Casion fx 992s
Round
  • 8073 Answers
SOURCE: I have fix and deg on my fx 992s and I am only
Ok. Press [MODE] key three times until you see a screen that shows Fix SCI and NORM. Under FIX you have 1, under SCI you have 2 and under NORM you have 3.
You cannot remove FIX, unless you replace it with another display MODE (SCI or NORM or ENGineering).
You cannot remove DEG unless you change angle unit to RADians or GRAds.
To set angle Unit You start by pressing MODE twice to get a screen that displays DEG, RAD and GRA and below them 1, 2 , qnd 3. If you press 2 the angle unit will be set to Radians. DEG will disappear, but RAD will be shown.
Whatever the display format for numbers (FIX, SCI, NORM, ENG) you can always enter numbers of any length. It is their displaying that is affected by the FIX,SCI, etc. mode.
If you want more than 1 decimal digit, press [MODE] three times, then select 1: FIX. You will be asked to select the number of decimal digits (from 0 to 9). You could take 2, 3 or 4, or anything you want.
  1. To summarize: Indicators on screen reflect the configuration or mode you are in.
  2. They can be replaced by others but you cannot clear the screen of the indicators.
  3. You can select the number of decimal digits in your results,
  4. but there is no restriction on the numbers you enter.
Posted on Mar 03, 2010
Testimonial: "Thank you!!!!!!!!!"
  • 126 Answers
SOURCE: where is the comma on
You can download the manual at Search-Manual-Online.com, It is in a PDF file, so you can save it on your computer.
Posted on May 02, 2010
  • 102366 Answers
SOURCE: On casion Scientific fx-300MS, how
Press the S--D key to switch between decimal and fraction forms.
Posted on Nov 10, 2010
  • 102366 Answers
SOURCE: my casio fx-992s is showing
The DEG is merely indicating that the angular mode is set to degrees. If you want to change it to radians or grads, press SHIFT MODE and make your selection.
Likewise, the FIX is merely indicating that the calculator is displaying numbers in fixed decimal notation. If you're not seeing any digits to the right of the decimal point, then you're in FIX 0 mode. To change it, press SHIFT MODE. You can choose FIX and the calculator will prompt for the number of digits, or you can select NORM.
Posted on Nov 29, 2010
  • 102366 Answers
SOURCE: How do you use the
Simply press SHIFT [pi] to insert the value of pi into an expression. For example, to calculate pi/2, press SHIFT [pi] / 2 =
Posted on Jan 20, 2011
How to make my degree button work?
I am sorry but the image does not show any Degree button.
To set the angle unit you have to press the Mode button twice before you arrive at the angle unit configuration. See the screen capture below.
Jan 16, 2014 | Casio Fx-992s Scientific Calculator
How do i make the degree button of my fx992s work?
PRIME FACTORIZATION USING CASIO FX-991ES PLUS
If it does not have the FACT key, you must factor by hand: Divide by 2, then by 3, 5, 7 etc.
Apr 24, 2013 | Casio Brand New-Fx-991es Plus - Scientific...
How and key to inverse
Look for a key marked [x^-1] or [1/x]. The marking may be on the key or on the face of the calculator. In the latter case you will have to press the SHIFT key first. Before you can calculate the reciprocal of a number the number must be entered.
Oct 23, 2012 | Casio Fx-992s Scientific Calculator
Casio fx 68 Scientific Calculator, Operation Manual
There does not see to be acalculator model FX-68 on the Casion web site. Here is the link to the available manuals. Find yours and download its manual.
Jul 16, 2012 | Office Equipment & Supplies
How do you use the pie button on a casion scientific calculator fx-83ES
Jan 20, 2011 | Casio FX83ES Scientific Calculator
My casio fx-992s is showing fix and deg on the screen. I think the "fix" is causing me a problem but I can't get rid of it. All my decimals are being rounded up to whole numbers! Thanks
Nov 29, 2010 | Casio Office Equipment & Supplies
Where is the comma on the casio fx-992s
May 02, 2010 | Office Equipment & Supplies
Casion Fx-300MS
If I understand correctly you result do not display any decimal.
If you want a fixed number of decimal digits (exemple 2) Press the [MODE] key a number of times until you reach the screen that displays Fix Sci Nom and under them the numbers 1 2 3
Press 1 to choose Fixed format followed by 2 for TWO Digits
3 decimal digits [MODE] ---------[1 ] (Fix) 3
Hope it helps.
Feb 13, 2009 | Casio FX-300MS Calculator
14 people viewed this question
k24674
jasbo
jasbo
