Question about AEG U3100-4 Electric Double Oven
AEG Competence U3100 trips breaker when up to temperature
Our AEG 3100-4 trips the dedicated breaker, immediately when it gets up to temperature. Element was recently replaced when it did it the first time but it still does it. Thermostat doesn't trip breaker when turning on and then turning down to hear the click. Any ideas? Faulty new element, thermostat, breaker, control board?
SOURCE: Oven cuts out after ten minutes and comes back after cooling down.
We have the same problem with our oven, AEG B2190-1.It started on on Christmas day[worst day of year]gets up to temperature after 10-15 minutes cuts out everything switches off until the oven has cooled down, The oven is only 18 months old. We have been told that it is a thermostat problem.
Posted on Jan 09, 2007
  • 1462 Answers
SOURCE: Main oven problem
I suspect not the oven element at fault. you only way forward is to actually test the resistance of the element to earth with a megga if you can beg the use of one. be cautious about the result as on occasion, elements are only faulty to earth when hot. another way to test if you are cdarefull, is to connect the element to mains independently of the oven and see if the rcd trips
Posted on Sep 22, 2008
barkencoa
  • 3463 Answers
SOURCE: AEG Competence Double Fan Oven Fault
Sounds like oven element is faulty, disconnect it and try again, if it does not trip, then it is definately the element..
It is easy to replace.
Plz leave feedback.
Posted on Dec 09, 2008
barkencoa
  • 3463 Answers
SOURCE: AEG U7101-4 Top Oven tripping the fuse after a few minutes
It is more than likely the oven element, as it gets
hotter the insulation in the element is breaking down and causing the trip to operate..
Remove the panel at the rear of the oven and you will see the element there, undo the screws and pull the element towards you, carefully, detach the 2 wires and remove the element.
Be careful not to lose the 2 wires behind the oven rear.
Replace with new element.
Cannot give you a part number, you will have to go to aeg web site.
Posted on Dec 12, 2008
barkencoa
  • 3463 Answers
SOURCE: AEG Competence Oven not working
If you are certain that the element is o/k, and it is not heating, then thwere are 2 possibilitues.
1- the oven thermostat could be faulty, whereby it is giving a feed to the element.
2-some ovens have a fan only setting, as well as heat and fan, make sure that it is not on a fan only setting.
Hope this helps.
Posted on Feb 05, 2010
Why does it trip breaker?
There probably is an internal short.
Oct 04, 2015 | Neff Ovens
Tried removing element from bottom oven, with the bottom oven selector on to provide some light. As I pulled the element out one of the terminals touched the casing and caused the light to go out, the...
More than likely you have tripped the house circuit breaker or fuse. If you know where the house fuse box or circuit breaker panel is check to see if either one side of the two 240 fuses is blown or one of the two tied together circuit breakers is tripped. If it is a breaker then shut off both breakers completely and then snap them both on completely or they won't reset. It is rare that an oven has a fuse internally. There can be thermal fuses but they will trip when the temperature is out of range.
Feb 25, 2014 | AEG U7101-4 Electric Double Oven
Went to switch oven on fan works when you turn the temp knob it trips the trip switch every time help
HI, Sounds like your from the UK
If you are referring to a trip switch as being equivalent to an American circuit breaker. (Electrical safety device designed to shut down power to an electrical appliance). Then we are on the same page.
Do the following diagnostic procedure:
1 SHUT DOWN THE POWER SUPPLY TO THE OVEN. I.E. THE TRIP SWITCH/CIRCUIT BREAKER.
2 Open the oven door and look very carefully with a flashlight at the heating element. Look at the the entire element. If it blew (similar to when a light bulb blows) you will
find white powder around the hole in it or it will be completely broken, or have bubbles in it. Some indication like that. If so it has failed and must be replaced. It is probably tripping the switch because it is shorting out somewhere. There is also the possibility that the internal wiring connectors to where the element is mounted into the oven walls is broken off and short circuiting against the oven chassis (walls). That being the case, it may be just a wiring repair in which you install new appropriate electrical contacts and re-connect the element.
Hope this helps,
Happy New Year,
Mark
Dec 31, 2010 | AEG B3101-4 Electric Single Oven
My caloric over keep tripping my breaker. seem to happen only when it is warm
I suspect it is the oven element causing the problem, as it gets hotter, the insulation resistance is probably breaking down, and causing the trip to operate.
Oct 31, 2010 | AEG B2100-4 Electric Single Oven
Dec 12, 2008 | AEG U7101-4 Electric Double Oven
Plz leave feedback.
Sep 22, 2008 | AEG B2100-4 Electric Single Oven
Warming up problem
This has nothing to do with the element. This oven should only be serviced by a qualified technician. If you were one, you would already know the solution. You need to go into diagnostic mode to determine if it is the solid state relay or the cc thermocouple. After resetting the hi-limit more than once, it will also need to be replaced.
Aug 24, 2007 | TurboChef TORNADO Electric Oven
Dec 10, 2006 | AEG B2100-4 Electric Single Oven
AEG U3100-4 Electric Double Oven Logo
Top AEG Ovens Experts
ashburton
Sal DeAngelo
Steve
Are you an AEG Oven Expert? Answer questions, earn points and help others
