Iwantit iph10011 Speaker has no sound
How to tune in a Iwantit ihfusbnit13 the rario stations will NOT stay Have to tune in evertime
It's sounds like you haven't connected the memory wire on the radio it's normally the blue cable that's got men. On it at the back on the wiring hardness
Sep 28, 2016 | Cars & Trucks
Right speaker has no sound
Check R cable from source to speaker, No power used in L or R cable, they only receive the signal from SOURCE to speaker, You onlly have 2 ends of each cable, 1 to source other end to speaker
Mar 13, 2015 | JBL Pebbles 2.0 Speaker System 2-Piece
Can I turn the standby option off on my Iwantit IPH10011 docking station
I'm trying to work out this as well. When I got mine first, this didn't happen.
Feb 25, 2014 | Audio Players & Recorders
Ineed an iwantit icrip12 clock radio manual
hi, i also need the manual for this product, have you found one yet?
Nov 11, 2013 | Audio Players & Recorders
My volume buttons on my compaq presario c769us are not working , is there a combination for the volume buttons
From the manual:
http://h10032.www1.hp.com/ctg/Manual/c01114193.pdf
Hotkeys are combinations of the fn key (lower left of keyboard) and one of the function keys:
Mute and restore speaker sound. fn+home
Increase speaker sound. fn+pg up
Decrease speaker sound. fn+pg dn
To use a hotkey command on the computer keyboard, follow either of these steps:
Briefly press the fn key, and then briefly press the second key of the hotkey command.
- or -
Press and hold down the fn key, briefly press the second key of the hotkey command, and then
release both keys at the same time.
Muting speaker sound (fn+home)
Press fn+home to mute speaker sound. Press the hotkey again to restore speaker sound.
Increasing speaker sound (fn+pg up)
Press fn+pg up to increase speaker sound. Hold down the hotkey to increase speaker sound incrementally.
Decreasing speaker sound (fn+pg dn)
Press fn+pg dn to decrease speaker sound. Hold down the hotkey to decrease speaker sound incrementally.
More manuals for this model:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lc=en&product=3678775&
Jan 25, 2013 | HP Compaq Presario C769US Notebook
How do u get a iwantit ipodcr10 docking station to work in portable mode
Iwantit iPhone speaker....volume button not
Working...when I lower volume it skips to next track...what's going on????
Aug 10, 2011 | Audio Players & Recorders
My daughter has an Iwantit ipod speaker model IW900 and it works/sounds fine with her ipod usind the dedicated ipod connector. On the the back of the speaker there is an Aux in socket. She would like...
It took me a while to figure this one out. Firstly plug your device in to the aux socket and play some music so you can hear when it's correctly switched over. Turn on the iwantit using the switch at the back then press the play button once, you should see the lights on the buttons go brighter. Now press the play button again, this time holding it down for exactly 3 seconds. When you release the button you should be in aux mode and you should hear your music playing. Hope this helps, it took me about an hour of faffing around before I finally figured it out.
Aug 16, 2010 | Audio Players & Recorders
The speaker of my computer have no sound when i bought it it have sound and when i change the speaker to head phone the head phone have sound and then when i plug the speaker and unplug the head phone the...
If you can get sound from the headphone from the same audio output and not getting any sound from the speaker, it is obvious that the speaker is not working
Jul 18, 2010 | Computers & Internet
DVD plays partial sound
Check your speaker connections it sounds like you have a 5.1 or higher sound system. 5.1 means left front speaker, right front speaker, center speaker, right rear speaker, left rear speaker and subwoofer.
Voices in movies all get channeled to the center speaker (you can usually hear it a bit from the right and left front speakers as well). If your center speaker is disconnected or not working, you will only hear the background sounds.
Sep 20, 2008 | Compaq Presario 5000 PC Desktop
137 people viewed this question
 Grubhead
Grubhead
