Question about Photography
Exakta VP model B with 7,5cm f2,7 Meyer Makro Plasmat??
Hi, I have an Exakta VP Model B with a Hugo Meyer 7,5cm f2,7 Makro Plasmat and cannot find any info about it anywhere? Does any one know of any others? The body serial No is 417340 and the lens serial is 581850...the focusing helicoid is quiet a bit longer than other Exakta's I have with Tessar lenses?? Please let me know if anybody has any info on my camera,thanks JonathanG
  • 11 Answers
SOURCE: Compatibility of vivitar lens with Minolta x370
Additionally: Even if your Vivitar lens does not have a Minolta lens mount, you can get an inexpensive adaptor to be able to mount the lens on your Minolta camera. At least you used to be able to buy these adaptors before the World went digital crazy. I still think the adaptors are available. Check with any large camera store, like B&H in New York. Also manual focus lenses for older SLR's (Single Lens Reflex) film cameras are available at reasonable prices. I have the same Minolta X370 camera (along with few others) and lenses for it. So you can get a lens that has a Minolta mount for your camera, this might be the easist way to go and you can sell your Auto focus lens (since the Auto focus will not work with the Minolta X370 camera). Hope this helps you. Thanks, AJ.
Posted on Sep 21, 2007
tjzteddy
  • 53 Answers
SOURCE: auto focusing problem
The D40 will only autofocus with the Nikkor AF-S lens...look for the AF-S in the lens title. For 3rd party lens, only SIGMA with the USM title will autofocus.
To use the T-adaptor...you will need to use the "Manual" mode of the camera.
Posted on Dec 29, 2007
cammedic
  • 667 Answers
SOURCE: aperture diaphram on mamiya secor lens 80mm f/2.8
The lens has a lever marked A/M near the aperture ring. If the lever is in the 'A' position, the lens will stay wide open until you trip the control lever at the back of the lens next to the rear optics. In the 'M' setting, you can see the aperture move as you change the f-stop setting on the ring. Set the lens to anything but wide open and move the control lever with your finger. You should see that aperture move.
Posted on Jan 14, 2008
Obertelli
  • 3006 Answers
SOURCE: Manual Canon 50mm FD lense will not focus!?
In that case the linkage between the movable parts of the lens group and the focussing ring has failed.
What follows applies to most lenses; I have a Canon 50mm FD to hand but as it works perfectly I've not needed to dismantle it so far but have repaired many others.
When you turn the focus ring there are usually two pegs which engage into helical slots cut into the focussing ring, these are hidden within the lens and you won't see them unless the lens is dismantled. The pegs are usually rounded to make the passage along the helical slot even smoother and each one is fixed to the inner lens barrel by a screw. On older lenses, the grease inside can dry out a bit, especially if the lens remains unused, when this happens the pegs may either shear off or simply become unscrewed and drop off. The gummy grease may hold them so you won't always hear a rattling part inside.
To fix it, you carefully dismantle the lens to the minimum extent you can get away with. You'll need good light, patience and a set of good quality crosshead precision screwdrivers. Normally you start with the screws on the mounting flange and watch out for small springs and detent balls which tend to escape to freedom never to be seen again. Some of the screws are usually hidden beneath the rubber grip on the focussing ring, and you remove this to check by carefully lifting an edge and then rolling it back over itself. It may need re-gluing afterwards. Clean out dried grease as you go and apply a small amount of thick grease to replace it on reassembly: less is far better than too much! Some of the screws may need thread lock applied to them when they go back in, but you're better off leaving this as your first time lens repair usually has to come apart again due to an error in reassembly.
Be prepared to ruin this lens as it's your first lens repair. The good news is that auction websites have plenty of other cheaply and in full working order, just make sure to ask if the iris (aperture) works smoothly and snappily and that the lens does not have the dreaded lens fungus on the glass elements (a patchy white haze). You can also usually get these lenses for free on Yahoo FreeCycle and a camera body and other goodies normally come as part of the offer. FreeCycle is how I've collected various Nikons, Canons and Pentax SLRs and lenses over the last year to add to my existing Olympus gear.
