumb charger that can overcharge your battery if left on the charger too long. This charger usually has a square or rectangular transformer that plugs directly into your wall receptacle. This charger may take up to eight hours to fully charge your battery and will continue to charge until you unplug it.
Oct 04, 2011 | Black & Decker & Cordless Drill
Someone gave me a pronto m51 sure step motorized wheelchair but no manual was given..my question is: Is it safe to charge the battery overnight? Is there any danger of overcharging? If anyone knows for...
Jo, nope you are safe. Most of the chargers are designed to cut off and go into trickle charge once they sense that the batteries are fully charged. The problem with overcharging comes after 18 hours or so. You should never leave the charger plugged into the chair for more than 24 hours. On the M51 the charger is built into the chair so just plug it in when you go to bed and unplug it when you get up and you'll be ok. You can check for full charge by looking at the charger there should be a red light and a green light when fully charged. Hope this helps
Sep 08, 2010 | Invacare Supply Group Invacare Pronto M51...
How long should you charge ur f&p voyager mobility scooter..after a trip of say 5-10 km ...i dont want to overcharge it and fry the new batteries.(2x 20 amp hr)
Hi. 20 amp hour batteries are rather small for one of these machines. You can fit up to 55 amp/hour batteries in these.
These machines have to have the programming changed for different charge rates for different batteries,e.g. Wet cell, sealed lead acid or gel cell.
These machines have a fully automatic charger that drops down to a float charge after the batteries have been charged. You cannot overcharge them. At the very least leave the machine on charge overnight after each use.
Batteries are built to do so many charge cycles, and the more they are discharged while using them the less cycles you will get. If you only use 25% of a batteries reserve you will get more cycles than if you use say 75% of a batteries reserve.
Good luck. Neil.
Feb 22, 2010 | Health & Beauty
For how long do you charge a 9.6V NiMH Battery Pack 700 mAh? It says don't overcharge, but can't find any info to instruct what overcharging is!! It goes to a remote control car made by Maisto. It is a...
There are too many unknown variables in this. One is the charger that you are using. Two is the amount of charge in the battery when you charge it. These are things you must know. However with new chargers you can be sure they wont over charge the battery. If you are still worried about it, put it on charge and check it every hour or so and don't go past 8 hours.
Oct 22, 2017 | Maisto Toys
Battery & charging Problem on my LG KS360
Is the phone still under warranty? if so I would take it back to be replaced. It does sound like the battery is bad if loosing power that fast. You can overcharge the battery and that will lessen the battery life.I've done that before.
My LG VX9600 I'm able to change the screen settings for when it is charging, maybe yours was changed somehow, check your Settings & Tools / Display Settings. I hope this helps.
Aug 14, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
My screen went dim.
i did the same and got very annoyed i'd broken it. pretty much gave up on it until i needed a date from the calender some months later and once the battery had drained it seemed to fix itself. i now only charge it for an hour or two at a time
May 07, 2009 | Palm Z22 Handheld
How to repair/fix an overcharged L6?
I have overcharged my L6 for 8 hours now its not working
Jan 10, 2008 | Motorola Mobility L6 Cellular Phone
Computers & Internet Logo
15 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
