Question about Samsung Washing Machines
WA80TALEC/XTL electronic control circuit board short and burnt
3 Suggested Answers
SOURCE: W640T2 (CIRCIUT BOARD)
I am a technician for Asko in Australia.The blackness on the motor control unit(circuit board) is probably carbon dust from the carbon brushes in electric motor.Likely problem is motor brushes have totally worn the armiture in motor or the MCU needs replacing due to earth leakage or short.Purchasing the parts from Asko should be no problem, but if you purchase and install electrical componenents only to find problem unresolved, you can't return installed parts for a refund. Also the breather hose from the detergent dispensor to outer tank can leak from tank connection when spinning load , and result in water running down outer tank and onto the electric motor causing circuit breaker to trip.....possibly damaging motor too. Goodluck!!
Posted on Sep 23, 2008
blueextc3221
  • 15935 Answers
SOURCE: I like to know the circuit board plug ins
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 17, 2010
I have xtl 500 model no L20QSS9PW1AN .audio is not comming.its audio interface board consolete is ok, spk is ok cables are ok I also re software but same condition .some fault is inside the main board pl...
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Nov 09, 2014 | Televison & Video
Tip
GE Gas or built in oven fault codes
FO or F-1. Failed transistor in control. If code can not be deleted recommend to replace the electronic control or touch pad
F-2 Oven over temp exceeded 590F with door unlocked.or 990F with door locked.Recommend you check for welded or burnt relay contacts or high resistance on the oven probe.
F-3 open oven tempurature sonsor.Recommend that you replace the oven probe.
F-4 Oven temp sensor shorted. Recommend you check for melted connnectors or both leads shorted to ground.
F-8 Component failure in Electronic range control,Recommend that you replace the electronic control board.
F-9 Problem with door lock Circuit.Recommend that you check the wiring to the lock mechanism make sure there is no pinched or broken wires.Replace door lock mechanism as needed.
on Jan 02, 2011 | Kitchen Ranges
Elite troubleshooting
unplug/remove power from device.. check heater element with a volt/ohm meter if ok , check timer for burnt contacts or circuit board for burnt connections, may be an internal logic failure if its electronically controlled(bad board/controller)
Mar 15, 2014 | Dishwashers
Funai magnavox model#37md359b-7 when turned on for amp fuse blows on circuit board
Could be 100 things. Do you see any burnt components or burnt spots on the board? Probably no way for you to fix this unless you have the electronics repair skills unless you visually spot a short on the board like a loose screw that ended up laying on a couple of components etc.
Feb 18, 2013 | Funai Magnavox 19" Class 720p 60hz LED TV...
Cav 2 2.1 speakers volume control is burnt
Short circuit in the board. Lcukily you can get a very inexpensive Universal Remote for almost nothing now. Shorts will smell similar to burned plastic, otherwise known as ozone. Discard the controller after removing batteries.
Sep 20, 2012 | Cambridge Soundworks Audio Players &...
I have a Jandy Aqualink RS system. The wires for one of the valve activators was shorted and the outdoor control panel and the indoor control panel lost power. None of the circuit breakers was tripped.
On the RS system there is a small fuse on the back of the circuit board. That may have been burnt. It acts as a safety for the transformer. Make sure ALL of the power is off, then check that fuse. Do not keep the shorted valve actuator plugged in. Replace it, or leave it disconnected. Then replace the fuse. Then re-apply power to the unit. Otherwise your transformer may go out next. If the fuse is not burnt, which would surprise me, you may have a burnt transformer.
Apr 04, 2011 | Jandy AQUALINK RS TELELINK KIT
Dryer not working. failure code E2
The electronic control board detected that the thermistor located on the blower housing is shorted (zero resistance). Either the wire harness connecting the thermistor and the electronic control board has a short circuit or the thermistor is indeed shorted. Click on the link below for the detailed troubleshooting instructions of this problem.
Troubleshooting Error Code E2 on Whirlpool Duet Dryers
Mar 01, 2011 | Whirlpool Dryers
The dishwasher will not turn on
Congratulations - you found the fault !
The options you have are -
Buy areplacement board from a spares centre.
Buy a take- off board from a scrap one on Ebay.
Or - Learn about electronic repair - and identify the burnt component , buy the parts and replace it yourself.
You can take it to an electronic repair shop - if you can find one - or a electronic supply shop - and ask for a new one of "them".
If replacing a burnt component - often there is a cause other than just that component.
Experience tells you what else might be wrong to cause it.
Aug 04, 2009 | Maytag MDB9600A Jetclean II Built-in...
Whirlpool GU2500XTP dishwasher went dead in mid-cycle.
"Wondering if this model has had reliability issues with the circuit card." ...If by circuit card you mean the electronic control board, that part number is used in many other models as well. In my experience with these control boards, I believe they have a low failure rate.
Make these checks if you haven't done so yet...
Check for 120V (breaker). Look for loose/shorted wiring connection at the dishwasher's junction box. Check all wiring connections to the control panel, electronic control and thermal fuse. Test the continuity of the thermal fuse (part # 8193762). If that's ok, you have already replaced the control panel so the problem is likely with the electronic control board (part # 8564546).
Good luck.
Mar 12, 2009 | Dishwashers
Sep 13, 2008 | Asko W6461 Front Load Washer
Washing Machines Logo
37 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
