My tray on my marantz ud5005 wont open - Audio Players & Recorders
My Marantz CD 53 CDplayer door is not opening. what is the solution
You probably have a broken belt on the cd tray so it's neither open or closed, if the laser's ok thats why it wont play
Mar 31, 2014 | Marantz Audio Players & Recorders
Marantz PMD 350 CD player/Cassette deck
Well if you want to DIY you should open the coves, spay some oil on the mechanics and ensure they are running smoothly, if you spray grease on lens you will damage it, be careful.
Jun 01, 2008 | Audio Players & Recorders
Marantz reset
how do i reset my UD5005 bluray player to factory default?
Jan 09, 2014 | Office Equipment & Supplies
Update firmware
It can be downloaded by Maranz official site.
Aug 13, 2013 | Marantz UD5005 BluRay Player
Disk
Check if there's an actual disk, and test with other disks.
May 27, 2013 | Marantz UD5005 BluRay Player
Fl off red led flashes on display and i can't do nothing
When you first turn it on, press the "pure direct" button to turn pure direct off.
Feb 08, 2013 | Marantz UD5005 BluRay Player
CD-72 Marantz CD Player disc tray is stuck in the shut position.
You might have to open the player and see why. remember to unplug till you need to see if you can get it to work or not.
Sep 06, 2012 | Audio Players & Recorders
How to reset ud5005 bd player
When I press any button in the remote it displayes BD2 and the remort is not working how to reset help
Feb 29, 2012 | Marantz UD5005 BluRay Player
DR6000 display "open"
you may need to replace the whole mechanism as i've had quite a few philips and marantz cd recorders with the same mechanism with exactly the same problem. when you press open/close it will display open or close with no sign of life from the player. this turned out to be a faulty laser unit and the PCB which is underneath the mechanism seems to go the same way which i found out later when i replaced the laser unit. the recorder worked for around 5 minutes then the laser started moving erratically but then would work again for 5 minutes after switching it off & on again. i cured the fault by replacing the PCB aswell. hope this helps?
Aug 24, 2009 | Marantz DR-6000 CD Player
CAN,T DETECT CD IN BURNER TRAY
laser failure on the recording side is very common on marantz and philips cd recorders.
they're well known for it.
so it's most definately the laser in your case.
hope this helps.
Jun 19, 2009 | Marantz CDR500 2-Disc CD Recorder
184 people viewed this question
 Grubhead
Grubhead
