Question about Lenovo ThinkCentre Computers & Internet
HOW TO BOOT LENOVA THINKCENTER M SERIES AFTER RESETING BIOS
SIR I HAVE LENOVA THINKCENTER MT-M-9736-AR7 MODEL DESKTOP , I CLEAR THEN BIOS FROM JUMPER NOW I CANT ACCESS TO BOOT MENU, JUST AFTER PRESS F1 CTRL S OPTION CAME IN WHICH I JUST OPEN MBA CONFIGURATION MENU IN THAT NO OPTION OF BOOT FROM HDD. HOW CAN I ACCESS FULL MODE OF BIOS OR BOOT MENU TO FURTER WORK. PC NOT START JUST OPEN AFTER POST ITS RESTRTS , IN POST ITS DETECT HDD AND CD DRIVE WELL BUT NOT BOOT FROM THAT PLS GIVE ME SOLUTION FOR THAT I TIRED TO USE ALL COMBINATION ESC CTRL INS F1 TO F12 KEY I ALMOST RIED EVERY COMBINATION OF KEY AS I GET FROM TOO MANY SITE MOTHER BOARD IS INTEL I 946F AND PHONIX BIOS AND LENOVA MT-M-9736-AR7 MODEL
SOURCE: Emachines T3882 desktop w/one cd-dvd combo drive[no floppy]
Download the drive test for the hard drive. Put the drive in your other computer and run the test. If it test good on simple test do the long test. IF IT COMES OUT FINE, Run the Zero program and then try to install the O.S. Check your BIOS settings and make sure everything is set right. You are on the right track. You just did not know how to test the drive. If it is a Toshiba you will not find a hard drive test. You might be able to use the Maxtor or Seagate drive test. Use the windows version if you can. If you can't do any of the test, right click on the drive and check for errors.
Rate me if this helped.
Posted on May 29, 2008
mumma_1
  • 903 Answers
SOURCE: BIOS failure ??? DEll Systems OptiPlex GX270 Series
this may or may not help, try taking out the cmos battery out (looks like a watch battery) and leave for a few minutes then replace, this will reset the bios.
Posted on Nov 17, 2008
SOURCE: Reset my Compaq D51C PC Desktop BIOS
hi anyone please can u help me i want 2 reset my pc back 2 the way it was when i got it so it like new again what keys on my pc can i use to reset it thank you sam.
Posted on Mar 10, 2009
callonafo
  • 174 Answers
SOURCE: I want my bios to detect usb flash drive in boot order
Quickly press F10 or F11 after booting your system, which will bring out the system setup environment, look for system power and boot setup to set up where your system to start booting from, be it your harddisk, CD drive or USB, select the one that you want first, the save the setting and restart the system.
Posted on Sep 21, 2009
SOURCE: HP Compaq Presario SR1220NX frozen on start up
while its froze take cmos battery out slide it back in real quick, it will restart and boot right up. ive done this it worked for me.
Posted on Jan 06, 2010
Where are computer settings on a Lenova desktop computer?
Could you please provide a little more info? What is the operation system you're running (ie, Windows XP, Vista, 7, 8, Linux, etc), what settings are you looking for (BIOS settings (for example, maybe you want to change the default boot device from a hard drive to a DVD drive so the computer tries to boot off the DVD drive first), power saving settings, device settings, windows update settings), etc. Also, perhaps the model number of the Lenova would help depending on what settings you're actually looking for.
Jun 25, 2014 | Lenovo Computers & Internet
On my ibm mt m8187 as soon as I plug it in it pwers up without pressing the switch. The fan and hd light comes on then off but fan keeps running with no boot
Have you changed something. It sounds like you have lost your config files. With out proper software or boot disk you will need help
Mar 29, 2014 | IBM ThinkCenter M50 (8189A1UJ) PC Desktop
Drive A: Error, Cannot detect Boot device
i assume you got two drives.do have been into BIOS ?.and done any changes ? you maybe don't boot from windows drive ? if have set optimal defefault in BIOS windows can switch drives.
