Question about Samsung SCH-i730 Pocket PC
Start menu I am trying to delete the "Recent Programs" from the start menu. Can someone help?
    Problem Solver:
  • 3 Answers
You have to go into the file explorer and look for the windows directory. Then go in the start menu folder to find the recent folder. Inside of that you should see the files you want to delete. That's how it works on my windows mobile phone.
Posted on Sep 04, 2007
I am trying to finalise payment on ebay for a hova-bator incubator . after i sign in my password it comes up you have hit a speed bump. and try again later . i have tried several times and get the same...
Try the steps below and they should help you.
First Step :
Click on Start button
Click on Run or under START TYPE HERE type the command "%temp%" without quotes (")
Click OK
A Window will pop-up ( Temporary folder )
Click on Edit from Menu bar and click Select All ( or short cut method to select all the files is Press CRTL + A
Press Shift + Del key to delete the files
Few files may not get deleted so skip those files as you can delete them later
( The files and folder listed in the folder will not harm any data/document/files on your PC as they are just temporary files and can be deleted )
Second Step :
Click on Run or under START TYPE HERE type the command "prefetch" without quotes (")
Click OK
A Window will pop-up ( Prefetch Folder )
Third Step :
Open Internet Explorer
Click on Tools on right side of window and select Internet Options
OR
Click on TOOLS from Menu bar on top and click on Internet Options
Under General TAB - Click on Delete button
Click on Delete Files button and click Yes for the message
Likewise Click on Delete Cookies, Delete History ( if you do not want the list of websites to be displayed when you type www and the website name in address bar ), Click on Delete forms
Click Close
( By doing this you will be able to get rid of any unwanted files and website data that is stored on your pc to make you access internet much faster )
For Mozilla Firefox
Click on TOOLS
Click on Clear Recent History
Select Everything from RECENT TIME
Click Clear Now to clear the temporary files and folder
Also, do not login for 3 hours atleast and then try to login.
Thank you for contacting FixYa
*Please rate this solution with Thumbs Up
Nov 23, 2010 | eBay Auctions
What is a second level menu that is accessed using a menu command?
Commands displayed in the start menu that have arrows on the right indicate that a submenu is available for a command. A submenu is a second-level menu.
Ex. "My Recent Documents" usually will have an arrow to the right of it. When you access your recent documents, you are actually accessing a submenu.
Sep 10, 2009 | Microsoft Windows XP Professional
My core speed drop always to 999,99 then 2000 then 1999 then 2500 and 2700mhz whats the problem ?? plzz help ??
some tips to increase your system performance
If you have an old and slow computer, do following to increase your system speed:
1- Disable Scan Disk
Click Start menu > Click run. In the run dialog box type: msconfig to open System Configuration Window. Then open "system configuration programs". In the General Tap click on Register and then check "Scandisk after error by shutdown disabled" to disable ScanDisk.
2- Disable auto start programs
Open System Configuration (msconfig) . click on the "Startup" tap and in the application list , Clear the check box for a startup item to disable it on your next boot.
3- Disable Windows Startup sound
Go to Start > Settings > Control Panel and then click on " Sounds and Multimedia" icon to open it. In the Sound tab disable Windows Startup sound.
4-disabe unused programs
Go to Start > Settings > Control Panel and click on "Add/Remove Programs" and uninstall old and useless programs.
5- Delete offline e-mails
Yes, offline e-mails especially e-mails with attachments can slow down your pc. Delete these e-mails.
6- delete temporary internet files
Temporary internet files can slow down your pc. In internet explorer click on tools menu and then select Internet Options and the click on " Delete Files and Delete Cookies" buttons to delete these files.
7- Defragment your Hard Drive
Defragment your hard drive every 10 days. To defragment your Hard Drive, click on Start menu > Programs > Accessories > System tools > Disk Defragmenter.
8- update your Windows
Turn on your Windows Automatic Update to have recent updates for your Windows.
do it in your system.Thankyou
Sep 04, 2009 | AMD Athlon 64 LE-1640 Processor...
Trying to install office 2007 but keep getting error code 1606 cannot find network location %APPDATA%. What can I do to fix this?
To resolve this issue, follow these steps:
