MY PHILIPS FMW154/05 CANNOT READ A CD AND WILL NOT EJECT ANY IDEAS
How do i eject a CD/DVD wit the Philips SRP3004/10? It doesn't have a button with the eject icon on it...
some do not have eject option ,only way is to doit at the device since they do not auto load or replace disk U need to be there .
Jan 18, 2015 | Philips SRP3004/10 universal remote...
Philips wireless music centre model WAC 700/05 will not eject cd or recognise. displays no cd
Philips music centre model 700/05 keep on saying booting please the other one is fine but the main unit which plays CD I have try all the trobleshooting but sill the power can't turn on how can I get the setup CD Rom
Apr 09, 2013 | Philips WACS700 Shelf System
I insert a CD into my CD Drive,the Drive can not read it and I can not eject it. CD Drive motor always tries to read CD. How must I do to eject the CD
you can manually eject the dics with a straightened paper clip via a small hole on the face of the drive it will help you retrieve the disc
Jan 26, 2011 | Dell Vostro 1510 Laptop
Hi, my cd player will not read cd's. It will read disc not finalized. We have a philips cd player. I'm not sure where to find the model number. It is a 3 disc changer. I read about cleaning the eye, but I...
you need to purchase a laser disk cleaner to clean the laser they are available from almost all electronics retail outlets
here is a picture of one
have a great day
please rate this advice if it helped
Jan 03, 2011 | Philips Audio Players & Recorders
Philips 3360H - can't eject DVD
Try this..turn it off, unplug it for a min or two, then plug it back in. THEN...if the power stays off...hit the eject/open/close button on the panel.
Sometimes this activates the eject mode without turning on the unit. IF NOT, try the remote eject without turning on the unit.
Apr 06, 2010 | Philips DVDR3370H DVD Recorder/HDD...
My CD won't eject on my Philips WACS700?
try holding the eject cd button while turning on and off or pressing the eject button rapidly while turning off and on. Thats done the trick for me in the past.
May 11, 2009 | Sony CMT-SPZ70 Shelf System
CDR is not working
have a look on ebay for a cheap working donor recorder as spares are very expensive and very hard to get hold of.
i'm guessing your recorder either doesn't read discs, or it won't eject? which is very common and means either the servo board is faulty or the laser.
The following recorders i know off hand for a donor mechanism are:
MARANTZ DR-6050
PHILIPS CDR-775
PHILIPS CDR-770
if it proves to be just a faulty laser, all 3 of the above have the same laser unit.
if it proves to be a faulty servo board, all 3 have the same servo boards except if you fit one out of a philips model it will show 'PHILIPS CD RECORDER' on the display at power up but will still work nontheless.
obviously if a marantz is found it will show 'MARANTZ CD RECORDER' as normal.
hope this helps.
Aug 27, 2008 | Marantz CDR500 2-Disc CD Recorder
Eject button will not eject cd
Mine was stuck in there for almost a year until I disconnected the battery (for other reasons) and when I reconnected it, the CD finally saw the light again.
Jan 26, 2008 | Eclipse CD7000 CD Player
CD stuck in player
Both times that a cd has become stuck in the player I simultaneously pushed the power and eject buttons. I came across this solution in the owner's manual and it worked perfectly both times I have had to do it.
Sep 20, 2007 | JVC KD-G200 CD Player
Philips CDD 4801 CD-RW Burner cycles
Is this covered by a front console cover type or is the dvd, as it is with it's own eject button, as it may be touching the front eject button.
Jan 15, 2007 | Philips CDD 4801 CD-RW Burner
23 people viewed this question
 Grubhead
Grubhead
