Question about Sony Bravia KDL-40V4100 40 in. LCD HDTV
When I go into settings. the picture is good. When I go out of settings picture is blurred. Tinman824@hotmail
SOURCE: Sony Bravia TV automtaically goes on standby.
Probably the main board. This has a 1 year mfc parts and lobor warr. I would contact Sony for the nearest auth servicer. If you open it you will void the warranty.
Posted on Apr 26, 2009
SOURCE: My Sony Bravia KDL-40V4100 JUMPS TO STANDBY MODE
The caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once insidet here will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Have fun becoming an overnight tv mechanic lol! ....If this helped you (or not) then please rate, thank you!
Posted on Feb 03, 2010
SOURCE: Bravia KDL-46VL130 TV: Our Sony KDL-46VL130 picture is streaking and some...
That symptom may cause by the main board or t-con board, I suggest you do software up grade first.
Posted on May 07, 2010
SOURCE: I have a Sony KDL-40V4100, constantly hearing clicking noises
Could be the power board or main board defective, but I suggest you do firmware update first. Go to http://esupport.sony.com/US/perl/swu-list.pl?mdl=KDL42V4100&LOC=3#div_pos_30 download the software.
Posted on May 09, 2010
Testimonial: "I will try to update the firmware. Thanks !"
SOURCE: Have a Sony Bravia KDL-40v4100 Flat panel, had a
Check the main AC fuse, it may have blown because in the TV it has MOVs for surge protection that are installed after the main AC fuse, when the MOVs conduct, it will cause the main fuse to blow to stop any surge from coming through the second time.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Please post back what you find.
Posted on Jul 27, 2010
May 22, 2014 | Sony BRAVIA KDL-40BX420 40" 1080p 1920 x...
Feb 11, 2014 | Sony Bravia KDL-40V4100 40 in. LCD HDTV
Sep 19, 2013 | Sony BRAVIA KDL-40V3000 Television
Apr 01, 2012 | Sony Bravia KDL-40V4100 40 in. LCD HDTV
Apr 10, 2017 | Sony Bravia KDL-40S4100 40 in. LCD TV
May 12, 2010 | Sony Bravia KDL-40V4100 40 in. LCD HDTV
May 08, 2010 | Sony Bravia KDL-40V4100 40 in. LCD HDTV
Dec 14, 2009 | Dell E153FP 15" LCD Monitor
Jun 09, 2009 | Sony Bravia KDL-40V4100 40 in. LCD HDTV
Dec 20, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Jun 18, 2014 | Sony Bravia KDL-40V4100 40 in. LCD HDTV
26 people viewed this question