  1. Click Start, click Run, type Regedit.exe, and then click OK.
  2. Locate and then click the following registry subkey: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders
  3. In the right pane, verify that the values are the same as the values in the following table. If each value matches the table, go to step 7. For Windows XP and for Windows Server 2003, see the following table. Collapse this tableExpand this table Value name Type Value data AppData REG_EXPAND_SZ %USERPROFILE%\Application Data Cache REG_EXPAND_SZ %USERPROFILE%\Local Settings\Temporary Internet Files Cookies REG_EXPAND_SZ %USERPROFILE%\Cookies Desktop REG_EXPAND_SZ %USERPROFILE%\Desktop Favorites REG_EXPAND_SZ %USERPROFILE%\Favorites History REG_EXPAND_SZ %USERPROFILE%\Local Settings\History LocalAppData REG_EXPAND_SZ %USERPROFILE%\Local Settings\Application Data Local Settings REG_EXPAND_SZ %USERPROFILE%\Local Settings My Pictures REG_EXPAND_SZ %USERPROFILE%\My Documents\My Pictures NetHood REG_EXPAND_SZ %USERPROFILE%\NetHood Personal REG_EXPAND_SZ %USERPROFILE%\My Documents PrintHood REG_EXPAND_SZ %USERPROFILE%\PrintHood Programs REG_EXPAND_SZ %USERPROFILE%\Start Menu\Programs Recent REG_EXPAND_SZ %USERPROFILE%\Recent SendTo REG_EXPAND_SZ %USERPROFILE%\SendTo Start Menu REG_EXPAND_SZ %USERPROFILE%\Start Menu Startup REG_EXPAND_SZ %USERPROFILE%\Start Menu\programs\Startup Templates REG_EXPAND_SZ %USERPROFILE%\TemplatesFor Windows Vista, see the following table. Collapse this tableExpand this table Value name Type Value data {374DE290-123F-4565-9164-39C4925E467B} REG_EXPAND_SZ %USERPROFILE%\Downloads AppData REG_EXPAND_SZ %USERPROFILE%\AppData\Roaming Cache REG_EXPAND_SZ %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files Cookies REG_EXPAND_SZ %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies Desktop REG_EXPAND_SZ %USERPROFILE%\Desktop Favorites REG_EXPAND_SZ %USERPROFILE%\Favorites History REG_EXPAND_SZ %USERPROFILE%\AppData\Local\Microsoft\Windows\History LocalAppData REG_EXPAND_SZ %USERPROFILE%\AppData\Local My Pictures REG_EXPAND_SZ %USERPROFILE%\Pictures My Music REG_EXPAND_SZ %USERPROFILE%\Music My Video REG_EXPAND_SZ %USERPROFILE%\Videos NetHood REG_EXPAND_SZ %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts Personal REG_EXPAND_SZ %USERPROFILE%\PrintHood PrintHood REG_EXPAND_SZ %USERPROFILE%\Documents Programs REG_EXPAND_SZ %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs Recent REG_EXPAND_SZ %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent SendTo REG_EXPAND_SZ %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo Start Menu REG_EXPAND_SZ %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
    Startup REG_EXPAND_SZ %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup Templates REG_EXPAND_SZ %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
  4. If any Name, Type, or Value does not match the table in step 3, right-click the Value name, and then click Delete.
  5. In the left pane, right-click User Shell Folders, point to New, click Expandable String Value, type the Name value that you want from the table in step 3, and then press ENTER.
  6. Right-click the value that you created in step 5, click Modify, type the value in the Value data box for the Value name, and then click OK.
  7. Locate and then click the following registry subkey: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders
  8. In the right pane, verify that the values are the same as the values in the following table. If each value matches the table, go to step 12. Collapse this tableExpand this table Value name Type Value data Common AppData REG_EXPAND_SZ %ALLUSERSPROFILE%\Application Data Common Desktop REG_EXPAND_SZ %ALLUSERSPROFILE%\Desktop Common Documents REG_EXPAND_SZ %ALLUSERSPROFILE%\Documents Common Favorites REG_EXPAND_SZ %ALLUSERSPROFILE%\Favorites Common Programs REG_EXPAND_SZ %ALLUSERSPROFILE%\Start Menu\Programs Common Start Menu REG_EXPAND_SZ %ALLUSERSPROFILE%\Start menu Common Startup REG_EXPAND_SZ %ALLUSERSPROFILE%\Start Menu\Programs\Startup Common templates REG_EXPAND_SZ %ALLUSERSPROFILE%\Templates
  9. If any Name, Type, or Value does not match the table in step 8, right-click the Value name, and then click Delete.
  10. In the left pane, right-click User Shell Folders, point to New, click Expandable String Value, type the Name value that you want from the table in step 8, and then press ENTER.
  11. Right-click the value that you created in step 10, click Modify, type the value in the Value data box for the Value name, and then click OK.
  12. Exit Registry Editor, and then restart the computer.
Sep 04, 2009 | Microsoft Windows Vista Home Premium with...
Delete icons in programs that have already been uninstalled.
You can open the "File Explorer" from start menu, navigate through "My Device" -> "Windows" -> "Start Menu" -> "Programs" and when you get there, you can delete the unwanted icons.
Apr 12, 2009 | HP iPAQ hx2190 Pocket PC
How can i uninstall panasonic videocam suite?
I had this problem and someone pointed me towards this
http://www.appdeploy.com/software/detail.asp?id=178735
I eventually deleted the folder that this string identified, and I was able to re-install the software at long last
pipster
Jan 03, 2009 | Panasonic PV-GS500 Camcorder
Ntl eurovox ireland
go back to the (Menu) screen then (installation) and (OK) on (User Installation) again enter 0000 as your pin, Now press the yellow button for (Power Scan).
Start the search @ 290.00MHz & end it @ 420.00MHz using the symbol rate of 6.887Mbaud then hit (OK) to start the scan. could take a few minutes but should get all your channels back.
Dont suppose you could post the most recent codes up please?
Dec 25, 2008 | StarTech.com StarView SV211K 2-port KVM...
Pictures
Start>Programs>Pictures & Videos
navigate to the picture in question and select Menu (right function key)>Delete.
or try
Start>Programs>File Explorer
navigate to My Device/My Documents/My Pictures and now you can select multiple files and then select Menu (right function key)>Delete.
Is this what you want?
Oct 16, 2008 | Samsung i760 Black Phone
How to delete recent log
I am having the same problem. I just contacted my wireless provider and they were stomped!! They tried calling Samsung directly but they are closed on Sunday's. I will be calling tomorrow but I have a strong suspicion that because there is no prompt to delete the log that a "Master Rest" will have to occur. Be advised that if this is done, that log may be deleted but so sill EVERYTHING else that is not factory set. All data will be lost if that is done. So hopefully that won't have to occur.
Nov 04, 2007 | Samsung BlackJack
Samsung SCH-i730 Pocket PC Logo
52 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
