SOURCE: Panasonic TV Remote
open it the keys are on a rubber membrane.
clean the board and the membrane
SOURCE: Panasonic Model #Th-42PA25
it is just an example for the part that should be replaced that is why i suggested that a service technician should check the tv physically to determine the part that needs to be replaced.
SOURCE: Panasonic model TH-42PW4 manufactured 2001.
it sounds a bit like power supply to me but with the darkeness can mean the pic tube has run on ya or even a resistor or capacitor
SOURCE: removing the stand from tv
I called Panasonic customer service and they directed me to their website where I was able to download that portion of the manual that addressed removing the stand.
SOURCE: How do I remove the stand from a panasonic tv. model TX - 32LXD70
The stand is held on by four screws. Lay the tv face down on a flat surface. Cover the surface with a blanket first. Use a regular phillips screw driver. (If you have a users manual see page 7)
The screws are the set just above the stand on the back of the set. The stand will then slide out.