I hope that I've helped you, if so please return the favour by rating my answer.
Posted on Jul 08, 2009
  • 63 Answers
SOURCE: Nikon D50 with Nikon DX 18-55 lens will not focus
Sorry to hear about your lens. If you are able to autofocus and take pictures with any other lens, then it means that your problem lies with the kit lens. If you can take picture in manual mode, but not in autofocus mode, then the AF motor in the lens in not functioning. I had the same thing happen to my 50mm 1.4 lens.
Depending on your location, there are Nikon repair centers in Melville, NY and Torrance, CA.
Hope this helps,
Andrew
Posted on Apr 16, 2010
Meyers home snowplow goes up n down no problem.angle right it inches its way to the right.angle left motor runs no movement. any thoughts
It sounds like a faulty valve. Some valves use O-rings to seal between ports and they may have failed. I would check the lines for trapped air first.
Oct 25, 2015 | Meyer Home Plow Home Plow by Meyer...
HI, WINDOWS7 DOES'NT RECOGNIZE MY CAM VP-D307 I, IT'S POSSIBLE TO FIND A DRIVER?
Yes, go to the web site of the camera manufacturer and check for updated driver for your model camera.
Dec 17, 2012 | Samsung Cameras
Samsung camcorders
You'll have to tell us what "this" model is. The model number of the battery charger doesn't tell us much about the camcorder itself.
Feb 02, 2012 | Samsung VP-W60, VP-W60B, VP-W61, and...
Need a temperature control unit pa 8300,for a Meyer Work
Try Meyer Customer Relations
http://www.meyer.com/contact_us.html
In 1998 I lost the cord for my wok (don't know the wok model as I do not have the wok now). Meyer sent me a replacement. The TEL number I called was 800 326 3933.
Jul 18, 2011 | Meyer 48986 Electric Wok
I have a toshiba x-ray camera model VP-34017RD with fault in driver board and need the circuit diagram.
TOSHIBA-VP-34012 400,000 CCD
TOSHIBA-VP-34016 400,000 CCD
TOSHIBA-VP-34017 400,000 CCD Thats yours used in siemens MOBILTRON C4
TOSHIBA-VP-34019 400,000 CCD
TOSHIBA-VP-34501 1 MEGA PIXEL CCD may be in C5 mobiltron
Aug 28, 2010 | Health & Beauty
Clouds in my TV
Hi it seems that the colour gun has gone faulty or the equivelent in an lcd tv. I purchased my umc from makro & I have never had any problems returning anything. As long as it is within the 12 month warranty. If 28 or more days have passed, contact makro or UMC & get an RMA number & you can get it replaced or refunded.
Jan 31, 2009 | Televison & Video
I need a replacement cord for an electric steamer/fry pan. The model number on the back of the cord is PA8300. Can you help??
http://www.meyer.com/kbReplacementParts.html
If you go to potsandpans.com and type cord in the search....
SKU # RP025
I dunno if this will work for you. It priced at $8.99.
Circulon Electrics
Fits model #48785, 45681 and 45881
Fits only Circulon Electric: Wok, Griddle and 12'' Saute
You may contact them by telephone Monday through Friday, 7am to 5pm PST (Pacific Standard Time) excluding holidays.
(800) 450-0156. This is potsandpans.com
Meyer 800 numbers => http://www.meyer.com/contact_us.html
Dec 26, 2008 | Kitchen Ranges
Hugo Boss watch
go to this link and find your nearest Movado Group(they make and repair the watches) service centre; http://a3.geoserve.com/scripts/esrimap.dll?Name=L&Com=fo&Db=DLRMovall&Ds=Movado&Filt=User4%20LIKE%20'_S%25' They can probably answer your question over the phone or e-mail, if not they certainly could if you could get the watch inspected. Most jewellers would also probably know - sometimes the serial number can be marked inside the watch, but I found no information online about your model that discusses this. Hope this helps, hope it's real :)
Jan 30, 2007 | Hugo Boss Metropolis Maxx Watch
Photography Logo
93 people viewed this question
Top Photography Experts
Tony
Are you a Photography Expert? Answer questions, earn points and help others