Apr 07, 2013 | Lenovo ThinkCenter M52 PC Desktop
Overclocking in bios made desktop crash.
clear the bios - locate the little 3-pin jumper labeled with "CLR" or simmilar next to the bios chip/battery. short circuit the free pin with the one next to it (yiou will need to use the jumper that is on there). once you have kept it on for 10 seconds - put it back in to original position and configure your bios (time settings, boot device,...)
if you can't find the jumper or you think it's too complicated - unplug your pc from power and remove the bios battery. after 30 minutes install the battery as it was and configure your bios (time settings, boot device,...)
Mar 19, 2012 | Systemax Venture Computers & Internet
I have a Lenova laptop and a intel MB I am having a problem. Trying to login but the supervisor password won't let me in no matter what i try Lenova G550 2958
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
also
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased. Hope this helps
Aug 13, 2011 | Intel Motherboard
Hi im trying 2 reset my bios but carnt get in there i need 2 know what on and off pins on the board i can take off and where r they located
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS
after you make any changes in BIOS press Esc then press the F10 button save to cmos to restart
cmos is located in BIOS
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don
Mar 25, 2011 | Acer Computers & Internet
Dear sir, i forget my BIOS Password model no lenova y500
If you cannot access the machine after if has been powered up, it is still possible to get past the BIOS password. The BIOS password is stored in CMOS memory that is maintained while the PC is powered off by a small battery, which is attached to the motherboard.
If you remove this battery, all CMOS information (including the BIOS password) will be lost. You will need to re-enter the correct CMOS setup information to use the machine. The machines owner or user will most likely be alarmed when it is discovered that the BIOS password has been deleted.
On some motherboards, the battery is soldered to the motherboard, making it difficult to remove.
If this is the case, you have another alternative. Somewhere on the motherboard you should find a jumper that will clear the BIOS password.
If you have the motherboard documentation, you will know where that jumper is. If not, the jumper may be labeled on the motherboard. If you are not fortunate enough for either of these to be the case, you may be able to guess which jumper is the correct jumper. This jumper is usually standing alone near the battery. If you cannot locate this jumper, you might short both of the points where the battery connects to the motherboard.
If all else fails, you may have to clear the BIOS password by resetting the RTC (Real Time Clock) IC (Integrated Circuit) on your motherboard.
Many RTC
Jan 03, 2011 | Computers & Internet
How can you reset the cmos password
Dell Optiplex 780, user forgot BIOS master password (which is necessary to change the boot order to run BartPE from CD and do an image backup).
There is a jumper on the mainboard called PSWD1, which is set (shorted). Remove power cable from PC (CMOS battery can stay in place), open the lid. Remove jumper from PSWD1. Reconnect power, start the PC, hit F2 to enter BIOS. All passwords should be reset.
Leave BIOS, power off the PC, remove power cable. Reattach jumper to PSWD1, close lid, reattach power cable. Start PC. Enjoy.
Nov 11, 2010 | Dell OptiPlex 780 MT PC Desktop
Medion Compsoser 5200
Based on the information that you gave us...You can't access your BIOS for reconfiguration. To go to BIOS settings, try to press DEL or F2 button when you see the LOGO of the manufacturer.. Then change its Boot Sequence: 1st Boot - Optical Drive..2nd Boot- Floppy (if there's one) and 3rd Boot - Hard Drive. If your BIOS is protected then you need to shutdown your computer, 1. remove the powercable, 2. open your Desktop CPU, 3. look for the CR2032 Button battery, 4. locate the jumper near this Battery with CLEAR CMOS label. 5. change the setting of this jumper by removing the jumper and mount it on the other setting. Maintain for 5 seconds and then remove it back from its original setting.. Note: dont forget the original setting of this CLEAR CMOS jumper. Also never to POWER ON your Desktop while the jumper is at CLEAR CMOS setting. This will destroy your motherboard. 6. Connect the power cables and power ON your Desktop and you will encounter an error on BIOS setting. press DEL button or F2 to configure BIOS. 7. Then change BOOT SEQUENCE of your Desktop to boot to Optical Drive or CDROM first and then press F10 to Save and Exit. ..................... Check your keyboard if its working well otherwise get a GOOD Known keyboard or a new one.
Apr 09, 2007 | Medion M3 Composer 5200 PC Desktop
Computers & Internet Logo
109 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
