Question about Microwave Ovens
Nn st659w I have just bought a Panasonic NN ST659W Inverter Microwave. Does it have a lght and if so, how do i replace the bulb please ?
MicrowaveSvc
  • 9098 Answers
SOURCE: I need to find a
Generic replacement bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
If you would prefer to order the original bulb, the best place to order Panasonic parts is Tritronics.
You can also call them at 866-779-5835.
Posted on Dec 08, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Hi, I have a NN-C784MF
Chances are there are other bad parts blowing the diodes, most likely a MOSFET.
Also, the ESR of the electrolytic capacitors should be checked and all board connections must be checked and resoldered if suspect.
If you're not experienced in troubleshooting switched-mode power supplies (inverters) then you can probably save a lot of timer and money by replacing the whole inverter.
You can find the nearest spare parts supplier by selecting your country then the support links at Panasonic.net.
Posted on Jan 02, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: bulb replacement
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
You'll need to remove the outer cover (wrapper) to get to the bulb.
Always unplug a microwave before removing or installing any bulbs.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Posted on Jan 19, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: Panasonic NN-P295 Cooktop Light not working
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
Posted on Jan 23, 2009
SOURCE: Bulb Replacement in Microwave
You have to take off the case. Need a T20 Tamper Torx bit and a Phillips #2 Bit. There are 2 tamper-torx screws on the case to discourage inquisitive types / prevent untrained hands from entering. Once the screws are out (5 in total), slide the cover off the back. On the right-hand side, you will see the electrics. The bulb is behind the black oval shaped fitting that lies just behind the 2 big red wires that carry the high voltage to the microwave tube. Just pry over the bend-down metal tab, and lift off the black oval, bulb is attached to it. Replace, re-install, and test with case off and door open to ensure your replacement works. Re-install the slip-off case and screws. You're done.
Kermit
Posted on Jul 05, 2009
Change light bulb panasonic inverter nn-h965bf
We recommend you have an authorized service center location replace the light bulb. Authorized service centers can be found in the below link.
www.panasonic.com/repair
Welcome to Panasonic Online Repair
Mar 23, 2014 | Panasonic NNH965BF Microwave Oven
Can't set the clock on panasonic NN-ST659W
read your owner manual download for free go towww.fitness.manualsonline.com and proceed the steps for adjustments clock.However you can be faulty control board or keypads.God bless youad8400f4-1635-4201-a242-f94fd7ee4a4a.gif
Apr 02, 2013 | Microwave Ovens
Panasonic microwave oven model NN-ST659W settng clock
when setting the clock wont let you use the microwave
Mar 17, 2013 | Microwave Ovens
Model NN-ST659W works for about 30 seconds then displays H98 on the display panel how do I fix this problem
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here. If you're not in the US, see Panasonic.net.
May 31, 2012 | Microwave Ovens
Panasonic NN-C980B stopped working. Blown fuse.
Sometimes when the mag shorts it takes out the inverter. I would measure the mag leads to ground and they should be open or 20M or so. If you have both a mag and inverter bad it's probably time for a new oven.
Apr 19, 2010 | Panasonic NN-C980 Convection/Microwave...
Panasonic NN-T994SF Microwave Oven quits after 15 seconds
my microwave shuts off after a few seconds. is there a fuse that needs replacing?
Feb 01, 2010 | Panasonic NN-T994SF Microwave Oven
How do I remove the sensor inverter on the Panasonic NN-S96OWA ?
That's a misnomer.
And oven may have an inverter and it may have a sensor (usually either a heat sensor or humidity sensor).
Please note that FixYa is not currently notifying us Experts when Clarification Requests are answered.
So to allow us to help you effectively (at no charge), please post a
NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, and your exact symptoms, so we can help you troubleshoot the problem and make recommendations.
Jan 08, 2010 | Panasonic NN-S960WA Microwave Oven
Stopped heating, shuts off before time expires
My panasonic microwave model # NN-S540BFW stops after 4 seconds after you hit the start button and cuts off on its own. What is wrong with my microwave?
Jan 12, 2009 | Panasonic NN-S763BF Microwave Oven
Panasonic bulb nn a753
First, get the bulb part #F612E4W00AP or equal. Next, you should find a few screws around a plate in the unit through which the light shows through. Carefully remove them and the glass lens. When replacing the bulb, be sure it is in securely.
Dec 15, 2007 | Panasonic NN-T774SF Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
